Old 6th August 2009, 12:55   #691
m4ugr8's Avatar
Thanked: 123 Times
@ The Saint: The header and strut braces for the Front and Rear are in my Car. I am just not getting the time to get them fixed, Will get it done soon and post the results soon.
m4ugr8 is offline   Reply With Quote
Old 6th August 2009, 13:01   #692
Thanked: 286 Times
Which one in the pic for the header will fit in the civic (the single one through out of the one which has single head with 4 and the exit), you bought the strut bar to fix for what, I mean for handling or bottoming down, in a rush as I am planning to drive down to delhi and want to order all of this from Thailand on the net, the shipment will take atleast 10 days to reach me.
The Saint is offline   Reply With Quote
Old 6th August 2009, 13:15   #693
m4ugr8's Avatar
Thanked: 123 Times
The single one will fit, The exhaust manifold is integrated inside the cylinder head. Its basically not a header but a Pipe to eliminate the front Cat.
The strut will not help solve the bottoming out issue, For that you need Shocks or springs. This will improve handling.
Old 6th August 2009, 14:33   #694
ImmortalZ's Avatar
Thanked: 141 Times
You'll need an O2 CEL eliminator if you remove the cat.
Old 6th August 2009, 14:52   #695
navpreet318's Avatar
Thanked: 837 Times
Nope not required.Tested it on my car.
navpreet318 is offline   Reply With Quote
Old 6th August 2009, 16:39   #696
Thanked: 286 Times
Thanks guys,
M4- Header will give more power, fuel efficeincy or what? IMprove handling means more stablity on corners etc. please enlighten.
You mean the below one will fit. You bought it from India, if yes then how much, I see you from Delhi maybe you can help when I am there?
Btw- Navpreet how are you, how is the header doing on your car mate?
Thanks guys,
Btw- Navpreet how are you, how is the header doing on your car mate? by the way im back on stock rims and will never buy lenso in my life (cheats)
Old 6th August 2009, 16:51   #697
m4ugr8's Avatar
Thanked: 123 Times
Thanks guys,
Thanks guys,
It should lead to an increase an Power, Though I cant gaurantee anything, FE wont increase thats for sure. Struts will help reduce Body Roll and Flex. which will inturn lead to better handling.
Old 6th August 2009, 23:26   #698
Thanked: 837 Times
I'm good.the car's doing good too .the only problem with the header is that it doesn't pass the emissions check by a slight margin.
Thats the sole reason of my concern and thats the reason i removed it.So i'm using a full cat back exhaust system along with the stock CAT CON pipe.
my car's running beautifully.17 inchers in the city and 15's when i'm out of the city.I keep it that way and its a pleasure to drive and to look at too.
Old 7th August 2009, 07:05   #699
ImmortalZ's Avatar
Thanked: 141 Times
It's such a sad situation. Two stroke autos cause so much pollution, but nobody gives a damn.
How was the noise with the full race header + exhaust system installed?
Old 7th August 2009, 09:56   #700
Thanked: 837 Times
Well the noise was surprisingly not bad at all.It was slightly more than that with the stock system.Maybe its because of the silent yet free flow exhaust that i got made.I was particular that it should be as silent as possible yet being free flowing.Its a compromise but i'm happy.
and the sound with the header was different no doubt but it wasn't that loud.Though i would have loved that sound.It became more bassy than the present exhaust sound that my car has and mind it that it too is quite bassy.not the typical honda sound.
Well about the pollution ,i'd like to do my bit.i changed the full exhaust on my superbike and it cleared the emissions test.but this didn't.seems like honda is hugely relying on the cat con to clear the air.
Old 7th August 2009, 12:33   #701
shyammg's Avatar
Hi Guys
Here's a pic of my civic with 17's and a K&N Typhoon Kit. I have been hesitant to do more stuff on this since its my daily driver.
Have any of you guys used Koni sport or FSD? Any suggestions for Coilover's?
Also, anybody aware of someone who arranges EBC or Hawk brake pads and Powerslot rotors.
Look forward to some feedback.
Shyam
shyammg is offline   Reply With Quote
Old 7th August 2009, 13:58   #702
Thanked: 286 Times
Navpreet, so you suggest a full system with the exhaust means full Free flow to be installed if I need to feel the actual gain? what is the gain like, do you feel the difference or its hardly any, also will it be worth doing it on a automatic though u have a paddle shift.
Have you done anything to your suspension like the coild springs etc etc.
Guys, someone needs to sort my low beam high watt bulb issue, still no solution to it, I dont want HID kit, want a yellow halogen bulb suggestion.
Cheers..
Old 7th August 2009, 13:59   #703
Thanked: 837 Times
Well get in contact with m4ugr8.he's getting some more work done in his civic.He's the one stop person for all you civic related queries.
Old 7th August 2009, 14:00   #704
Thanked: 286 Times
Shymmag- Contact Viper who is a member here, he has D2 coil over full sports suspension which is Value for money and he has others as well, choice will be yours at the end of the day, he can get the brakes done for u as well...
Old 7th August 2009, 14:03   #705
Thanked: 286 Times
m4u- I am driving down to delhi on 29th August with my baby, can you let me know your whereabouts in Delhi and if we can catch up for a while. I would love to see your baby too and suggestions for improvement on some stuff.
Btw do you have a solution for the low beam headlight so that I can install and see the highway better on my way to Delhi??
Is it possible to install a Civics engine on a Baleno? Baleno4397 Modifications & Accessories 11 31st August 2009 10:09
Honda Recalls 182,756 Civics Over Wheel-Bearing Leak Ashutosh The International Automotive Scene 11 18th September 2007 11:16
Visit to Honda Dealer - New CRV Driven, a Few Crashed Civics Seen roovee Test-Drives & Initial Ownership Reports 14 9th April 2007 22:59
Pics: Honda Civic (modded) Gordon Super-Cars & Imports in India 51 11th March 2007 21:14
Modded Honda City(old V) artofzen Modifications & Accessories 6 13th January 2005 13:53
