Old 28th March 2011, 06:42   #106
1self's Avatar
Thanked: 270 Times
Default Re: Elantra Petrol Stage 2 Complete!!!
Originally Posted by Neil.Bhujbal View Post
Where & who installed the Apexi S-ITC ? You were at tune up plus yesterday in your elentra right ? I never knew u owned a elentra too.
I got the wiring diagrams & Hyundai A.S.S. installed it! But thats because i know those guys very well on a personal level. Yes i was there there yesterday Neil.
Originally Posted by pranavt View Post
I hope you won't be using the ignition controller when you go FI. What engine management are you planning on using?
I already have another Apexi S-ITC going in The Sonata. I have a DIY "Digital Fuel Adjuster" & DIY "WideBand O2 Sensor". These kits comes rather cheap (try 200$ total for both). One only has to solder them together.
Turbo will be remote mount STS Universal.
I can easily get the job done professionally by any number of tuners....but that would be akin to buying an-already -completed jigsaw puzzle!
1self is offline   Reply With Quote
Old 3rd June 2011, 06:53   #107
1self's Avatar
Thanked: 270 Times
Exclamation Re: Elantra Petrol Stage 2 Complete!!!
Added one more performance part yesterday. It is called an Enricher. It modifies the narrowband o2 sensor signal when the engine is on load (settings user adjustable) & sends a dithering signal (the kind the ecu expects to see when mixtures are stoich).
So, i can enrich mixtures right from idle, without the ecu becoming any wiser & learning it's way around the mod! Cool eh!
Pics!
Old 1st August 2011, 19:51   #108
1self's Avatar
Thanked: 270 Times
More Goodies For My Baby!
19mm roll bar & 4 point H Beam...Now the handling will be even better!!!
1self is offline   (1) Thanks Reply With Quote
Old 2nd August 2011, 03:01   #109
pranavt's Avatar
Thanked: 274 Times
If you can contact any dealer of that company, can you ask/forward my details to him for OHC parts? Last time I asked the parent company, they didn't seem to have anything in stock. Thanks.
Old 7th August 2011, 09:06   #110
1self's Avatar
Thanked: 270 Times
PM'd you. Go to the website.
Old 14th May 2012, 19:41   #111
1self's Avatar
Thanked: 270 Times
Brake Upgrades:
Brake calipers & pads are from the V6 Sonata (OEM). These have bigger pistons & pad surface area than the Elantra ones & are a PERFECT fit.
I had the front and, recently, the rear brake discs also grooved.
The difference between stock & grooved is night & day.
Pics:
1self is offline   (4) Thanks Reply With Quote
Old 15th May 2012, 15:25   #112
abhijitl's Avatar
Thanked: 16 Times
Wow, Brake disks look good. Where did you get them done?
abhijitl is offline   (1) Thanks Reply With Quote
Old 15th May 2012, 15:36   #113
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by 1self View Post
Brake Upgrades:
Pics:
Great job! what brake pads are you using?
Any downside to this mod of grooving the disks?
KSM-Vtec is offline   Reply With Quote
Old 15th May 2012, 15:55   #114
1self's Avatar
Thanked: 270 Times
KSM, I'm using stock pads. No downsides whatsoever. There is no discernable fade even after hard use. Only negative i can think of is that the pads will wear out faster than before, but I'm willing to replace them sooner in exchange for the massive bite. It's awesome!
Old 15th September 2012, 13:49   #115
knightrider_25's Avatar
Is there any advantage in installing a Fuel Pressure Regulator in Elantra Petrol ? (Mods include: ECM remaped from Kiirus Tuning, K&N, Iridium Plug, Cushion Tech Pads in Springs, upgraded S Drives from Yokohama)
Please suggest for the same.
knightrider_25 is offline   Reply With Quote
Old 15th September 2012, 19:51   #116
1self's Avatar
Thanked: 270 Times
In naturally aspirated cars, there is really no requirement for an aftermarket FPR.
The fuel pump can easily supply the required fuel. By raising the fuel pressure, actually less volume of fuel gets in the cylinders because the fuel pump is made to work harder to supply the higher pressure.
In simply analogy, if you take a garden hose & cap one end with your thumb, the pressure of the water is increased, but less volume of water is discharged.
Now, manufacturers increase of the volume of fuel being pumped at higher rpm's to protect & cool the engine. If you run an aftermarker FPR, sustained high rpm's will be bad for your engine due to the reduced fuel flow.
You might gain some power though due to better air-fuel-ratios at those rpm's. Hyundai's are known to run rather rich at higher rpm's (above 5000).
Old 2nd July 2013, 21:19   #117
LP640's Avatar
Thanked: 41 Times
Vivek/John, me faced a problem with failed Ignition coils (2 of them). Car started misfiring all of sudden on Pune-Mumbai expressway. Exhaust was getting red hot and power had dropped excessively at low rpm. Showed to a mechanic but he couldn't help. Drove to Pune in the same condition. No other problems. Engine temp was normal and car could do 80-100kmph.
My question is why did the coils fail all of a sudden? Any idea? I did replace all spark plugs a few months back. I am also running Kirrus remap on stock air filter and exhaust.
LP640 is offline   Reply With Quote
Old 2nd July 2013, 21:27   #118
1self's Avatar
Thanked: 270 Times
LP640,
Have you confirmed it was ignition related? There are only 2 ignition coils on the Elantra as it has a waste spark ignition system. Coils do fail due to heat & age. It's resistance increases & eventually cannot conduct electricity.
Old 18th October 2017, 11:11   #119
1self's Avatar
Thanked: 270 Times
Some new footwear for my baby & a high friction clutch kit.
Elantra Petrol Stage 2 Complete!!!-22181175_10210957739559293_7445758291906005147_o.jpg
1self is offline   (2) Thanks Reply With Quote
Old 18th October 2017, 14:47   #120
Thanked: 35 Times
Whats your opinion about using a Wideband 02 sensor, as the only mod on a stock car. Any real benefits?
I have a Hyundai Accent.
sinhead is offline   Reply With Quote
My Subtle yet Suave Swift - Stage 1 Performance Mods Complete Mi10 Modifications & Accessories 14 3rd May 2010 11:28
ICE for Baleno EDIT: Stage 1 complete streetrage911 In-Car Entertainment 45 31st October 2009 22:43
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
