Old 2nd September 2007, 21:20   #1
Default Xeon and Air filter options for a 99 Zen
I'm a newbie so excuse if I've not done enough to look up for info before starting a new thread. I'd like some info on the air filter options available for a 99 Zen (Carb and not MPFI). Also, is it a good option to switch to Xeon bulbs from the stock ones? What's the life of these bulb like and can I have a few brands I should be looking for? Appreciate the help.
ZenRocks is offline   Reply With Quote
Old 3rd September 2007, 08:49   #2
hellspawn's Avatar
Infractions: 0/1 (10)
you have the option of fiiting a k&n filter.lot of threads on the forum to help you with procuing them and finding shops to install them.it is definitely a good option to switch to xenon bulbs but honestly,they really work to well with the zens headlight assembly since they are not clear glass and hence diffraction of light is more.the various brands available are bosch,philips etc.
hellspawn is offline   Reply With Quote
Old 3rd September 2007, 09:32   #3
If somebody is installing Xenon to the zen .. do him need to chnage wiring and othet assembly it only changing a bulb is ok ?
nicejits is offline   Reply With Quote
Old 3rd September 2007, 15:16   #4
kjdesigns_2000's Avatar
If you go for a complete HID set then it comes iwth its Ballasts and xenon bulbs, no dont need to put anything other than that.
But if you just want higher wattage bulbs then you will have to upgrade your holders and wiring also. the Standard wiring cannot support the higher wattage bulbs.
If you go for an aftermarket bulbs of the same wattage but which claims to have better lighting then there is no need to change anything other than the bulbs itself.
kjdesigns_2000 is offline   Reply With Quote
Old 3rd September 2007, 15:58   #5
crazydiablo's Avatar
Thanked: 21 Times
For a 100/90 watts, halogen bulb you need not upgrad your holder. You need to add a relay to the wiring. Some even go up to 130/100 without holder change. IMHO 100/90 is more than good enough for some night driving.
crazydiablo is offline   Reply With Quote
Old 3rd September 2007, 16:39   #6
Crazydiablo,
Thx for u r reply ! what are teh rates of For a 100/90 watts, halogen bulb ? and a relay ?
Jitendra
Old 3rd September 2007, 17:20   #7
Thanked: 21 Times
You can get the Philips 100/90 halogen and a good relay. Cost is approx 1000 - 1200 bucks(quite and old quote). I would let other comment for the latest prices in mumbai.
Old 4th September 2007, 00:25   #8
kpzen's Avatar
Thanked: 1,598 Times
Can Xenon be installed in a non clear lens headlamps of an old zen?
Has anyone done it before??
Old 4th September 2007, 09:01   #9
Akshay1234's Avatar
Thanked: 6,670 Times
you can do it but it wont be as bright as the clear lens ones.
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
Halogens or xeon lights for karizma. maxguru Motorbikes 5 5th June 2007 12:39
Variable Intake system and performance air filter shazikon Technical Stuff 1 23rd February 2006 20:27
