Old 25th November 2007, 08:25   #1
croonneck's Avatar
Default MM540 with engine change
these are the pics of the 87' MM540 4WD which we bought primarily for estate use.paid 42k for her including broker charges,renewed insurance etc.
the major work which was carried out on her was the engine change. we went in for a Simpson's S4 which was suggested by my garage guy. the engine is used by the mahindra maxi cabs(model FJ 460 93')its supposed to be a 3330 cc DI engine!! we paid 17k for it and got 5k for the old XDP.
we had to change the mounting positions of the engine little further towards the front.we had the diesel pump serviced,2 new pistons,new rings and seals.
the other big job was the tinkering and painting which costed me another 7.5k.
since its an estate vehicle we haven't made any other modifications.
we had the seats overhauled, changed the shock absorber dampers and we've kept her sprung high, hence there is a quite a bit of body roll, but then again we dont exactly use her for racing.
initially there was a crazy amount of tyre wobbling when i went on deep potholes but then we traced the problem to play in the steering gear.changed the steering rod.
other than that, we did relatively small jobs, changing parts like the brake shoes, new hoses all around, lots of new bearings,new oil filter-things like that.
since this was my first restoration i'm now in love with her, we plan to take out the fibre top next year(makes a fair bit of noise,and looks ugly)
the whole thing came up to 1.1 lacs, its funny how all the small things add up to the amount(no new tyres either)
one important thing was that we had to change the crown pinion ratio from the original 44/9 to a 47/11 because (44,47 i think)the simpsons just couldn't put her foot down with the original(we could only touch 40 kmph that time)so that was another thing.
"croonneck"achaiah
croonneck is offline   Reply With Quote
Old 25th November 2007, 23:37   #2
nitrous's Avatar
Thanked: 285 Times
Love the restoration
Is that the "international" engine u've plonked in?
Old 28th November 2007, 11:10   #3
croonneck's Avatar
quote:"Is that the "international" engine u've plonked in?"
no ,its the engine used by the mahindra mini vans. its a direct injection engine(and a much bigger cc)so no heating required.
Old 29th November 2007, 14:54   #4
Thanked: 655 Times
I think the engine is nomenclatured the P4.
jyobeb is offline   Reply With Quote
Old 29th November 2007, 15:34   #5
nitrous's Avatar
Thanked: 285 Times
This is the Mahindra Van's engine???
Old 30th November 2007, 06:49   #6
croonneck's Avatar
actually what you're talking about is the Perkins P4, mine is supposed to be similiar but its called the simpsons s4.
regards,
achaiah
Old 30th November 2007, 06:52   #7
croonneck's Avatar
the engine i'm using is from one of these kind of vehicles
Old 30th November 2007, 10:22   #8
S@~+#0$#'s Avatar
Thanked: 37 Times
Has the 4WD capability been retained?
S@~+#0$# is offline   Reply With Quote
Old 30th November 2007, 11:08   #9
agspins's Avatar
Thanked: 311 Times
I think this the same engine used in bolero DI...aint it?
agspins is offline   Reply With Quote
Old 30th November 2007, 11:28   #10
nitrous's Avatar
Thanked: 285 Times
Holy smokes!
The long stroke piston of that motor alone mesmerizes me with the thought about its raw torque. Arka had a plan of plonking the van engine and later backed out for reasons of weight distribution.
Heard it weighs a ton
Old 30th November 2007, 13:52   #11
DirtyDan's Avatar
Thanked: 776 Times
Default Here are the motor specs
Here's the Simpson S4 motor specs: 3330cc, 18.5 torque @ 1400rpm
Minibus Fj 740 Ds4 Hiroof,Mahindra & Mahindra,Mahindra Minibus,Minibus Fj 740 Ds4 Hiroof Bus
Old 30th November 2007, 14:03   #12
Spitfire's Avatar
Thanked: 707 Times
Nice job. Did the engine go right in? Or did you make changes to the engine bay. I think the mount points are different too.
Spitfire is offline   Reply With Quote
Old 30th November 2007, 20:27   #13
mech.9n's Avatar
Default finally
finally dude. i have been looking for your thread since last week.looks good in the thread dude,cheers:. i have been privileged enough to be there when your monster was being built
mech.9n is offline   Reply With Quote
Old 1st December 2007, 07:55   #14
croonneck's Avatar
yup we've retained the 4WD. we had the crown-pinion ratio of both, the front and the rear differential changed to the 47/11 from the 44/9.
but the gearbox is still the same 4+1 ,4WD with HS and LS, so retaining the 4WD wasn't a problem.
Old 1st December 2007, 08:13   #15
croonneck's Avatar
thanks a lot man. thats the same site which mech.9n referred me to when we didn't know the exact specs of the engine.
the engine fitted directly onto the existing 540 4+1 gearbox,but yeah , we'd to change the mounting points few cms further towards the front.its much more heavier though.
it was a privilege to have you working on my jeep and being there most of the time when the jeep was being built man
Engine Oil Change - Synthetics or Minerals? sparkglow Technical Stuff 28 30th August 2017 21:44
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
XD3P or DI Turbo Engine upgrade for MM540 4x4addict Modifications & Accessories 7 9th September 2009 20:28
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
