Old 25th November 2007, 09:18   #1
Lotusking's Avatar
Default Need Help! Problem after changing to K&N stock filter in Swift ZXi
Hi all Gurus,
Yesterday I changed the Air filter in my 1 yr, 11000 Km old Swift Zxi to stock K&N filter. At first I was quiet happy with even the slightest of indication of better torque. But after some time I noticed the warning light for the emission Control Unit in the dashboard was continuously on even while running. I read from the manual that the warning light continuously being on might be a problem.
I am confused now. I changed the K&N filter back to the OEM filter. Still the light glows continuously. Please Help!!
Lotusking is offline   Reply With Quote
Old 25th November 2007, 14:05   #2
ram_hyundai's Avatar
Thanked: 48 Times
hey buddy ,
the sensor might have got loose attached to the airfilter pod.just check it out and put back your k&n back.happy ridding,
ram
ram_hyundai is offline   Reply With Quote
Old 25th November 2007, 14:33   #3
Vid6639's Avatar
Thanked: 21,081 Times
Yes check the air flow sensor on the air box. It might be loose. After that if the check engine light remains on, reset the ECU by disconnecting the battery and reconnecting it back again.
Old 25th November 2007, 22:00   #4
theMAG's Avatar
Thanked: 1,574 Times
Originally Posted by Lotusking View Post
Hi all Gurus,
Thats Engine Control Unit. And the airflow sensor is loose.
Old 25th November 2007, 22:13   #5
Jaggu's Avatar
Thanked: 8,692 Times
air map sensor error, and you might require to take the car to dealer if resetting doesn help to remove the error code.
Old 25th November 2007, 22:15   #6
jerish666's Avatar
Dont worry about new stock K&N filter it wont harm your engine.I think the sensor is loose.
jerish666 is offline   Reply With Quote
Old 25th November 2007, 22:52   #7
Thanked: 25 Times
I hope your problem gets solved and btw who changed the air filter for you ?
supercars is offline   Reply With Quote
Old 26th November 2007, 09:39   #8
Lotusking's Avatar
Default Problem solved!
Thanks guys,
I checked and cleaned the sensor in the filter box. just tightened the connections a bit. I replaced the K&N filter. Now the light is not glowing. The guy who fit the filter also had not placed the filter properly.
Anyways thanks much guys for the help. The problem is solved now.
I had also put new sunfilm on the wind screen(Lumar Air 75). This has developed bubbles so I have to go back to the dealer anyways, I will tell him about this.
Old 26th November 2007, 15:09   #9
Thanked: 48 Times
happy drive buddy always its our pleasure to take care of fellow t bhpians
ram
Ikon Fuel Filter : OEM is cheaper than After-Market filter RM2488 Technical Stuff 13 28th June 2012 11:39
Power Steering Problem After Changing Santro Belts nura Technical Stuff 30 3rd August 2010 17:14
Strange problem with Air Filter K&N/Stock on Alto amit_mechengg Technical Stuff 71 18th November 2008 23:34
