Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 12th November 2007, 06:23   #1 (permalink)
Default Gypsy hard top removal a DIY?
A search brought up no hits, so please help.
Folks, just picked up a 93 gypsy with 70k KMs on the clock. Its a real piece of **** this car, drinks a quart of oil every 200 KMs and rides like one too. But its got character and I intend to piddle around with it for a while.
Now, its got a hard top which is in very good condition, but this tiny 1.0L motor cannot haul all the bulk. So I intend to strip it down and turn it into a pick up truck - hard top, back seats will be removed and a bed cover will be fabricated. Just curious if the hard top can be removed at home or is it welded to the frame? Poked around and found some bolts on the top and sides near the front passenger cabin but nothing else. The inside roof is carpeted so I cant explore more without ripping out some carpeting.
Please advice, thanks.
xxaarraa is offline   Reply With Quote
Old 12th November 2007, 08:12   #2 (permalink)
It can be removed but you would need the help of at least one other person. If it a factory fitted top it should not take you more than 20 minutes to remove it. Spray some wd40 on all the bolts before you start.
The hard top is not very heavy anyway and you probably will not notice any difference. However the looks would dramatically change!
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 12th November 2007, 08:19   #3 (permalink)
The original factory fitted hard top is made of fibre. It is screwed at various points to the body - over the windshield, the doors, B pillar & along the bed. Also be careful when removing the rear door the fitting is a bit tricky.
__________________
Rmonie
_____________________________________________
Adventure 1.6
Gypsy King 1.3 Carb
Octavia 1.9
rmonie is offline   Reply With Quote
Old 12th November 2007, 08:41   #4 (permalink)
govigov's Avatar
brilliant choice that you went in for the gypsy, like you said the car has got character. you are going to make it to a soft top, thats good. just out of cusiosity how much did you pay for your 93 gypsy?
__________________
______
o/_______\o
(OO=00=OO)
govigov is offline   Reply With Quote
Old 12th November 2007, 10:10   #5 (permalink)
Thank you jyobeb and emonie. Its good to know it can be done at home, I was afraid it was some sort of weld job that had to be cut apart.
Can you provide any direction on where to look for the bolts? I would like to leave the fiber over the driver/passenger cabin intact and remove the rest. I see bolts at the top and to the side, but nothing along the bed wall or at the back. I am removing the back seat and the pair of kid seats also, and they seem pretty straightforward. Thanks for your insight.
I paid 105 for the 93 Gypsy and spent about 15k getting it back in good mechanical shape.
__________________
93 Gypsy
03 BMW F650 CS
07 C220 CDI
03 Santro
96 M800
Previously..
00 E55 AMG
05 RSX Type-S
95 Jetta III
94 Escort
Old 13th November 2007, 04:57   #6 (permalink)
Ali
You paid 105 for a 93 gypsy.If im not wrong its 1,05,000.Well i guess its way too much.A friend of mind sold his gyppy 95 model with Alloys and 75k on the Odo for 70,000.
__________________
Effort is Important,But where to make one makes all the DIFFERNCE!!!
Ali is offline   Reply With Quote
Old 13th November 2007, 10:46   #7 (permalink)
I look at mine & send you the exact locations of the screws.
The back seat bolts may be rusted solid though. You may have to cut them with a gas cutter.
__________________
Rmonie
Adventure 1.6
Gypsy King 1.3 Carb
Octavia 1.9
Old 13th November 2007, 12:08   #8 (permalink)
gd1418's Avatar
Ali, I'm sure it must be a typo. What he would have meant was 10.5K.
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 13th November 2007, 19:13   #9 (permalink)
Team-BHP Moderator
Mpower's Avatar
Gypsy pickup modification is common in the rally world. Some readymade kits should be already available and save you the headache of re-inventing the wheel.
__________________
The difference between the men and the boys....................is the speed of their toys.
Mpower is online now   Reply With Quote
Old 29th November 2007, 19:21   #10 (permalink)
khan_sultan's Avatar
I have a MPFI King, and it had hard top. I got it removed under 30 minutes. no welding is present between the body and the hard top. Just remove the bolts and you are through.
The bolts are all along the side where the body and hard top meet. If you see the image posted above, you would see the bolt points protiding all along the edge. these are the bolts to be removed.
I must say that the whole look of the Gypsy changes once you remove the hard top and make it either open/half cabin.
I would suggest that you DO NOT keep the old half cabin roof, as it is of sloping type and would not look good.. however, your choice -- just my 2 cents.
khan_sultan is online now   Reply With Quote
Thread Tools
Scratch(writings) removal? herculesksp Modifications & Accessories 49 20th August 2008 14:15
Rattle Removal Buffetfan The Indian Car Scene!! 77 23rd April 2008 23:04
Top Gear 2006 Survey : Fiat zooms into top 10, Honda, Skoda top list. amit The International Automotive Scene 10 8th March 2007 11:31
Soft top for Gypsy Mack Modifications & Accessories 1 31st August 2006 17:49
Caribe Removal karthik247 Gadgets, Computers & Software 13 7th August 2005 08:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
