Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here!
Thread Tools
Old 13th November 2007, 11:41   #1 (permalink)
siddhu_engg24's Avatar
Default Injector and carburettor cleaner for my Swift !
I wanna know everything about Injector and carburettor cleaner ( ICC )for my Swift VXi, including the exact selection criteria for a particular car & the procedure to deploy it in the car.
Thanx,
Siddharth
siddhu_engg24 is offline   Reply With Quote
Old 13th November 2007, 14:33   #2 (permalink)
Absar's Avatar
Welcome to the forum! Do go through the rules of the forum, it does not permit slang style. Full form is only accepted.
Back to your query, I think the Swift isn't carb, it has to be MPFI.
You can find System-G at BP bunks which acts as a injector cleaner too.
It's to be put in a ratio of 1 ml/1 litre in the fuel tank.
cya
A
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 14th November 2007, 16:06   #3 (permalink)
cya
A
firstly that barely qualifies as slang ; and since your not a mod give the guy a break !
secondly try giving him some better info
Sid you can get your injectors cleaned on an injector cleaning machine from a garage with a good reputation : should cost 500 rs ish
but if you want to clean your whole fuel system out which is reccomemned every 10 000 km , this is what i would do [ i drive a swift too ]
1 st dump a bottle of sonax fuel system cleaner into a full tank of fuel and nearly finish that tank :
then
engine decarbonization [machine done again ] rs 1500 ish
after that change your fuel filter & spark plugs [ which plugs you use? ]
then flush your oil system i seriously like the OWs engine flush & change your oil [have to after a decarb] ; hope your on mobil 1 5w50 api sm
THEN have your injectors machined cleaned and spray pattern checked as a last step
clean/replace your air filter too : are you on stock?
cheers man
cy
cyneverdie is offline   Reply With Quote
Old 7th November 2008, 16:45   #4 (permalink)
Swifty2008's Avatar
then
cheers man
cy
Hi There,
I'm from Pune and I drive a Swift Petrol. I'm planning to follow the steps that you have mentioned above.
I'm planning to switch to Mobil1. When I contacted exxonmobile, they recommended 0W40 for Swift Petrol. It costs about 4K in Pune. Now you are using 5W50.
1). How much would it cost you for 5W50?
2). Who recommended 5W50?
Thanks.
__________________
Driven by Dreamz......
Swifty2008 is offline   Reply With Quote
Old 7th November 2008, 21:41   #5 (permalink)
SirAlec's Avatar
Originally Posted by siddhu_engg24 View Post
Thanx,
Siddharth
Swift has a carburettor!? thats new.
Dude. do not put any additives and get it cleaned by an expert with proper machine. preferably at MASS.
It will look something like below.
__________________
Still! Living Life a quarter mile at a time.....post being Dad.
Old 10th November 2008, 03:11   #6 (permalink)
Wow thats a flashback, now I use ows 360 as an additive .
The "machine" I mention was what your talking about available at most MASS s - engine decarb'ing machines.Dont know of "experts" present at many of them though.
Swifty: 5w50 costs the same is ie 3300 rs ; It's for more "hard" driving and is fully synthetic.
The 0w40 maybe more lighter giving slightly better hp figures for the swift engine at least the ows somethingW40 definitely feels lighter but with a slight compromise on engine protection.
Old 10th November 2008, 10:14   #7 (permalink)
Swifty2008's Avatar
Hi There, Thanks for the details. I will prefer 5w50 over 0w40 if its good for engine life.
I too have a Swift Petrol.
I guess, OWS 360 is a fuel system cleaner?
How should I use OWS 360?
What's the price of OWS 360?
__________________
Thread Tools
Carburettor mod for Padmini-S1 Intrepid Modifications & Accessories 17 2nd November 2009 12:58
Solex Carburettor for CJ3B desertfox 4x4 Technical 12 3rd July 2009 18:37
Need help and advice for carburettor change in Premier padmini rajnikhil Modifications & Accessories 5 6th January 2008 15:27
Petrol leak from Carburettor - Mach 500 Ketan Technical Stuff 5 12th July 2007 14:19
How does one find a vaccum leak in a carburettor? techn0l0gist Technical Stuff 1 14th January 2007 00:54
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
