Old 29th June 2008, 18:02   #46
Awaiting Email Confirmation
Thanked: 20 Times
thanks for the link 1self.
hope you're not expecting too much from it. most reviews say it doesnt increase the power on fuel injected cars, because the air fuel mix has already taken place before it reaches the throttle body.
but the insulating effect will help a bit methinks. will wait for your review, because parts like this one are going to be available for the DDiS. was planning to experiment.
Old 30th June 2008, 00:43   #47
AbhiJ's Avatar
Thanked: 531 Times
Originally Posted by shrivz View Post
I think a high heat resistant silicon rubber gasket will do the same job as the above mentioned phenolic intake spacer aka gasket at a fraction of the cost!
The maximum a Silicone Rubber Gasket will stand is 250 degree Celsius.
Will this be enough temperature resistance for this application?
AbhiJ is offline   Reply With Quote
Old 30th June 2008, 00:59   #48
shrivz's Avatar
Thanked: 92 Times
Originally Posted by OCi Hi-Temp RTV Silicone Gasket maker
OCI Red Hi-Temp 100% RTV Silicone makes reliable "formed-in-place" gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Hence ideal for use as replacement for gaskets, seals, gaskets dressing, cork, felt, paper, rubber and asbestos gaskets. It is permanently flexible and stable at temperatures from -80F to 650F (-62C to 343C). It is also highly resistant to oil, water, weather, vibration and grease.
here's the technical datasheet: http://www.ociamericas.com/images/ht_temp_rtv_tds.pdf
This gasket maker costs roughly Rs. 125/- for an 85g tube.
It is ideal for use on exhaust manifolds, timing chain covers and most hi-temp applications.
shrivz is offline   Reply With Quote
Old 30th June 2008, 06:08   #49
1self's Avatar
Thanked: 270 Times
Shrivz,
In the linky you provided, the hi-temp applivation is for a range of -60 to 343 degrees celcius. Temperatures next to the combustion chamber, even on the intake side will be more i believe.
1self is offline   Reply With Quote
Old 1st July 2008, 20:07   #50
1self's Avatar
Thanked: 270 Times
Default Update: Intake Spacer Installed
Hi Guys!
Just completed installing the Phenolic Intake Spacer. Took the Hyundai A.S.S. guys a total of 3 hrs to install. Quite a labour intensive job!
Went for an all out 2nd gear drive. Drove hard for 15 mins. Then opened the hood...the IM is a little warm, unlike before when one could'nt even touch the damn thing!
Mission is a success!
Old 1st July 2008, 20:24   #51
Ford Rocam's Avatar
Thanked: 16 Times
Where's the intake air temperature sensor located in an elantra? if any?
Ford Rocam is offline   Reply With Quote
Old 1st July 2008, 20:25   #52
Thanked: 20 Times
thats good,congrats!
but what has it done for the throttle response?
Old 1st July 2008, 22:32   #53
1self's Avatar
Thanked: 270 Times
On the IM, just behind the throttle body.
Old 1st July 2008, 22:36   #54
1self's Avatar
Thanked: 270 Times
Slightly improved (Mind you it is already rather good due to the CAI, Sparks, FFE etc). I believe the best improvement in results will come on driving in hot weather & pushing hard.
Old 26th January 2009, 08:07   #55
1self's Avatar
Thanked: 270 Times
Exclamation Under Drive Pulleys!
Hey Guys!
When i visited South Korea, i bought these for my Elantra:
1. Adjustable Cam Gear
2. Under drive Crank pulley
3. Under drive power-steering pulley
4. Under drive alternator pulley
5. NOLOGY plug wires.
I advanced my cam timing by 5 degrees.
Old 26th January 2009, 08:13   #56
1self's Avatar
Thanked: 270 Times
The results are rather spectacular! My car reaches the rev-cut-off a LOT faster than before. My low low rpm torque is increase by a fair margin. Switching on the A/C has does now slow down the car performance by much...almost as if it were off.
All in all a very much improved performance!
Old 26th January 2009, 12:03   #57
Gangsta's Avatar
gr8 to hear.. what abt the mileage part?
Gangsta is offline   Reply With Quote Received Infraction
Old 27th January 2009, 05:32   #58
1self's Avatar
Thanked: 270 Times
well, if one drives with a light foot, the mileage is actually INCREASED....due to less throttle inputs as compared to previously.
Old 27th January 2009, 22:36   #59
Gangsta's Avatar
aha! great.. how much/
Old 28th January 2009, 04:44   #60
paras211's Avatar
Thanked: 57 Times
hope you dont have any high end ice that uses a lot of batt power. performance pullys are rumoured to be inefficint in charging the batt
paras211 is offline   Reply With Quote
My Subtle yet Suave Swift - Stage 1 Performance Mods Complete Mi10 Modifications & Accessories 14 3rd May 2010 11:28
ICE for Baleno EDIT: Stage 1 complete streetrage911 In-Car Entertainment 45 31st October 2009 22:43
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
