Closed Thread
Old 30th September 2007, 15:44   #1
adheesh's Avatar
Thanked: 35 Times
Smile Restoring a 1991 Fiat
Hi. I have a 1991 fiat which is in excellent engine condition but has some rust. I am planning its complete overhaul starting the 11th of October. Here are the things i'm planning with the budget alloted
- Paint Touch Up : Rs.5000/- (Since the car already has a 2yr old coat 'of po' paint)
-Castrol GTX or Magnatec (Need Advice Here): Rs. 650 or Rs.1000
-New Suspention Bushes
- A antirust coating from turtle wax outlet (offering wriiten 15 yrs warranty) : Rs. 3850/-
Any other things which need to be added? My total budget is Rs.15000
adheesh is offline
Old 30th September 2007, 19:23   #2
nitrous's Avatar
Thanked: 285 Times
Its actually the Castrol Magnatec GTX. Around 750 for 3 lts which I think is more than enough for the Padmini.
Btw, I don't think this thread needs to be in the Vintage section. No offence, but a '91 padmini kinda contaminates this section. Lets leave this for the proper vintage and classics. Hope U understand.
nitrous is offline
Old 30th September 2007, 23:16   #3
Stanher's Avatar
Thanked: 1,691 Times
Wow, that sounds kinda steep! You can instead try Wurth, you get a 1L can @ Rs. 950 odd....2 cans should be enough for 1 car, even so it'd come less than the price of TW you've quoted here....just a suggestion!
Stanher is offline
Old 1st October 2007, 22:18   #4
adheesh's Avatar
Thanked: 35 Times
Wink
After Researching I have concluded to work up on the following things
Painting & Protection
Touchup: Rs.5000
Buffing: Rs.1200
Wurth Protection: Rs.1894
Oils & Filters
Castrol Magnatec GTX: 3lts: Rs.1000
Flushing & Rest : Rs.500
Oil & Air & Fuel: Rs.350
Coolant: Rs.200
Mechanical
Fan Motor & Water Pump: Rs.1200
Suspension : Rs.2500
Gear & Valve Tuning: Rs.750
Electricals
Sparkplugs & Cables Rs.350
All advices are welcome !!
adheesh is offline
Old 2nd October 2007, 02:02   #5
1100D's Avatar
Thanked: 2,503 Times
You mention rust, what are the main areas of rust on your car. How is the floorboard? How are the front housing for the leaf springs. Post some pictures.
You dont need Castrol GTX magnatec. Castrol GTX itself of the correct grade will suffice and it is of the API-SL grade as well and hence conforms to modern standards as well.
The PAL manual will have an extensive list of the different grades of oil's applicable.
Are you doing the conversion to electric fan? Note that it requires more than just the motor.
1100D is offline
Old 2nd October 2007, 10:03   #6
adheesh's Avatar
Thanked: 35 Times
Thanx for the quick reply. The main parts of rust on my car are
1. The doors (at the bottom) The rust persists even after repeatedly cleaning all the drain holes.
2. Behind the front and rear bumper
3.Edges of the boot lid.
adheesh is offline
Old 20th October 2007, 18:49   #7
adheesh's Avatar
Thanked: 35 Times
Hi. I've sent my car for a full repaint in the same shade but 2k paint. After it comes back i myself with a mechanic who has his expertise in FIATS is going to tune the engine suspension etc and flush the oils replacing it with gtx magnatec.
adheesh is offline
Old 20th October 2007, 23:19   #8
karlosdeville's Avatar
Thanked: 8,810 Times
Is your car sea facing? Is it in a sheltered parking? If the 1st answer is yes, and the second is no, there isnt much you can do. The car is supplied with woefully inadequate antirust, and Bombay weather is merciless.
When the car is washed take extra care that water doesnt collect in all the channels, which just hastens the process.
karlosdeville is offline
Old 21st October 2007, 01:47   #9
egangsta's Avatar
Is your car sea facing.
Karl, i think Adheesh place is close to this place called Kalwa Creek, so that may the reason for it to rust too, Adheesh, am i right, you stay in Kalwa right ???
Adheesh, which workshop are you getting the work done ?? I could drop by when am free.
egangsta is offline
Old 21st October 2007, 08:20   #10
viper's Avatar
Thanked: 9 Times
As per your request I am giving below my comments.
1> Paint - You will need a higher budget if you want to do a professional 2k booth job as there is a lot of corrosion. Would advise a full scrap to bare metal and go forward. Consult V-16 or Karlos.
2> Both are good enough go for whatever suits your budget.
3> A definite change if existing are worn out.
4> Avoid.
Cannot comment or advise without seeing the car condition.
Viper
viper is offline
Old 21st October 2007, 10:47   #11
adheesh's Avatar
Thanked: 35 Times
Thanks for your responses.
1. From the year 1991 to 2003 the car was in Dadar but not exactly near chaupati.
2. In the year 2004 , I had the car fully repainted and replaced the parts which had corroded.
3. Since 2003, the car is in my place at Teen Hath Naka, Thane (West) in a fully enclosed stilt parking as you can see the pic in my 'avtar'.
So the main reason for rust may be the water that seeps through the window channels (When they are rolled down) and perhaps the drain holes provided by PAL are not efficient enough.
I have sent the car again for a full paintjob with 2K paint (Ofcourse I had to extend my budget for it, but its worth it) at Vasant Autogarage (Where I had earlier got the paint job done with excellent results.) which is next to the H.P Petrol Pump besides wockhardt hospital, Mulund West.
After I get the delivery of my car on Saturday (17th October) I would then proceed at changing the oils, and other work. I had to do this since the garage for the paint job and the mechanical work which I use are two different place due to their expertise in thier respective fields.
Anyway would be coming with my car on the 4th Nov FCCCI rally surely.
adheesh is offline
Old 21st October 2007, 15:43   #12
adheesh's Avatar
Thanked: 35 Times
Thumbs up
Here are some pics of the car
adheesh is offline
Old 24th October 2007, 18:50   #13
adheesh's Avatar
Thanked: 35 Times
Went to the garage yesterday. The tin work was going on. Will post the pics tomorrow
adheesh is offline
Old 25th October 2007, 20:09   #14
adheesh's Avatar
Thanked: 35 Times
Here are the latests pics from the garage.
The Tin Work In Progress.
Car All opened Up. Was Unable to take more shots due to poor lightning conditions and I didnt have the camera with me. All these are taken by a cell phone camera
adheesh is offline
Old 26th October 2007, 12:11   #15
prabhuav's Avatar
Thanked: 112 Times
Default your 1991 fiat
post better pics soon...
prabhuav is offline
Closed Thread
Restoring my college mate 1991 Enfield 500CC sreejeshmp Motorbikes 5 1st December 2009 21:25
1991 Maruti 1000 - 4,00,000+ kms Porus Long-Term Ownership Reviews 32 16th February 2009 02:01
Engine and gearbox swap for 1991 SWB Trax citron Modifications & Accessories 16 24th November 2008 22:38
1991 - Diesel 190 D Mercedes - Remap or Engine Swap ?? vipul_bscity Modifications & Accessories 5 18th January 2008 21:39
Pic : 1991 Caddy Brougham + 1996 Fleetwood v12 Super-Cars & Imports in India 24 30th May 2005 00:54
