Old 13th February 2011, 14:32   #31
hiren959's Avatar
Thanked: 50 Times
Default Re: Dashboard reflection on windscreen
Same problem facing in my ANHC and somewhat in my Figo.
And the best solution I am having is polarised sunglasses. I have put one pair of those in my cars so the problem is solved 100%.
hiren959 is offline   Reply With Quote
Old 13th February 2011, 14:47   #32
Thanked: 143 Times
Saw another solution in a taxi WagonR in Goa - he put a dark black colour cloth on the dash - it was tailored for the dash, with holes for air vents and other things under the dash. The WagonR has a depression above the glove box - where the air bags go. There was zippered bag at this place.
Old 13th February 2011, 16:33   #33
Faced the same problem with my NHC but the reflection has reduced after I installed vkool film on the front windscreen .
aditya_911 is offline   Reply With Quote
Old 13th February 2011, 16:42   #34
Turboholic's Avatar
Thanked: 21 Times
Originally Posted by Kairalee View Post
I too have a pair of Fast Track polarised sunglasses and it helps ward of the reflection from the windshield completely.
One thing I noticed though was, when I look at the windshields of cars through my Rear View mirror or through the ORVMs, they seem to be multicolured. Something like when you look at a large soap bubble in the sunlight...you see the entire spectrum of colours on it.
I never felt this when using a regular sunglasses.
Has anyone else using a polarised sunglasses felt this and is this normal for a polarised pair of glasses?
Edit: Oh and another thing that polarised sunglasses eliminate is the shadows of over head tree branches when you drive fast on a tree lined road. Without polarised glasses, the shadows of these overhead branches/leaves/foliage can be very distracting as they rush over your car's windshield.
@Kairalee: I have experienced the spectrum of colours on windshield of other vehicles when I use Polaroid glasses. There is a typical pattern to it mainly squarish. I am not sure what causes it though it is not seen using normal Ray Bans.
I think this is normal for Polaroid sunglasses.
Turboholic is offline   Reply With Quote
Old 13th February 2011, 19:00   #35
Thanked: 55 Times
After reading through the new posts, I am convinced using polaroid glasses is the best solution. The only remaining question is which brand is the best (I have to use clip-on sunglasses on top of the regular glasses I use)
mohan41 is offline   Reply With Quote
Old 13th February 2011, 19:26   #36
jerry can's Avatar
Thanked: 63 Times
@Mohan: Polaroid is a brand in itself. The technology being discussed above is Polarized lenses. You can get sunglasses with polarized lenses from many good brands, even Ray-Bans have a range with polarized glasses.
jerry can is offline   Reply With Quote
Old 13th February 2011, 19:29   #37
Thanked: 1,191 Times
Putting sunfilm on the front windscreen may not be legal. Also because of the slanting windscreens of the modern cars, this problem will occur in all modern cars in more or less degree.
The only solution would be to use a dashboard cover or a piece of cloth spread over the dashboard.
Old 13th February 2011, 19:54   #38
Mpower's Avatar
Thanked: 1,682 Times
Originally Posted by headers View Post
Simple solution is to use a matt black cloth on top on your dashboard, close to the demist area. Black absorbs light and does not allow the reflection to occur.
Where is this matt cloth available? How is it held in place?
Old 13th February 2011, 20:09   #39
Arkin evoisrevo's Avatar
Thanked: 108 Times
Well, windshield sunfilm on my car is totally transparent, and so is not illegal. It does have a very slight green tinge though, but it looks the same as the windscreens of Mercs.
Arkin evoisrevo is offline   Reply With Quote
Old 13th February 2011, 22:41   #40
@honeybee the dashboad cover will 'look bad and will be tuff to clean.
As mentioned by Arkin, the transparent sunfilm is not illegal and solves the problem.
Old 31st March 2011, 12:39   #41
Thanked: 55 Times
I see at least two varieties of polarized lens - grey and brown. Which one is recommended for driving, please suggest.
Old 31st March 2011, 13:31   #42
Thanked: 25 Times
The best colour for Polarized glasses would be "No Colour". You can use them even in the night.
Polarised glasses also reduce the glare of headlights. However dark tinted ones can't be worn at night.
I have light brown ones and have found them useful even while driving in rains.
Has anyone come across clear polarised glasses?
Highflyer is offline   Reply With Quote
Old 19th April 2011, 22:42   #43
rajatsingh78's Avatar
Thanked: 27 Times
I think this link will be useful to many here,
How about a bulk order, if yes, I am in
night polarized | eBay
rajatsingh78 is offline   Reply With Quote
Old 2nd November 2012, 00:26   #44
Chewbacca's Avatar
Thanked: 119 Times
Default Non-reflective cloth to cover the dash board
I wish to paste the top area of the dashboard with a non-reflective black cloth to eliminate the reflection on the wind-screen. It would be cut to size and pasted at the edges using 3M tape so that I can replace / wash it when needed.
The best I could think of was a 5 mm thick black sponge sheet but I couldn't find one. I am sure other have better ideas. Maybe there is something available specifically for this purpose. I did find some readymade dashboard covers for the Indica but mine is a Lancer and it won't fit. Also, they were not black. Some were velvety dark coloured and didn't really help prevent the reflection. Please suggest.
Chewbacca is offline   Reply With Quote
Old 2nd November 2012, 01:47   #45
quadra's Avatar
Thanked: 52 Times
Default Re: Non-reflective cloth to cover the dash board
I wanted to try out how carbon fiber vinyl acts when placed on the dash. Will try sometime
quadra is offline   Reply With Quote
Front windscreen sunfilm? Samurai Modifications & Accessories 2195 30th October 2017 16:39
If I want to change Vista Dashboard to Manza dashboard: A Discussion sushantr5 Modifications & Accessories 14 13th July 2010 12:08
Dark windscreen sunfilms - cops raid in NaviMumbai!!!! gbpscars Modifications & Accessories 18 16th April 2009 14:48
Windscreen Grime Hazards! Sahil Technical Stuff 42 10th October 2008 10:27
An interesting reflection : Slow Down Culture sharathjeppu Shifting gears 10 13th February 2007 19:03
