Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 16th October 2007, 21:06   #1 (permalink)
Default Zen Engine overhauling
HI Friends, I own a Zen 2000 MPFI which has done 91000kms till date. I was driving to the airport to leave for delhi one night in bangalore, due to heavy rains one of the roads was filled with at least 2 feet of drain water for a streatch of 200meters as there were no other alternative routes I decided to cross it , with the 1st gear engaged and engine reving hard by clutch slipping I some how managed to cross it ...of course there were anxious moments in the middle of the strech where i felt that the engine might just giveup but it did not and it drove pretty well that night Once I came back after two weeks, there was a disturbing friction sound from the engine ( as though two metal disks were rubbing against each other )and the idiling was pretty high I would say 2000RPM!! I got it checked from a MOS near my place, they did an engine tune up, changed the engine oil which brought back the High Ideling to much lower but for the sound they say that the engine needs to be opened up and decarbed and the costs would be around 3 to 4K well I dont really see the connection here....need to know if there are any good mechanics in bangalore who work on Zen engines in Blore who is reliable? any thoughts on this one?
enigmatictech is offline   Reply With Quote
Old 17th October 2007, 08:43   #2 (permalink)
gopz's Avatar
Who checked the Engine, was it a MASS? Can you post the details here please?
gopz is online now   Reply With Quote
Old 17th October 2007, 09:58   #3 (permalink)
mithun's Avatar
91000kms is a good age to do an overhauling.
But, more details needed before an advice.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 17th October 2007, 10:15   #4 (permalink)
gotzuk's Avatar
mithun,
91000 is NOT a good age to overhaul a zen's engine..
they are known to soldier on for 175000 kms with
average care before needing major surgery...
and with a little TLC, a lot more....
__________________
In Somnis Veritas
gotzuk is online now   Reply With Quote
Old 18th October 2007, 01:08   #5 (permalink)
hellspawn's Avatar
my zen has clocked 86k kms and is still in good running condition.i suggest you get a second opinion from another m.a.s.s.
__________________
Kenwood KDC-X8529,IPaul 4.300,Image Dynamics CTX65cs,IDQ15
If you try,and succeed at first,
try not to look astonished.
hellspawn is offline   Reply With Quote
Old 18th October 2007, 12:28   #6 (permalink)
Super-Admin
It really depends on how the car has been maintained. If it was serviced as per the recommended schedule (including oil changes), then yes....the engine should be healthy enough for 1.5 lakh kms.
But it really is not uncommon for a Zen to require an overhaul around a lac if the upkeep hasnt been that regular.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 18th October 2007, 12:37   #7 (permalink)
Team-BHP Moderator
theMAG's Avatar
Any thoughts on leaving it at a Maruti authorized service center - preferably the sales-service types of RNS or Mandovi ?
__________________
If you lose your temper, you’ve lost the argument
Old 18th October 2007, 15:49   #8 (permalink)
nitrous's Avatar
First check compression in a knowledgeable garage.
Then,decide on how to go about it.
__________________
Maruti - Everyone comes home with rattles!
Old 19th October 2007, 15:41   #9 (permalink)
thanks for the replies guys...here's the update
...i showed it to surakshaa MASS in hosur road they said the alternator bearings are gone due to water entering due to which the sound is loud plus the would also check the fan belts they also recommended a engine flush for decarbing the engine as he said there is a lot of sludge in the engine..I will get it done next week. hopefully after this i get back my ever smooth Zen Engine performance!!!
Thread Tools
zen di engine head overhaul zenopio Technical Stuff 5 22nd February 2008 13:56
performance engine for zen wanted naturaldisaster Modifications & Accessories 27 3rd July 2007 04:58
Zen - Running in (engine noise) gchandra Technical Stuff 25 7th January 2007 16:56
S-Zen?(Swift engine in a Zen) raghuram.cg Modifications & Accessories 4 26th November 2006 17:24
Alto with Zen Engine? dsinz The Indian Car Scene!! 16 13th October 2006 06:29
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
