Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 18th December 2007, 16:51   #31 (permalink)
DocG's Avatar
well if ur spending so much money getting the turbo done, then why keep stock internals? change them to forged, and well keep the boost high, and milk all the power out of it...that's what i'm planning
50% boost in power is too less for the amount of money i'm blowing
__________________
______
o/_______\o
(OO=00=OO)
0=--------=0
E30 POWER
DocG is offline   Reply With Quote
Old 18th December 2007, 18:52   #32 (permalink)
v1p3r's Avatar
Originally Posted by binz View Post
Oh c'mon How long would stock internals hold up 1bar ?! How would this kind of setup ever be reliable?
Not sure about tuning.
Originally Posted by iceman91 View Post
agree with Binz stock internals wont "last long" at 1 bar..7-8 psi yes but more no way will it last
Don't wish to argue this. Amit, I'm sure you will be meeting him on Saturday, ask him yourself.
__________________
Singh is king?! He's a bloody baadshah!
v1p3r is online now   Reply With Quote
Old 18th December 2007, 19:15   #33 (permalink)
pawan's Avatar
from what i have read/heard baleno internals can take a lot more except the rods.the pistons and cranks can handle a lot more.they have to be shot peened.
also a bit ot: the worlds fastest swift g13b twin cam is running on stock internals.some 9.91 1/4 mile.
__________________
EZEN for sale.
pawan is offline   Reply With Quote
Old 18th December 2007, 20:09   #34 (permalink)
neo_trace's Avatar
i m driving TURBO CHARGED baleno sinc 2 yrs... viper performance tunned to 6psi with Lpg direct injection programeble ecm (tunned by Lovato italy)and car made successfully 45000kms
got my clutch replaced ..turbo eat that
neo_trace is offline   Reply With Quote
Old 18th December 2007, 20:19   #35 (permalink)
iraghava's Avatar
Wow.....turbo hungry!!
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 18th December 2007, 20:21   #36 (permalink)
Infractions: 0/1 (4)
just turboing by 1.3 petrol swift running 8psi. piper cams uprated clutch, internals, 2pot brake upgrade and lots lots more
gemballa is offline   Reply With Quote
Old 18th December 2007, 22:48   #37 (permalink)
thanks for finally speaking in this topic jitu,always learn something new from your posts,besides that fahad sheikh of team fs is running a 1.3l sohc head from a g13b and the bottom half from the g15b,he was running a na setup earlier,currently he's working on lowering the compression and going the turbo route,a little off topic but i wanted to understand this from you jitu practically a g13b head with g15b bottom itself would be a high compression setup correct,im saying in stock form..?
__________________
oVaBoosT - Performance Unleashed...!!
dragger is offline   Reply With Quote
Old 19th December 2007, 00:47   #38 (permalink)
ananthkamath's Avatar
Originally Posted by Ford Rocam View Post
There will be a huge difference between a T25 & GT30 Turbo running at 8psi & 15psi respectively. So according to me "PSi" is irrelevant term.
Can you please explain why that is so?
__________________
Miata Turbo Is GO!!
ananthkamath is offline   Reply With Quote
Old 19th December 2007, 05:31   #39 (permalink)
Originally Posted by DocG View Post
Loves to make cars fly huh...guess he and I will get along just fine...
And thanks for the info guys...sounds like he's a good guy to talk to about my project...
buddy if i were you i would speak to 3 people
viper
fahad
KS too
KS has a dyno
therefor you can test his claims for yourself , i presume.
he definately sounds tight
KS Motorsport...>>>
cyneverdie is offline   Reply With Quote
Old 19th December 2007, 07:36   #40 (permalink)
DocG's Avatar
well even though KS has a dyno...he's best at tuning Hondas, Lancers n Esteems...most experience with those sort of cars...One has to find the tuner who knows their car inside out, or if not that, then one who has worked on similar cars..no doubt all of them are capable
Besides a dyno run is what 3000 rupees, that's not much when u wanna TC n mod ur ride in the engine department...
Just my 2 paise
__________________
______
o/_______\o
(OO=00=OO)
0=--------=0
E30 POWER
Old 19th December 2007, 07:53   #41 (permalink)
iceman91's Avatar
v1p3r: looking forward to it
Ford Rocam:
cfm vs. psi. a larger turbo can flow more air. but at 4psi there probably isnt much in the way of power differences.
cfm is actual flow, or amount of air coming out of the turbo
boost is a specific amount of measurement of compression that is occouring inside the piping/engine
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 19th December 2007, 18:09   #42 (permalink)
crazydiablo's Avatar
It largely depends on what size turbo you using on the setup & the size of compressor & turbine housing,exhaust turbo manifold,downpipe. There will be a huge difference between a T25 & GT30 Turbo running at 8psi & 15psi respectively. So according to me "PSi" is irrelevant term.
As a rule of thumb stock engines (depending upon C.R) can withstand 50% power increase on stock internals if Tuning is precise & detonation is avoided.
Correct me if I am wroing. Irrespective of turbo Boost pressure is boost pressure. The way these two turbos generate 8 psi or 15 psi will be different. But if stock can hold only Xpsi it will hold only Xpsi irrespecitive of turbo.
50% power increase approximately equates to 7psi boost (assuming all other factor to be stock).
crazydiablo is offline   Reply With Quote
Old 19th December 2007, 21:54   #43 (permalink)
redeye's Avatar
guys just curious how much would a turbo setup cost for a lancer???
__________________
Faster than a speeding ticket.
redeye is offline   Reply With Quote
Old 19th December 2007, 22:02   #44 (permalink)
binz's Avatar
What kind of output would you be looking at?
__________________
HAhaha
Old 19th December 2007, 22:08   #45 (permalink)
v1p3r's Avatar
Depends on power levels, I should think.
__________________
Thread Tools
ARTICLE: Points to consider before TURBO-Charging your car Psycho On modifying a car 55 2nd April 2008 09:15
Better car for turbo charging - which?? Ricky_63 Modifications & Accessories 97 10th August 2007 12:49
Turbo-charging a Honda Accord V6? accord masters Modifications & Accessories 13 22nd September 2006 23:37
Turbo charging a Ford ikon 1.6 shazikon Modifications & Accessories 50 18th September 2005 11:10
turbo charging snoopy41 Technical Stuff 48 10th September 2004 12:16
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
