Old 28th August 2007, 07:37   #1
Default Headlamp mods for Skoda
A friend of mine has a skoda octavia. Off late we are observing that the head lamp is not as strong as it used to be.I dont know if there is any probs. We did get it checked at the showroom...guys there claim its okay!
We were alos thinking about a new bulb....We went to a shop and he suggested ...hmm I guess 95/100 ( I'm sorry if I'm not making sense with these numbers....I'm not that techi on the electricals !! ) But I was worried about the reflectors....which might get melted with the higher rating
I want suggestions...
1) Should we get the head lamps rectified!...
2) Should we get a new bulb
Also could you please suggest a good place in blore where I can get it done!
deltabox is offline   Reply With Quote
Old 28th August 2007, 10:04   #2
gbpscars's Avatar
deltabox,
you can be pardoned, being a newbie, welcome to the forum.
but please use the search function.
there are numerous postings regarding your query, and there is a super long dedicated thread on auto lighting (more regarding the 100/90 lamps)
to make it short,... a 100 W lamp cant 'melt' something like a headlamp housing!!! (atleast not when fit with good branded accessories and methods)
gbpscars is offline   Reply With Quote
Old 28th August 2007, 10:57   #3
chiragh_bir's Avatar
Thanked: 70 Times
bro go in for xenons.... !!!!!!!
these days u can get bosch xenons for bout 7k... !!!!
chiragh_bir is offline   Reply With Quote
Old 28th August 2007, 12:14   #4
androdev's Avatar
Thanked: 2,305 Times
I would suggest keep your car next to a new car and compare the headlamp brightness (maybe park them in front of a white wall)
if you decide to upgrade, be considerate and buy something that doesn't blind the oncoming traffic. i am seeing lot of cars with after-market blinding white lights - and they start showing them off even during day time!
androdev is online now   Reply With Quote
Old 28th August 2007, 14:30   #5
shuvd's Avatar
@ Deltabox - I faced the same problem with my Octy. Actually, the main problem is the stock bulbs provided by Skoda. They are grossly under powered IMHO. The Skoda A.S.S. had no idea how to improve upon the stock fixtures. I contemplated 100/90 bulbs with harness etc. But, got a good deal on 6000K HIDs and am currently using those (at the lowest beam position to avoid blinding oncoming traffic). Haven't faced any problems.. yet!
shuvd is offline   Reply With Quote
Old 28th August 2007, 14:31   #6
khanak's Avatar
Thanked: 130 Times
http://www.team-bhp.com/forum/modifi...ting-here.html
khanak is offline   Reply With Quote
Old 28th August 2007, 19:13   #7
Thankyou guys!....sorry I had'nt seen the existing thread on this.....
@Shuvd what make are these 6000K HID....Is it a direct fit on or do I need to make mods with the wiring ?
How much will Xenon cost?...any good place in blore where I can go and get these things done?
Old 28th August 2007, 20:12   #8
Akshay1234's Avatar
Thanked: 7,241 Times
they would be a direct fit if you buy the correct bulb size. they will have their own wiring which will connect to the stock headlamp wiring. they would have their own ballasts etc. 6000k is the most popular and the brightest. the higher k you go the less bright it will become.
Old 28th August 2007, 20:19   #9
Ricky_63's Avatar
Thanked: 394 Times
I have recently upgraded my Octavia headlights to 80/100 W Bosch normal light colour NOT white. Normally Phillips or Hella would be 90/100 W As the visibility is best in a yellowish tinge (OE) color. Am very happy with the result. Cost 400/- Think that is the best solution. If that does not work for you / your friend then consider changing the headlamp (expensive proposition) Xenons are more for BLING FACTOR & less for actually driving clarity. That is my opinion, many may disagree.
Old 28th August 2007, 20:32   #10
you could also get at HID kit. Plug and play into the OEM harness of the car.
Shardul is offline   Reply With Quote
Esteem headlamp, tail lamp swap possible without mods? Raccoon Modifications & Accessories 24 15th December 2009 04:59
Headlamp stickers zzzehar Modifications & Accessories 19 7th May 2008 13:17
Clear Lens Headlamp for Type 1 Esteem!! CaliforniaKnight Modifications & Accessories 18 9th February 2006 15:38
Need more power from the Pulsar headlamp revvhed Motorbikes 3 26th April 2005 18:52
