Old 29th February 2008, 14:14   #226
karan561's Avatar
Thanked: 9,342 Times
Originally Posted by viper View Post
Hey Karan,
Are you taking part in the Speed Run. If yes good time to prove what you say. Will be driving a Civic in your category, lets see who is faster
Viper
Hey there jiggy boy .... good to hear from you it has really been long ... sadly i am not taking part this year too , because i have my exam(2nd Prelim-TY-Bsc. - Chem.) on the very same day in the afternoon and another TEST on Sunday too .
Shall unofficially test it someday. cheers:
karan561 is online now   Reply With Quote
Old 29th February 2008, 21:11   #227
ram_hyundai's Avatar
Thanked: 48 Times
Best of luck to both of you guys.lol .Interesting to lookout for the winner.
ram
ram_hyundai is offline   Reply With Quote
Old 1st March 2008, 02:10   #228
varun_patra's Avatar
Originally Posted by blueraven316 View Post
Man these Rims look sweet . Good choice of rims by the owner . Havnt seen a merc in a long time with brabus rims , and now we have a civic
Last edited by Rehaan : 1st March 2008 at 08:46. Reason: No need to quote all the images / text.
varun_patra is offline   Reply With Quote
Old 1st March 2008, 12:39   #229
S@~+#0$#'s Avatar
Thanked: 37 Times
Hey Satya, saw this car on Residency Road yesterday. Looked Killer. Well Donecheers:
S@~+#0$# is offline   Reply With Quote
Old 1st March 2008, 21:52   #230
hey guys, i didn't used to like these projector lights earlier but the more i see them on civics, i have started likeing them.pls tell me are they of good quality, i mean there build quality. do they perform well after fitting HID's. cause i don't want to spend thousands on these if they aren't good enough and is the projector lens good enough or is of cheap quality. people who are using them, please reply on this. thanks
sanchits is offline   Reply With Quote
Old 1st March 2008, 23:39   #231
FlyingSpur's Avatar
Thanked: 1,331 Times
How much do these projector headlamps cost? And any idea how much a sunroof would cost to be installed onto a Civic? What about the reliability?
FlyingSpur is offline   Reply With Quote
Old 2nd March 2008, 19:57   #232
blueraven316's Avatar
Some better quality snaps taken in the day time
blueraven316 is offline   Reply With Quote
Old 3rd March 2008, 00:46   #233
Thanked: 31 Times
What happens to the ride quality with that size of tyres ??
csentil is offline   Reply With Quote
Old 3rd March 2008, 00:48   #234
m4ugr8's Avatar
Thanked: 123 Times
as blueraven has said before!!! forget the practical issues....its looking hot and that is what matters
m4ugr8 is offline   Reply With Quote
Old 3rd March 2008, 01:21   #235
hellspawn's Avatar
Infractions: 0/1 (10)
@blueraven:Looks damn hot,and you have managed to accomplish what honda hasn't...increase the ground clearance.The car looks higher than the stock civic or is it just the camera angle.
hellspawn is offline   Reply With Quote
Old 3rd March 2008, 03:54   #236
v1p3r's Avatar
Thanked: 27 Times
Damn, so the pics are finally up. Will check the car out when I'm back, and it's good to know I can always call Rajiv for a drive anytime I want a cure for indigestion!
Old 3rd March 2008, 11:39   #237
ST7677's Avatar
Thanked: 45 Times
The car is raised up as the over all diameter of wheel has increased.
Of many other things, this would lead to...
1. Lower speedo & Odo readings
2. Very poor ride quality - considering Bangalore roads
3. Probably the Suspension would die very soon
4. The rear tyres have taller profile (side walls) than front tyres. i.e. the rear wheel has bigger diameter and the car is raised from back. This can reduce the stability of the car. (anyway I don;t think it can be driven fast on our roads)
Well all that on practicality front.
But they do look hot
ST7677 is offline   Reply With Quote
Old 3rd March 2008, 13:19   #238
The profile on both wheels are 30, suspension is stock and not raised, and IMO it is a absolutely horrible idea to fit such rims on our road conditions, as one cannot even drive the car fast enough to feel the bad ride quality, so in a way the suspension is taking a beating and at the same time not, cos this car is not even taken on bad roads let alone be driven fast.
This is like taking a Tiger and keeping it in a cage like a good looking multicolored Monkey in a zoo that everyone wants to see.
I personally would not go above 17"/18" on a civic considering my driving patterns.
EDIT: BUT, IT LOOKS ABSOLUTELY HOTT !!!!
Old 3rd March 2008, 14:10   #239
ST7677's Avatar
Thanked: 45 Times
Also this car demands to be lowered to improve the looks.
With this size of wheel and stock suspension, the tyres would probably hit the wheel well if lowered. So the car should be lowered with a stiffer suspension.
With these awesome rims that should be a must do next step...
Any pics from the rear side of the car showing the wheelies..?
Old 3rd March 2008, 17:05   #240
ST7677's Avatar
Thanked: 45 Times
The profile on both wheels are 30...
Profile is specified as a ratio of tyre wall height to width (tread) in %age.
Tread width in this case is different 225mm for front and 245mm for rear, so the height (tyre wall height) is different.
It is advised not to to run different sizes tyres considering safety aspects.
BTW I expect the car is raised at least 1 cm compared to stock, due to the bigger wheel. This demands to be lowered, it would look even better
Is it possible to install a Civics engine on a Baleno? Baleno4397 Modifications & Accessories 11 31st August 2009 10:09
Honda Recalls 182,756 Civics Over Wheel-Bearing Leak Ashutosh The International Automotive Scene 11 18th September 2007 11:16
Visit to Honda Dealer - New CRV Driven, a Few Crashed Civics Seen roovee Test-Drives & Initial Ownership Reports 14 9th April 2007 22:59
Pics: Honda Civic (modded) Gordon Super-Cars & Imports in India 51 11th March 2007 21:14
Modded Honda City(old V) artofzen Modifications & Accessories 6 13th January 2005 13:53
