Closed Thread
Old 5th September 2007, 13:37   #1
arunkvc's Avatar
Default 1985 maruti advice needed for engine mods
i am sorry if i am repeting the post if so please help me out.
i have a maruti 800 1985 model i have pit in a headder and high lift cam shaft and going to put in a esteem carborator. the main thing is i need it to pick up fast and do atleast a 150km so please advice.
ps: i have a webber carborater have to try and find out how it works.
arunkvc is offline
Old 5th September 2007, 15:35   #2
Akshay1234's Avatar
Thanked: 7,240 Times
put in a zen engine.
on a serious note do you already have a high performance air filter and a free flow exhaust? if not then you can start with those.
Akshay1234 is online now
Old 5th September 2007, 16:17   #3
pawan's Avatar
v1p3r old signature:
ss80+g13/d15+t3/t4=13 sec.
pawan is offline
Old 5th September 2007, 16:44   #4
arunkvc's Avatar
the engine has been done only the carborater to be fitted. first i have to find one have spoken to some guys have to get a good one.
arunkvc is offline
Old 6th September 2007, 10:02   #5
arunkvc's Avatar
what filter shall i put into it any suggestions
arunkvc is offline
Old 6th September 2007, 17:12   #6
Akshay1234's Avatar
get a k&n or ractive conical.
Old 6th September 2007, 18:09   #7
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Arun, just by changing the carb, a high lift cam and headers I do not think you will be able to extend your top end by that much unless your engine in itself will produce power at such high rpm's. If you want more power, I suggest you get yourself a 1.1ltr engine or a zen engine. IIRC, even a esteem engine fits into the engine bay of a 800. If speed is what you need then this would be the best option.
Or do an engine overhaul of the existing 3 cyl engine, check if the compression is alright. Change the oil, do some basic mods and see if you are satisfied. Going by the fact that you do rally, I think a esteem engine in the 800 is what will satisfy you the most.
mclaren1885 is offline
Old 6th September 2007, 23:47   #8
fieroid's Avatar
Thanked: 287 Times
if performance is ur only goal, then plonk the 5-speed 800/alto's 12 valve head. Use the zen or esteem carb, get a hot cam and header and it will be a screamer. Infact it can give complex to some mid-size cars too.
However, u need to work a lot on upping compression and getting the right state of tune. u can also mount a 5-speed gearbox.
The stock 800 bottom can be retained with the exception of only having to change the pistons to the ones with the 4-valve recess.
fieroid is offline
Old 7th April 2009, 12:53   #9
bablue's Avatar
Arun. I have been following your thread. Where is it headed now. Can you please let us know about it. How is your car performing and what all technical modifications you have got done. I am eager for your reply
bablue is offline
Closed Thread
Restored! 1985 Maruti 800 (SS80), A/C Deluxe royamrit Modifications & Accessories 27 4th September 2016 10:54
Advice On Restoring My 1985 Mercedes Benz 300d (w123) LOVE HER(ALD)! Post-War 3 7th October 2010 15:28
1985 toyota corolla estate bought.Help needed! iceman1 Technical Stuff 4 10th March 2010 10:54
Planning to Procure a 1985 White Maruti DX SPEEDY_RACER Hatchbacks 19 25th February 2010 11:19
Wanted 1984/1985 Maruti Suzuki SS80 DX ajay99 Shifting gears 4 27th January 2008 11:48
