Old 7th September 2007, 08:25   #1
1self's Avatar
Thanked: 270 Times
Exclamation Throttle Body Bypass
Hey Guys!
What is TB bypass, & how does it prevent from losing HP?
1self is offline   Reply With Quote
Old 7th September 2007, 09:29   #2
veyron1's Avatar
Thanked: 38 Times
It does not prevent it from losing HP; at least not on Indian cars, where the throttle body is standalone. Bypassing helps on coolant circuited throttle bodies, where the intake air temperature is adversely affected.
This is a technique mostly used on high-capacity dragsters...
There's also the bypass below the TB, used for I/T for idling; which's also called a TB bypass.
veyron1 is offline   Reply With Quote
Old 7th September 2007, 10:03   #3
Rash's Avatar
Thanked: 41 Times
The Idea behind a heated throttle body is to prevent icing in cold countries.
In our country we can do without heating the TB.But i am sure it is not going to make any difference to the HP either percepted or real.
But then the thing with DIY is you have to see for yourself that it will not work
So go ahead and do your TB bypass mod and let us know how it feels.
Rash is offline   Reply With Quote
Old 7th September 2007, 14:31   #4
Rash's Avatar
Thanked: 41 Times
My apologies, did not exlpain what a TB bypass is.
Basically the Idea in this mod is to stop the hot coolant from circulating around the throttle body.
Its a simple thing and all you need to do is route the coolant pipe that goes towards the TB directly back to the engine.
If you are not mechanically inclined then hop over sometime.I will rig it for you.
Throttle body cleaning amit_mechengg Technical Stuff 103 5th June 2018 12:04
DIY : Throttle Body - Coolant bypass Sankar DIY - Do it yourself 34 12th June 2013 22:12
Throttle Body Enlargement / Expansion hellspawn Modifications & Accessories 42 1st December 2009 09:44
RPM Surges-Throttle Body Cleaning wolfinstein Technical Stuff 29 6th October 2009 08:12
Optra, Throttle body repair sage Technical Stuff 5 7th June 2007 12:30
