Old 27th December 2004, 00:29   #16
speedsatya's Avatar
Thanked: 712 Times
how abt fitting a simple fan into ur grill
so that---
1 when the car is in motion ,the air from outside will be rammed in when the fan turns.
and
2.when standing still,the fan shud not turn but as the hot air is there inside and it tries to go out,so in doing so the fan turns the other way,throwing out the hot air.
also for this u dont need to connct to the battery.
wil thios really work
speedsatya is offline   Reply With Quote
Old 27th December 2004, 01:08   #17
Domnic's Avatar
Hey rice,
as i said in the pm, the blow dryer motor will simply not work... to make a thing like this work you will need about 175+ cfm atleast.. but then you will have problems like, lean burning, as the carb uses a vaccum to draw fuel... you will have to then get an uprated fuel pump, and modify the carb so pressures are restricted to some ports in it.
there are electric superchargers in the market, but those motors need huge amounts of power to work, so they last only for a few seconds till the caps charge.
What kinda budget are you looking at?... you could probably get a used turbo for about 50$ and then work on the piping etc... i would suggest the book "Maximum Boost by Corky Bell" good stuff in it, will help build your own turbo system. It even has info on carb turbo setup's. As setting up a turbo on a carb is prety tedious.
Dom
Domnic is offline   Reply With Quote
Old 27th December 2004, 10:07   #18
Rice_tuner's Avatar
Thanked: 13 Times
hey...thanx Dom...
hey dom, u said sumtime back that u picked up some used turbos for 4K or sumthing?
got any info on that?
Rice_tuner is offline   Reply With Quote
Old 27th December 2004, 10:21   #19
Domnic's Avatar
HI,
Yes i have 2 turbo's with me. One a C class diesel turbo. And one a Nissan Watercooled turbo.
Dom
Old 28th December 2004, 10:09   #20
Rice_tuner's Avatar
Thanked: 13 Times
thanx dom...plz p.m me with more details..
cheers,
Kenwood AMP/ICE advice plz plz cuteavaya In-Car Entertainment 9 10th January 2007 11:52
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
What wud UR garage look like if U wer the Ambanis? _Crazi4Speed_ Shifting gears 1 21st July 2004 00:33
Which is the ONE car that you wud buy?? v12 The International Automotive Scene 36 30th May 2004 13:10
what wud u choose normally_crazy The Indian Car Scene 25 30th April 2004 13:58
