Old 12th September 2007, 14:40   #16
nitrous's Avatar
Thanked: 282 Times
Originally Posted by rd
Its a simple straight forward job.
A complete mpfi esteem engine, ecu, wiring and instrument cluster should cost you anywhere from 50k to 80k. Its a bolt on to your carb esteem.
Confusing karthi.
Are u referring to an engine swap here?
Old 15th September 2007, 03:16   #17
rohan_fonseca's Avatar
If it is increase in performance you are looking for you could do a lot with your current carb setup. Refer to dinars post. You could rejet, get better carbs, etc.It would be a lot cheaper as well.
rohan_fonseca is offline   Reply With Quote
Old 15th September 2007, 03:52   #18
chetanhanda's Avatar
Thanked: 42 Times
Originally Posted by veyron1 View Post
If we're just looking at going FI, why look at multiport? Why not TBI? Simpler, cost-efficient, and minimal alterations required, in terms of wiring, manifold customizing, labour, etc....
You mean go for throttle body injection instead of of multi point ?
Where is he going to get this type of a TB ?
Can we get one off the shelf ? Or you are suggesting he should fabricate one ?
chetanhanda is offline   Reply With Quote
Old 15th September 2007, 03:54   #19
v1p3r's Avatar
Thanked: 26 Times
First-gen Astras came with one. You could theoretically salvage one of them. Mating it will be less of an issue than fabricating a whole custom throttle body.
Someone on this forum has already done an 8v carb conversion to MPFI.
Weber carbs - specialist restorer required phil001 Post-War 8 15th July 2011 20:36
Looking for RD 350 Carbs and Clutch Inner Basket sanjusahu Motorbikes 15 6th April 2009 18:07
Urgent:Yamaha R1 Quad Carbs & G13b bruce Technical Stuff 7 23rd November 2008 05:01
Tuning Carbs Spinner Wheelz Technical Stuff 5 9th April 2008 17:08
Diff between weber dcoes and 4 bike carbs? Stage3Monster Modifications & Accessories 7 12th March 2005 07:07
