View Poll Results: How will you want to mod your engine?
Give me the boost of a turbo. 55 47.83%
NOS, the best bang for the buck mod. 10 8.70%
Engine swap is the way. 38 33.04%
Will stick to Naturally Aspirated High Compression build. 10 8.70%
I wont touch my engine. It will remain stock, thank you. 22 19.13%
Multiple Choice Poll. Voters: 115. You may not vote on this poll
Old 26th August 2007, 20:27   #46
v1p3r's Avatar
Thanked: 27 Times
Please recheck. The old Elantra had a 2.0 petrol engine in the US, loosely based on certain famous Mitsu blocks. The Indian Elantra comes with a 1.8, unless I'm terribly mistaken.
I'd like to explore the limits of my stock car before touching the engine, when I buy a car.
Old 26th August 2007, 21:52   #47
Default hi
how will it go ...
japanese m800 frontie<1986> with palio 1.6 100 bhp engine with 150 deg overlap valves +free flow exhaust 225 wheels ?
TURBOSAM is offline   Reply With Quote
Old 26th August 2007, 22:47   #48
ananthkamath's Avatar
Thanked: 63 Times
With 150 deg. overlap you will be blowing huge fire***** out the throttle body & sucking in air through your freeflow exhaust.
ananthkamath is offline   Reply With Quote
Old 27th August 2007, 00:00   #49
v1p3r's Avatar
Thanked: 27 Times
how will it go ...
I thought the Palio had zero overlap.
Old 26th March 2008, 08:35   #50
teknophobia's Avatar
Thanked: 22 Times
I can just imagine that
teknophobia is offline   Reply With Quote
Old 26th March 2008, 10:55   #51
Thanked: 152 Times
I vote for engine swap. Gypsy 1.3 MPFI engine in a fiat. Drool Drool
Cyrus43 is offline   Reply With Quote
Old 17th December 2010, 15:08   #52
daemon's Avatar
Default NOS and engine
What changes does one need to make to the engine to use NOS?
What other changes are involved?
Sorry if this sounds like a repeat question. I couldn't find a definitive answer on the forum when I searched.
Thanks.
Last edited by Jaggu : 17th December 2010 at 17:03. Reason: Please use Search before opening a new thread. Similar thread exists. Thanks.
daemon is offline   Reply With Quote
Old 17th December 2010, 17:15   #53
pranavt's Avatar
Thanked: 274 Times
Default Re: NOS and engine
No changes are required, just bolt a NOS cylinder and spray into the intake. Don't forget to use 2 buttons mounted on the steering wheel as that is the most important step. The buttons alone add 10 whp each. If you use steel braided lines, make sure that the fittings are blue in color as they lower the intake charge temps, help atomise the spray better and can increase horsepower by upto 30 nm and if you can procure cams with 360 degree overlap, you are set.
The changes needed to make the engine keep using NOS for more than a few seconds? That's a different matter altogether.
Old 17th December 2010, 18:29   #54
Ricky_63's Avatar
Thanked: 394 Times
Default Re: Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine?
Turbo for me. As I just TC'd my Swift !
Old 17th December 2010, 20:01   #55
jatinpatel's Avatar
Thanked: 191 Times
To above all just one question:-
is doing a engine swap legal in India?
Can it be officially be recognized by the RTO?
But if given a choice i would prefer dropping 4G63T into lancer and the rest mods like suspension and all.
jatinpatel is offline   Reply With Quote
Old 17th December 2010, 20:09   #56
pranavt's Avatar
Thanked: 274 Times
Twincharged ITB'd single cam Honda running Darton sleeves sleeved by Dan Benson.
Old 17th December 2010, 20:24   #57
Ricky_63's Avatar
Thanked: 394 Times
You live the dream that most of us do / did. Engine swap per se is not legal unless endorsed on your RC (which is not the easiest thing to do)
Ya you could go that route, rather read Amey's ENLIGHTENING thread.
Most of us here do not understand Greek Care to explain in simple English for us lesser mortals ?
Many thanks
Old 17th December 2010, 20:53   #58
pranavt's Avatar
Thanked: 274 Times
Many thanks
Honda D15/D16 single cam engine running a supercharger for throttle response at low revs and to get the revs high enough to around 5k RPM quickly, feeding the exhaust into a big turbocharger that's capable of around 600 whp, with my ITBs and a custom intake manifold to top it all up.
The block would be sleeved with Darton sleeves by one of the most capable guys for sleeving Honda blocks in the World, a one-man shop that runs Dan Benson racing.
Might just get it done one day
Old 17th December 2010, 22:26   #59
jatinpatel's Avatar
Thanked: 191 Times
@pranavt
just one question will the nimble little OHC stay on its feet with 600whp??
baring in mind with custom suspension and body strengthening done.
isnt 600whp too much for the OHC?
Old 17th December 2010, 22:48   #60
pranavt's Avatar
Thanked: 274 Times
Manageable, definitely. I should have a traction control system ready and on the car sometime during the next year. High speed stability is a function of the chassis design and the suspension; can't do much to the former but can definitely upgrade the latter.
What would you do if a vehicle hits you/you hit a vehicle! rajinibm Street Experiences 30 3rd June 2010 12:53
How much land would you need to build your own race track 2-2.5m long? 1Day Indian Motorsport 32 31st January 2010 13:14
Which car would you buy to modify?? Gordon The Indian Car Scene 81 11th March 2009 10:00
How do you want to modify your car? GTO Modifications & Accessories 58 2nd November 2007 16:49
NOS, How does NOS work? DRC Technical Stuff 2 26th December 2005 13:53
