Old 13th October 2008, 21:55   #151
abhinav.gupta88's Avatar
Thanked: 310 Times
As far as i know , top speed should be better with low profile tyres.
Can someone confirm this.
And my personal opinion says 15" stock alloys painted purple definitely look better than the previous ones
Old 13th October 2008, 22:07   #152
karan561's Avatar
Thanked: 10,561 Times
Well , its the width which decreases TOP SPEED , i.e. 225/45 R17 setup decreased the Top Speed , where as the 205/60 R15 did not hamper the top speed . .
And about the Purple painted ALLOYs , theres a small little surprise coming up . . check out this thread soon . . have an update in the alloys . .
karan561 is online now   Reply With Quote
Old 13th October 2008, 23:03   #153
Thanked: 310 Times
If the width decreases the top speed , why is it that the lambos and others have tyres
like 235/35ZR19 in the front and 295/30ZR19 ( in the Gallardo)
Wont the width in this case decrease the top speed?
EDIT : Waiting for the update on the alloys
Old 13th October 2008, 23:03   #154
iraghava's Avatar
Thanked: 156 Times
Wider tyres especially the increased rim size means higher drag due to the heavier tyres/wheels & of course the added load due to the increased contact patch.
IMO 225/45 R17 is too wide for a stock Corolla.
Because they have about 500 bhp+ whereas a stock Corolla has 125 bhp. They can get away by using wider tyres since they have the power to use them and also since they're high performance cars, they need the wide rubber to put the power down effectively & also maintain firm grip on the road while takeing turns/curves at insane speeds.
Two different car, two difference purposes. I don't think a comparison between them is correct Abhinav.
Old 14th October 2008, 11:48   #155
im_srini's Avatar
Thanked: 399 Times
Hi guys, very interesting observation Karan & iRaghava...
These are not comprehensive or rigorous, but, by switching to a taller tire (~7.3 mm), the torque arm has increased in length, but not by much. The gearing at the contact patch decreases from 3.189 to 3.152, so the drop is very very small (~1.2%).
Coming to aero drag, the section width has increased by 20 mm due to the tire change. Assuming a ground clearance of 16 mm, & even allowing for a Cd of 1.0 (way too high as the tire curves away), the aerodynamic force due to the increased width alone, at a speed of 200 Kmph, is around 1.1 N only.
If you ask me, I don't think increased aero drag due to the wider tires alone can explain the relatively large drop (> 5%) seen in the top speed. The tune of the car could've decreased or other mods (like a body-kit) could be at fault. The rolling resistance could've increased too (although I think stiffer tires have lower rolling resistance values). Other things to consider - the tire pressures could've been lower, or the tread could've been thicker !
im_srini is offline   Reply With Quote
Old 14th October 2008, 16:18   #156
autopsyche's Avatar
Thanked: 15 Times
The drop is definitely due to 2 reasons
1. increased rolling road friction because of additional width
2. increase in unsprung weight on the drivetrain
These two factors are very much capable of reducing top speed by upto 10%
autopsyche is offline   Reply With Quote
Old 14th October 2008, 19:50   #157
abhik's Avatar
Bro if you are looking at the Lambo then do keep in mind you are looking at a RWD most importantly and wider tyres to harness the insane amount of BHP and put it on the road. Goes for almost all RWDs with lots of power. Wider rear to put down the power, smaller front tyres to aid handling.
And rightly said by Ishaan the cars being compared are not right as each of them are in their own leagueand made/built for separate purposes.
abhik is offline   Reply With Quote
Old 14th October 2008, 23:38   #158
karan561's Avatar
And guys the ALLOYS are TAIWANESE make , so not the best quality racing alloys which are a lot HEAVIER so that is also one of the major factors for the top speed not goin above 200 .
Another experience i want to share is that with the Stock Setup , and engine under stock conditions just about did a 200 , but when added with the performance mods and checked the top speed (after getting back to 15"s) it did a 210 , where as the top SPEED of A COROLLA is 196 km/h (taking the speedo errors into picture) .
Old 15th October 2008, 22:46   #159
karan561's Avatar
Well , have painted the 17" Chrome Alloys ( minus the spinners ) Purple , and have left the circumfrence CHROME .
They are looking HOT .
Will upload the pic. soon. cheers:
Old 15th October 2008, 22:53   #160
abhik's Avatar
That should be a looker! So switching back to 17s?
Waiting for the pics!
Old 15th October 2008, 23:05   #161
karan561's Avatar
Already have . . will upload the pics by tomorrow .
Old 16th October 2008, 22:27   #162
karan561's Avatar
Sorry for the poor quality image .(was taken when the car was going for wheel alignment and balancing)
Will post better pics. soon .
So is it looking better now ?
Old 16th October 2008, 23:29   #163
Thanked: 310 Times
Thanks for the info guys
For once i was made to think that Super cars will run faster if on less wider tyres.
@ Ishan
I wasn't actually comparing the rides ( just wanted to know why the sports car have wider tyres when wider tyres lower the speed ( like in karan's corolla)
@ karan
Please put a clearer picture of the alloy
The chrome finishing you have left is looking just too amazing.
nice thought
cheers:
Abhinav
Old 16th October 2008, 23:45   #164
faithless_1984's Avatar
Thanked: 217 Times
Yes ,much better.!
Looking forward to some better quality pics now.
faithless_1984 is offline   Reply With Quote
Old 17th October 2008, 22:21   #165
karan561's Avatar
Originally Posted by faithless_1984 View Post
Yes ,much better.!
Thanks , Really busy with college right now , Will post better quality pics. soon .
Modded Front Grill for the Honda City? Bopanna19 Modifications & Accessories 13 28th February 2013 11:05
Modded Toyota Corolla Altis- Projector CCFL Angel Eyes, Spoilers, Side Visor jocreative Modifications & Accessories 108 8th July 2012 12:33
How to make Angel Eyes nikibusa Technical Stuff 33 3rd February 2009 00:39
My lancer with angel eyes added anku Modifications & Accessories 24 3rd July 2008 02:06
Anyone Has Round Heal Lights(Angel Eyes) Like the BMW For Honda City 1.5 vtec? ollie Modifications & Accessories 26 7th July 2006 17:55
