Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 14th September 2007, 11:39   #1 (permalink)
Default honda civic suspension
hi guys i have recently bought a honda civic and no i still have my lancer, the civic is a dream to drive aceept one problem, i find that the rear stock suspension is not as good as i thought it would be , every time i drive over a "water pipe cut"(small pipes that cross the road) or what we now call mumbai roads the rear suspension makes a huge thud sound , a typical sound of a weak suspension system bottoming out, the company claims that's the suspension is perfect but i think other wise need help:
if i change suspension which one? and how much? will it affect warrenty?
daily driving route is 28 kms back and forth
ancer is offline   Reply With Quote
Old 14th September 2007, 11:42   #2 (permalink)
you are thinking about changing the dampers ?
srishiva is offline   Reply With Quote
Old 14th September 2007, 13:11   #3 (permalink)
Ancer,
Hats off to you.
You bought 12 lakh Rs. car, not happy with the suspension and instead of getting pissed off with the company/dealer, you want to go ahead and fix the problem on your own!
Why not try other Civics to see if all have the problem. If not, then the dealer/Honda will be forced to acknowledge the problem and fix it. If you find that all the Civics feel the same then you can probably do whatever you feel like with the suspension setup.
My 2 cents.
__________________
Aerodynamically speaking, a bumble bee should not be able to fly, but it does not know this, so it flies.
anandpadhye is offline   Reply With Quote
Old 14th September 2007, 13:40   #4 (permalink)
shailu's Avatar
Install a Koni FSD(frequency selective dampers) for you civic . it makes a huge diffrence .
__________________
"Dream as if you'll live forever,live as if you'll die today"
shailu is offline   Reply With Quote
Old 14th September 2007, 13:53   #5 (permalink)
The damping might not be as soft as you want. Try other cars and see if its a problem with your car.
Old 14th September 2007, 18:22   #6 (permalink)
viper's Avatar
I would suggest you install TEIIN's. They simply rock and you also have the advantage of installing a EDFC controller on dash.
See this link for TEIN. PRODUCTS and this for the EDFC
TEIN EDFC.
Have just got the same for a 2005 Accord.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 14th September 2007, 18:42   #7 (permalink)
Ford Rocam's Avatar
What Tyre Pressure you running on rear wheels?
__________________
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Ford Rocam is offline   Reply With Quote
Old 14th September 2007, 21:03   #8 (permalink)
jeetu4444's Avatar
Infractions: 0/2 (8)
iam sure u have high tyre pressure.... i own a civic for few months now have changed the it to 17 inc alloys with 225 tyres goodyear f1 and my suspension is perfect get your car checked or check tyre pressure
jeetu4444 is offline   Reply With Quote
Old 14th September 2007, 21:09   #9 (permalink)
nitrous's Avatar
Viper, I've studied that Tein suspension system.
And wow! Its such a Godsend to tune the suspension in real-time from the cockpit ,on a race track.Aaah! What pleasure!
For the road driver, U can play with soft/hard setting depending on the road u're gonna use.
Infact,I think this is better than the Koni FSD system which has a mind of its own.
__________________
Maruti - Everyone comes home with rattles!
Old 14th September 2007, 23:25   #10 (permalink)
Team-BHP Moderator
Mpower's Avatar
Do you want a suspension that is stiffer or softer than the stock one? How can you bottom out by driving over a water pipe? do you have like 8 people in the car?
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 14th September 2007, 23:45   #11 (permalink)
Bit off the topic here but a couple of friends said that they have a problem with their Civics touching bumps and speed breakers. Is this true? If so, why? The Accord has lower GC and longer WB and does not face this problem?
__________________
Thanks,
Kumar
kumar2007 is offline   Reply With Quote
Old 15th September 2007, 11:19   #12 (permalink)
well on monday i have asked for a test drive of another civic, will take the car down the same route and see if i get the same effect, as for tire's they are stocks, haven't modded anything. will also be requesting the company to ajust the suspension set maybe its to hard! i am a person who belives that if you buy a glove it should fit you well because if it doesn't it will always bother you all theway! hence the suspension thud may not be such a huge problem it will always play on the back of my mind, you'll know how it is when you hear the litle sound coming and you just want to get rid of it!
Old 15th September 2007, 12:09   #13 (permalink)
zenx's Avatar
Is it just a perception issue ? Hondas typically do offer more road "feedback" than many other brands - and people actually appreciate this cause this makes for surer driving. Even a tiny pebble on the road is communicated back through a tiny thud - though not usually accompanied with any jolt etc. Its not so much a "bad" suspension as its an audible one, imo.
More technically capable folks may comment on this more technically
__________________
Sameer, Bangalore
zenx is offline   Reply With Quote
Old 17th September 2007, 12:52   #14 (permalink)
no man. it's like a huge *BANG*. feels like the suspension bottoming out.
but thanks - i will screw the dealer as my 3rd service is coming up.
and now with this recall abroad maybe they'll take it more seriously.
Old 20th September 2007, 20:53   #15 (permalink)
joethomasv's Avatar
Hi Ancer,
Even I have the same problem with my 10 month/20k km Civic. Its a problem with all the civics. The rear suspension bottoms out way too easily even with moderate loads. Its a great car otherwise. Even I'm looking for a solution and thats how I ended up inthis thread.
Joe.
joethomasv is offline   Reply With Quote
Thread Tools
It's Official: Mid-Day report on Civic Suspension issue amit The Indian Car Scene!! 40 4th May 2008 09:04
Honda City 1.5exi suspension evoVIII Modifications & Accessories 11 25th November 2007 19:27
honda suspension issues-need help nitroxx Shifting gears 1 28th January 2005 19:54
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
