Old 12th August 2005, 22:45   #151
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by MustangMan
is it possiable to fit a mpfi dohc setup on the esteem 1.3 carb block?
U mean, fit the cylinder head from the old Swift into the Esteem's cast iron block. May be possible, if the bolt pattern and bore spacing matches. Timing belt also has to lineup properly. Man to ask is Viper.
Old 13th August 2005, 12:13   #152
Rehaan's Avatar
Thanked: 25,043 Times
Originally Posted by v1p3r
Stoppies have occured in cars, it's well known. But then you need almost no weight at the rear, a very short wheelbase, and very sticky rubber. Best known stoppie mobiles are Mini Coopers.
Old 13th August 2005, 15:00   #153
viper's Avatar
Thanked: 9 Times
Hey Mustangman,
Yes it is possible. It is a direct fit.
Viper
viper is offline   Reply With Quote
Old 13th August 2005, 16:50   #154
MustangMan's Avatar
Thanks Viper!
It makes more sense to pick up an old Carb block. and when have the budget, get the DOHC Gti heads etc. rather than buying a hard to find and much more expensive esteem mpfi block.
(for a zen btw)
MustangMan is offline   Reply With Quote
Old 13th August 2005, 16:56   #155
ananthkamath's Avatar
Thanked: 63 Times
Dude, the Esteem block is all-aluminium, as compared to the Zen. So I think it's actually slightly lighter. The same goes for the Honda 1.5 and Vtecs, which are essentially the same block.
I thought the Zen and Esteem block are made from the same casting and are separated at the machining stage? Which is why the Zen has such a short stroke at 61 mm to bring down the displacement to 993 cc...So, the weight difference between the blocks may hardly be 5-6 kgs...due to extra weight of the crankshaft...
Logically speaking, if there's a longer wheelbase with most of the weight at one end of the car, stoppies should be easier than with a short wheelbase..
Ananth
ananthkamath is offline   Reply With Quote
Old 13th August 2005, 16:57   #156
Thanked: 63 Times
Esteems never had cast-iron blocks...G-series are all aluminum, and that includes the Zen...
Ananth
Old 13th August 2005, 20:00   #157
v1p3r's Avatar
Thanked: 27 Times
ananthkamath, you may be right about the similarity in the blocks. I'm not too sure. I know for a fact that the G13 is all-Al. Not too sure about the Zen.
As far as the stoppie goes, I've observed it mainly on short WB cars, like the 2-door in Rehaan's picture. Longer WB would essentially mean more weight, further away from the front. As a percentage of the total weight, the weight to the rear would be larger than in a shorter WB layout, assuming suspension and engine weight to be the same. Please correct me if I am wrong.
Old 13th August 2005, 21:30   #158
Mpower's Avatar
Thanks for the correction guys. I knew the Zen was the first all aluminum engine in India. For some reason I thought the Zen was released after the Esteem.
Old 13th August 2005, 21:45   #159
Thanked: 63 Times
No. Its just the opposite. If you keep everything in its original place, and start moving the rear wheels further backwards, the total proportion of weight on the front will increase...Look at a slingshot dragster. Most of the weight is on the rear wheels..If you start moving the front wheels backwards, the weight on them would increase progressively until the weight distribution is equalised.
Ananth
Old 13th September 2005, 13:33   #160
dadudeonfire's Avatar
can you guys let me know the price of honda 1.3/1.5 engines..and also if it is possible or no to fix/put these engines in to a corsa sail...aand also let me know if it can cause any problem after installing these engines...planning to do this thing after a few months...
dadudeonfire is offline   Reply With Quote
Old 13th September 2005, 14:38   #161
i even wanted to know where can i get these engines...in mumbai...
Old 15th September 2005, 07:07   #162
fieroid's Avatar
Thanked: 287 Times
the ZEN has an all aluminium engine and hence the power-to-weight ratio is amazing...
BTW, I know a 88 model m800 of my TVS R&D mate, which has a carburetted esteem engine which costed him 10k....the car looks ****ty coz of the old looks, but will take the ****-outta an esteem itself!
fieroid is offline   Reply With Quote
Old 15th September 2005, 08:41   #163
Thanked: 127 Times
yeah remember seeing that car at the last years bangalore speedrun.
heavy_foot is offline   Reply With Quote
Old 28th August 2006, 12:38   #164
Default E Zen in Bangalore
Which is the best place to get an Ezen built in Bangalore ? I am interested in getting one ?
autocenter is offline   Reply With Quote
Old 28th August 2006, 14:38   #165
n_aditya's Avatar
Thanked: 2,780 Times
get hold of an esteem engine and a good tuner... i can help you with the engine and you can contact RAC or psycho for plonking the engine.
all the best !!!
Safari GX 4x4 Mineral Red - Booked and waiting and waiting and waiting and waiting... HappyWheels Test-Drives & Initial Ownership Reports 166 9th August 2009 11:54
post all pics of modded zens honda_dude Modifications & Accessories 31 11th September 2008 14:34
Can the Cup Console in Newer Zens be fitted onto the Old ones raghuram.cg Modifications & Accessories 11 17th June 2006 16:40
All those who own e-zens say I superunknown Modifications & Accessories 22 29th January 2006 16:10
Maruti recalls 500 Zens on faulty engine assemblies tabrez02 The Indian Car Scene 0 12th August 2005 11:10
