Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 24th November 2007, 18:29   #1 (permalink)
Default Help Required For My New Swift Diesel
Hi Guys,
Just baught a vdi this month and after driving it for 3000 kms in around 25 days have noticed some humming noise from the front tyres when at real slow speeds.
The noise comes only when the car is slow and it seems from either wheel bearings or brakes.
Since its almost a brand new car i am very worried , will take it to my dealer on monday.
Please help.
has anyone faced the same problem???
Thanks in advance
autozoniac is offline   Reply With Quote
Old 27th November 2007, 17:58   #2 (permalink)
thirst4torque's Avatar
I had faced similar issues with my vdi(done 5200kms). I got the brake pads cleaned and the wheel allingnment done. It solved the issue.
thirst4torque is offline   Reply With Quote
Old 27th November 2007, 21:31   #3 (permalink)
Jaggu's Avatar
i havent faced it, your vehicle is covered under warranty dont worry and get it checked at the dealership
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 28th November 2007, 08:12   #4 (permalink)
vijit.gangwar's Avatar
I am having the same problem with my LDi, the noise comes while braking at slow speeds....went to MSM Okhla, Delhi. They washed the pads with some kind of liquid, the noise did go away for three says but has again reapeared yesterday evening. Plan to go there once more & give them a piece of my mind.
vijit.gangwar is offline   Reply With Quote
Old 30th November 2007, 12:38   #5 (permalink)
Hi Guys,
Thank you for the response.
Went to my dealer(apra auto gurgaon), according to them its the tyre noise which is there in almost all the swifts.
since my car is just a month old and done 3000kms am worried ........should i complain and ask for tyre change??? or live with it which (according to the dealer) everyone else is doing....
please suggest?????
p.s - since the noise is very similar to wheel bearing noise i insisted my dealer to check the bearings , but due to nonavailability of lift he could not do it and has adviced me to come back.
has anyone else faced a problem with the bearings as well????
Old 3rd December 2007, 10:12   #6 (permalink)
Hi Guys,
Tyre noise if any will occur when you at high speeds on the highway maybe 80km/hr or above. This generally happens when the width of the tyre is less in your case it is 165mm, ideally this car should have 185mm. The tyre is JK, put in a complaint and ask for a service engineer meet you.
But the problem here is the guy may give you a warranty & replace your tyre calculating the wear on a prorata basis. So any ways you will end up getting about Rs 800 /= per tyre.
Which you will get if you walk into any tyre dealership & ask to put broader tyres say 185/70 R14.
So either live the noise if you do not drive on the highway much or walk into any tyre shop & change your tyres to 185mm which is a good fit on the stock rims.
Old 3rd December 2007, 11:30   #7 (permalink)
theMAG's Avatar
I have noticed a "hum" from the wheels of ABS shod Swifts that is absent in their non-ABS variants. Is this the same sound ?
__________________
If you lose your temper, you’ve lost the argument
Old 3rd December 2007, 12:06   #8 (permalink)
The intensity of 'HUMM' should be more in all swifts except for the Zxi
Old 4th December 2007, 11:56   #9 (permalink)
prateek's Avatar
Originally Posted by autozoniac View Post
Hi Guys,
Please help.
Thanks in advance
is your swift equipped with abs.if yes then it can be sound from it.
__________________
live life HUMMER size.
prateek is offline   Reply With Quote
Old 4th December 2007, 12:41   #10 (permalink)
Thanks for the reply.
Vijit: tyre noise in my car comes at low spped as well, infact its more prominent when the car is almost at 10-20 km/hr.
since my car has just done 3500kms do u still think i would only get around 800 rs. per tyre?
what should be the correct trye size(upgraded) if at all i go for new tyres?
since my car doesnt have abs so i guess the noise is either from faulty wheel bearings or tyres....
i have shot a mail to maruti ,they were supposes to get back to me ...still waiting
Originally Posted by vijit.gangwar View Post
Hi Guys,
Old 10th December 2007, 11:55   #11 (permalink)
See I was able to get Rs 800.00 after I had run about 4200 kms...so that should not be a problem...depends on the dealer & your bargaining capabilities.
As for the noise...if it is at low speeds then please get it checked...I see you are also from Delhi, go to either MSM Okhla or Naraina.
Thread Tools
Swift Diesel, Saga continues. The DIESEL experience! Part II Jaggu Long-Term Ownership Reviews 295 7th October 2008 08:58
Help Required: Diesel Engine Eddy Modifications & Accessories 0 26th February 2008 13:53
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 18 13th April 2007 15:02
Diesel car maintenance help required!!! Steeroid SUVs, MUVs & 4x4s 24 5th March 2007 08:28
Minimum km running required for diesel cars sumitdongerkery Technical Stuff 9 14th February 2007 01:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
