Old 11th September 2007, 13:55   #1
kpzen's Avatar
Thanked: 1,655 Times
Default Driver Seat getting deeper..!!!
My Zen is now 7.5 years old and has done 50k kms.
My car's driver seat is getting deeper and deeper with time now. The cushion seems to have totally gone and I'm feeling the springs underneath my bottom while passing through every bad patch on the road..
Rest of the seats in the car are pefect as they are rarely used.
What could be the best possible way to solve this issue?
Should i change the complete seat assembly?
Will adding cushion to the existing seat be a good idea? I doubt it as it will raise the hieght of the seats too much...
Old 11th September 2007, 14:40   #2
panky12345's Avatar
Thanked: 150 Times
kp, i'm facing a similar situation in my 6 yr old 99K Indica....the local guy suggested using foam and i did that, but of no use....seat tend to get deformed as the foam is not stable.
i think i'll go for changing the entire seat.
panky12345 is online now   Reply With Quote
Old 11th September 2007, 14:53   #3
Sankar's Avatar
Thanked: 4,646 Times
The seats would be having springs inside them. The seat is becoming saggy as the springs lose their tension. It should be possible to replace the springs and get a new foam lining which will bring back the firmness.
Hey KP that's what you call a proper 'bucket' seat
Old 11th September 2007, 15:06   #4
panky12345's Avatar
Thanked: 150 Times
sankar, any idea how much does it cost? and where to get it done from?
Old 11th September 2007, 15:32   #5
iraghava's Avatar
Thanked: 156 Times
That's the seats way of telling you two to lose some weight
I think re-upholstering the seat & replacing the foam will do the job, provided that it is done in a good place.
Old 11th September 2007, 15:42   #6
Sankar's Avatar
panky, your upholstery guy would be able to do it for you.
Old 11th September 2007, 15:46   #7
rjstyles69's Avatar
Thanked: 795 Times
Chuck those seats and get your self recaro/sparco look-a-likes Prajesh.
Old 11th September 2007, 18:04   #8
gd1418's Avatar
Thanked: 656 Times
A cheaper way for you would be to eat two paranthas less everyday for next 6 months...The seat will automatically recover..
Old 11th September 2007, 18:37   #9
Jaggu's Avatar
Thanked: 8,685 Times
If you want OE stuff then, zen has zig zag springs linked to clips that run around, check if these clip points are fine, if not a simple weld job will fix it. then see if these springs are ok, if not replace them and then move on to OE foams, buy them and replace the old one. This will be the best fix rather than going for stuffing and all.
If you want to upgrade go to a good apholstory guy and upgrade to leather upgrade, they will take care of the stuffin part also
Old 11th September 2007, 19:15   #10
Thanked: 20 Times
The other option is to ask furniture fixtures wala to give you some good quality foam to paste on the existance seat and cover with the new seat covers. Silly idea
contactme27 is offline   Reply With Quote
Old 11th September 2007, 19:38   #11
kpzen's Avatar
Ya sure but i dont like the springs making noise while the car goes through every bump.
No way. I'm already underweight.
Where do i get those from? How much do they cost?
Old 11th September 2007, 19:41   #12
rjstyles69's Avatar
Thanked: 795 Times
The look-a-likes cost roughly about 16k a pair. PM blueraven316 should be able to help you source them.
Old 11th September 2007, 20:07   #13
danlalan's Avatar
Thanked: 135 Times
But wil they be as comfortable. Can they be used for everyday driving..Or will it feel like you got something stuck to the back of you the whole time..
danlalan is offline   Reply With Quote
Old 11th September 2007, 20:18   #14
rjstyles69's Avatar
Thanked: 795 Times
People who have used them, have personally told me that its comfortable and they like it.
Old 11th September 2007, 21:44   #15
kpzen's Avatar
OMG...!!!
I'll find some cheaper jugaad. I dont think its wise enough to spend so much on a 7.5 year old zen.
My mechanic has told me that i can swap the front seats.
Riju..I'm still waiting for the Baleno seats pics.
Seat Covers: Choice Seat Zone, Royapettah pras.oct25 Chennai 40 28th October 2017 11:57
Slip on Seat Covers Vs Factory Fit seat covers Kärlsson Modifications & Accessories 18 29th June 2016 22:19
5-point Harnesses / Belt-In-Seat seat belts in Road Cars? Brute_force Modifications & Accessories 10 18th February 2013 13:38
My Height and Driver's seat distance webjunk Technical Stuff 8 6th March 2007 21:46
DRIVER TALENT:- How do u judge a good track driver from a good street driver memo45_m Indian Motorsport 27 18th May 2006 07:42
