Old 12th March 2010, 15:15   #91
1self's Avatar
Thanked: 266 Times
Exclamation
Update:
Have just received a torque damper kit custom made for my Elantra.
In the second pic torque damper as attached in another vehicle.
Pics:
1self is offline   Reply With Quote
Old 12th March 2010, 15:40   #92
KSM-Vtec's Avatar
Thanked: 437 Times
long time vivek, we need an update.
KSM-Vtec is offline   Reply With Quote
Old 25th March 2010, 03:02   #93
1self's Avatar
Thanked: 266 Times
Exclamation
Yippee! Got myself a used Apexi S-ITC (Super Ignition Timing Controller), via e-bay! Advanced timing just 3-6 degrees across the rev range. The effect is HUGE! The midrange torque has become MASSIVE!
The Apexi S-ITC is a previous generation controller.
Pics:
1self is offline   (1) Thanks Reply With Quote
Old 25th March 2010, 13:57   #94
KSM-Vtec's Avatar
Thanked: 437 Times
Nice!!!! Congrats!!!!
So whats in store for stage 2??
do you plan to do a dyno now??
Have fun and drive safe...
Old 27th March 2010, 03:57   #95
1self's Avatar
Thanked: 266 Times
Yup! A dyno will be on the cards soon! Stage 2 complete! Still experimenting with the timing!
Old 25th November 2010, 13:13   #96
Thanked: 7 Times
I see that you have done Somender Head Grooves / Grooving in your pictures posted.
Did you shave the head after doing it? Has it made a difference in the performance /mileage?
eapen is offline   Reply With Quote
Old 24th March 2011, 08:18   #97
1self's Avatar
Thanked: 266 Times
Default Re: Elantra Petrol Stage 2 Complete!!!
Sorry for the late reply....yes, i did shave the head a bit (on the Sonata). It has increased the compression ratio very slightly. So there is a bit more power & torque. I do feel the engine is smoother & revs rise more quickly. I can stay in longer in a higher gear now.
Old 24th March 2011, 12:11   #98
pranavt's Avatar
Thanked: 272 Times
No info about the Singh grooves?
Who did the head work?
Old 24th March 2011, 15:29   #99
1self's Avatar
Thanked: 266 Times
Exclamation Re: Elantra Petrol Stage 2 Complete!!!
Pranav....i went all the way from Pune to Mysore JUST to get the whole thing done from Mr. Somender Singh himself. He also did the radiusing of the valves, porting of the intake & exhaust etc. The signature.."sing" in the pic is of the man himself!
Old 24th March 2011, 16:44   #100
Thanked: 3,499 Times
1self, i've always been intrigued by this grooving technique and i've been wondering if the results gained are because of the grooving or because of increasing the compression ratio which is always done alongwith grooving. Your thread made me take a look into Somender Singh's website yet again and there i have found this interesting test result.
SOMENDER-SINGH.com - ARAI Dyno Test
In the test result we can see that after completing the grooving the engine gained a bit of torque but lost on peak power (the IAT is nearly the same for test 1 and 3). Another interesting fact is that the head used for test 3 seems to be different.
Old 25th March 2011, 06:29   #101
1self's Avatar
Thanked: 266 Times
Sankar, one actually LOSES a BIT of compression after grooving, as there is more space in the compression area due to the grooves. The shaving of the head gets it back to original compression.
Old 25th March 2011, 08:41   #102
Yep thats right. But i feel on low compression engines a bump in compression, not as high as to induce knock, would yield a similar result. My exp is limited to motorcycles though.
Old 25th March 2011, 10:03   #103
1self's Avatar
Thanked: 266 Times
Sankar, the whole point of doing the exercise was to give knock resistance when i go FI on the Sonata. People who have tried this on high boost drag cars in the US were amazed with the knock tolerence of gooved engines all else being the same! The engine has some extra power after grooving. Seat of the pants feeling. My car already has 10:1 compression.
Old 27th March 2011, 21:41   #104
Neil.Bhujbal's Avatar
Thanked: 57 Times
Where & who installed the Apexi S-ITC ? You were at tune up plus yesterday in your elentra right ? I never knew u owned a elentra too.
Neil.Bhujbal is offline   Reply With Quote
Old 28th March 2011, 03:44   #105
pranavt's Avatar
Thanked: 272 Times
I hope you won't be using the ignition controller when you go FI. What engine management are you planning on using?
My Subtle yet Suave Swift - Stage 1 Performance Mods Complete Mi10 Modifications & Accessories 14 3rd May 2010 11:28
ICE for Baleno EDIT: Stage 1 complete streetrage911 In-Car Entertainment 45 31st October 2009 22:43
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
