Old 12th December 2007, 12:10   #241
Psycho's Avatar
Thanked: 95 Times
Depends on what cost you get the donor engine and please remeber it is always better to rebuild as you never know how many km the engine has run.
Easier approach:
MPFI zen to MPFI e-zen
carb zen to carb e-zen
The moment you try to mix you could run into trouble.
Old 12th December 2007, 12:20   #242
iceman91's Avatar
Thanked: 22 Times
run into trouble as well as have a bottomless pocket for hidden expenses and patience to get it completely up and runnning
what say mr.psycho??
iceman91 is offline   Reply With Quote
Old 12th December 2007, 19:50   #243
Thanked: 127 Times
any one here on the forum who has managed a reliable carb zen to mpfi e-zen ?
if yes who did the swap? and how many kms has the car seen after the swap ?
heavy_foot is offline   Reply With Quote
Old 12th December 2007, 20:13   #244
pawan's Avatar
well mine is its running super fine no issue.
only issue is fuel lines for me since i am running a high pressure fuel pump so the standard lines are bursting.
there is no other problems for me of any sort releated to the esteem engine or the swap of any sort.
other than that i face problems of traction major problem since if i accelerate a little fast of the signal the tires start squeling since i am running stock tires.
suspension is not very good or mine isnt.
pawan is offline   Reply With Quote
Old 13th December 2007, 11:03   #245
iceman91's Avatar
Thanked: 22 Times
pawan why dont you change the lines?
can buy mpfi lines in the local market or get branded imported lines from abroad
Old 13th December 2007, 11:25   #246
pawan's Avatar
i put some mpfi lines but there were leaks at the ends especially at slow speeds this happened.so i was searching for some better fuel lines but didn't get any.
all the had was the local stuff not sgp.
i should get some better fuel lines by this week.
Old 13th December 2007, 18:57   #247
Psycho's Avatar
Thanked: 95 Times
Pavan have you checked your return line if it blocked even that cause a fuel line burst.
Old 13th December 2007, 20:03   #248
pawan's Avatar
yes keshav did that to i have put a steel line for the return which is slightly larger but lines some how bursts so finally am getting stronger steel braided lines.
Old 13th December 2007, 21:29   #249
Ford Rocam's Avatar
Thanked: 16 Times
Hi pawan,
Have you got Fuel Pressure regulator? & fuel pressure gauge?
have you measured how much the pressure is?
Ford Rocam is offline   Reply With Quote
Old 13th December 2007, 21:50   #250
pawan's Avatar
Originally Posted by Ford Rocam View Post
Hi pawan,
i dont have a guage and fpr.
keeping the fpr as a last resort if the new pipes don't work.
will measure the fuel pressure soon.
Old 13th December 2007, 21:56   #251
Ford Rocam's Avatar
Thanked: 16 Times
Putting a fuel pressure regulator will only increase more pressure from stock. what i wanted to say is have you checked your stock F.P.R?
Old 13th December 2007, 22:02   #252
pawan's Avatar
cant i reduce the fuel pressure with an fpr.?
will check the fuel pressure by tomorrow or with in this week and let you guys know.
Old 13th December 2007, 22:30   #253
Ford Rocam's Avatar
Thanked: 16 Times
you can, if you remove a stock f.p.r & put aftermarket f.p.r you can adjust the pressure.
Old 6th April 2010, 00:23   #254
Thanked: 114 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
mycarhasablower is offline   Reply With Quote Received Infraction
Safari GX 4x4 Mineral Red - Booked and waiting and waiting and waiting and waiting... HappyWheels Test-Drives & Initial Ownership Reports 166 9th August 2009 11:54
post all pics of modded zens honda_dude Modifications & Accessories 31 11th September 2008 14:34
Can the Cup Console in Newer Zens be fitted onto the Old ones raghuram.cg Modifications & Accessories 11 17th June 2006 16:40
All those who own e-zens say I superunknown Modifications & Accessories 22 29th January 2006 16:10
Maruti recalls 500 Zens on faulty engine assemblies tabrez02 The Indian Car Scene 0 12th August 2005 11:10
