Old 24th May 2007, 23:42   #226
Godfather's Avatar
Thanked: 65 Times
Originally Posted by WagonRkid View Post
What about WagonR ? Can you fit a 1298cc esteem engine in it?
The wagon R used to come with a 1.1L engine.. i guess there should be no problems considering that there are Alto's running with the 1.3 Twin cams now.
Godfather
Godfather is offline   Reply With Quote
Old 10th June 2007, 15:18   #227
Gtea's Avatar
Hey Guys,
I was wondering, what engine would be the best compromise between power and balance (handling).
What I mean is that, will the bigger engines like the Baleno's be too heavy at the front?
If the car was not going to be used for staight line drags but on mountaineous twisty roads???
Any inputs.
B.T.W. Is it possible to get a 1.3 twin cam MPFI HEAD??
Gtea is offline   Reply With Quote
Old 10th June 2007, 15:34   #228
Godfather's Avatar
Thanked: 65 Times
HI Gtea.. which car is this for??
Godfather
Old 10th June 2007, 15:54   #229
binz's Avatar
Thanked: 412 Times
Godfather
Post count maare
Obviously for a zen naa..
Old 10th June 2007, 15:55   #230
Gtea's Avatar
The zen, this is the e, b, - zen thread after all.
Old 10th June 2007, 21:01   #231
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
You can get the 1.3L twin cam head. But getting the ECU and the wiring harness is the problem. From what I have seen most of them run carbs on this engine.
Old 30th June 2007, 02:14   #232
Gtea's Avatar
I don't know about the wiring but.... Won't a Standalone work as well as an ECU? Or is the ECU needed too?
I've read in the Forum somewhere that the GTi head can handle more stress levels like if going for FI and availability of aftermarket performance parts.
Old 30th June 2007, 02:20   #233
Thanked: 35 Times
As the name refers standalone does the work alone. Doesn't need the OE ECU. Yes, the GT internals are stronger and availability of performance parts are a plenty. Infact I know someone who has two GT engines in excellent condition for sale.
Old 30th June 2007, 02:55   #234
Gtea's Avatar
How much Bhp does the Gti engine produce in stock form?
Any complications in servicing a DOHC over SOHC?
Will the Zen gearbox, clutch be able to handle the GTi engine? Or will they be needed to be replaced with stonger (better) ones?
Old 30th June 2007, 03:01   #235
v1p3r's Avatar
Thanked: 27 Times
100 bhp. Not much in terms of complications. You can use the Esteem box etc.
Old 30th June 2007, 03:19   #236
IronWolf's Avatar
Thanked: 36 Times
Since we are on topic of eZens.. not trying to get an infraction here however... cousin is selling his. Its a Esteem engine running on carbs.
Like I said in another post.. can take on a stock baleno with ease.
another friend tried this GTi engine from bangkok on his Alto and he had issues with power steering and engine chugging at times. Dont ask me who the tuner was .. someone in jayanagar, blr.
IronWolf is offline   Reply With Quote
Old 30th June 2007, 03:41   #237
Gtea's Avatar
Is the Gti engine more sensitive to change in quality of fuel?
Taking quality of fuel into consideration, will Bhp decrease?
Will we need to change the driveshaft?
Is LSD possible on a Zen? (LSD = Limited slip differential) again.
Old 30th June 2007, 06:40   #238
Thanked: 35 Times
No the engine is not sensitive to fuel, I mean all engines are. But the GT engine will work on 87Oct as well, depends on whether you are bumping up the CR or not. No the stock zen driveshafts can handle it. And no, I am yet to see anyone use a LSD on the zen.
Old 11th December 2007, 16:43   #239
jkdas's Avatar
Thanked: 1,436 Times
http://www.team-bhp.com/forum/282552-post167.html
can someone re-quote the above post as its a bit old. And what if I am to go ahead with carb instead of mpfi and 1.3l still costs 50k?
Old 11th December 2007, 21:19   #240
pawan's Avatar
mpfi is some 10 k cheaper than what was qouted with wiring and ecu to.
pawan is offline   Reply With Quote
Safari GX 4x4 Mineral Red - Booked and waiting and waiting and waiting and waiting... HappyWheels Test-Drives & Initial Ownership Reports 166 9th August 2009 11:54
post all pics of modded zens honda_dude Modifications & Accessories 31 11th September 2008 14:34
Can the Cup Console in Newer Zens be fitted onto the Old ones raghuram.cg Modifications & Accessories 11 17th June 2006 16:40
All those who own e-zens say I superunknown Modifications & Accessories 22 29th January 2006 16:10
Maruti recalls 500 Zens on faulty engine assemblies tabrez02 The Indian Car Scene 0 12th August 2005 11:10
