Old 9th September 2007, 22:34   #1
speed0mania's Avatar
Default best CAI
hey guys finally got a ractive ev500 for my swift!
the first issue was finding a decent place under the cramped hood, once that was sorted by pushing the battry back a little the issue of what kind of CAI to use popped up,
i got the plumbing made in mild steel but the issue is how to protect it from getting hot, the metal piping tends to absorb heat from the engine bay, chrome plating sure looks good but i dont think it would really shield the intake from the heat any suggestions to insulate the plumbing??
as in what material to use and where to source it from!
speed0mania is offline   Reply With Quote
Old 10th September 2007, 09:43   #2
rishibravo's Avatar
I think you are worrying about the wrong thing here. If your filter is in the engine bay then you should try to insulate the filter by putting a heat shield of some sort.No matter what you do your filter will suck on hot air if it is in the engine bay and you dont have a scoop or the new Kits which come with an extra hose for the cold air.
rishibravo is offline   Reply With Quote
Old 10th September 2007, 12:15   #3
i know it is going to suck in some hot air it is next to impossible to get fresh air without the risk of water! but the filters placed in a decent enough location (infront of the battery) but the last thing i want is the air to get further heated due to heated pipes!
will try to find a decent shielding solution as soon as i find a good one for this! thnx!
Old 10th September 2007, 12:21   #4
streetsdisciple's Avatar
Sounds good bro ,can you please post some pics of the install ?
Do you mind telling how much did it cost you ?
streetsdisciple is offline   Reply With Quote
Old 10th September 2007, 12:46   #5
vikram_d's Avatar
Thanked: 940 Times
In a Swift - in front of the battery = behind the radiator. Your intake is anyways sucking in hot air.
Old 10th September 2007, 14:48   #6
its not directly in front of the radiator, and its the best possible solution, the car definately feels better, so i dont think i have any other option! im bed ridden right now so cant post pics yet!
but i seem to have found a soultion by wrapping the plumbing in fiberglass tape similar to that used in a cast(orthopedic). it has good thermal insulation properties and would be easy to wrap!
+ interesting colours;-)
Old 10th September 2007, 15:09   #7
nitrous's Avatar
Thanked: 285 Times
The BEST CAI for the Swift is the stock location.
A stock-replacement K&N/Green/Pipercross/Ractive filter in the Stock airbox which takes cold air from the honeycomb grill plus 3 times the air volume compared to a regular OE filter.
Come rain,come shine! The swift will drive fine!
Old 10th September 2007, 18:28   #8
lol!
but the stock intake doesn't get air from the grill either! my filter is placed where the stock inlet was! no air gets into the engine bay thru the grill! checked out the whole thing!
moreover i tried a stock replacement k&n in my zen and it did nothing noticable!
Old 10th September 2007, 18:41   #9
vikram_d's Avatar
Thanked: 940 Times
This wont be very noticable either.
Old 10th September 2007, 19:07   #10
rishibravo's Avatar
I agree with vikram here... But you can always use the loud growl to scare away the autowallas
Old 10th September 2007, 22:29   #11
i know it wont make much of a difference by itself but definately feels better than what i remember of the stock replacement! anyways getting back to the topic, any suggestions for insulating the plumbing?
Old 10th September 2007, 23:57   #12
rohan_fonseca's Avatar
Speedomania go to AutoSpeed - The World's Best High Performance Online Magazine and look at the article on 'siting CAIs'. Also check out the thread on appolo cai for some pointers. See if you can find some pics of cais in wrc cars as well.
rohan_fonseca is offline   Reply With Quote
Old 11th September 2007, 00:41   #13
hey thanx a ton rohan!
Fiat Palio S10 Green CAI bhavit46 Modifications & Accessories 18 4th June 2009 22:27
Greens CAI installed in Baleno vivekji05 Modifications & Accessories 35 10th October 2008 22:53
Fiat Adventure on Custom Headers, FFE and Green Cotton CAI akbaree Modifications & Accessories 12 4th September 2008 12:20
CAI will suck only cold air: even if sucking in air just next from the engine :-) khan_sultan Street Experiences 19 30th June 2008 09:29
Help Needed with CAI for IKON 1.6 abhik Technical Stuff 14 16th June 2008 19:13
