Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 18th December 2007, 10:44   #1 (permalink)
Question Mounting speakers on Boot tray.. good or bad for tray??
Hi Guys,
In the last week i decided to ICE up my new Getz.
And one of my friend(who works with maruti) told me that Oval shape seakers give better output than round speakers .And after listening to both I definetly liked out put of oval speakers.
Now problem is if I have to fit Oval shaped speakers i have to fit them on my boot tary.One of my other friend told me that fitting it on boot ttray damages the tray. IS that true?if anyone who has mounted oval shaped speakers on boot tray can help me.
Thanks in advance..
varunghatge is offline   Reply With Quote
Old 18th December 2007, 10:55   #2 (permalink)
RufRoc's Avatar
As long as the parcel shelf is of quality good enough to hold the weight of the speakers and as long as it fits tight to ensure there is no ratttling, I don't see why it would be a problem.
__________________
Blessed are those who can laugh at themselves coz they'll never cease to be amused.
RufRoc is offline   Reply With Quote
Old 18th December 2007, 11:00   #3 (permalink)
hydrashok's Avatar
@varun, fitting them on the OE tray would not be a good idea. It will not be stiff and strong enough to hold the 6x9s. And it will rattle like mad when you go over pot-holes.
You'll need to get an MDF tray (will be available with your installer) and mount them on the MDF tray. If the MDF tray is fitted properly, it will not rattle. If at all it rattles, just buy a bit of A/C insulation foam (available at all upholstery shops), and paste strips/pieces under the tray where it touches the body. That will take care of rattles.
You can keep your OE parcel tray safely without cutting holes in it.
EDIT: This being the ICE section, I can't let you go without pointing out that you should buy front speakers first, and not rear speakers Ideally, you should get components in front. They will cost only 4.5K for the 5.25" comps and 5K for the 6.5" comps (JBL GT5 series). You will be able to fit 6.5" comps in front, with a spacer (not visible from outside). Comps will sound better than a 6x9, and you will get the sound up-front, where it belongs. I'm guessing you don't have front speakers now, and that you drive the car, BTW.
__________________
Coming soon: Balls of STEEL!
Old 18th December 2007, 11:13   #4 (permalink)
PatienceWins's Avatar
I am using MDF tray on my getz and the rattling noise is coming from the side as the plastic clip has become loose with the weight of the MDF tray. Took it to Hyundai and the only resolution is to remove the MDF tray. Hyundai says it is not possible to replace the plastic clip inside the plastic panel on the side.
I am living with the rattling as I love my Alpine SPS 6*9 inch speakers. I will never use MDF tray again. I would recommend getting quality speakers on speaker provisions on the rear door.
PatienceWins is offline   Reply With Quote
Old 18th December 2007, 11:27   #5 (permalink)
I believe the plastic clips became loose with the wire being pulled from inside the plastic panel on the side of the boot. I changed it later by pulling wire through the provision given on the side.
The MDF trays are making the loose plastic clips rattle. If at all you decide to go for MDF tray make sure the wires to the boot are pulled through the provisions given on the side, inside the side compartment (difficult to notice).
Old 18th December 2007, 11:56   #6 (permalink)
I am relctunt to install MDF tray..
basically i just wanted to know ,in the long run, will installation on boot tray make a rattling noise?? if it does, is it possible to install new boot tray in Getz??Can any one throw light on this??Please...
Old 18th December 2007, 12:06   #7 (permalink)
Team-BHP Moderator
Technocrat's Avatar
Does your Getz Has Rear Viper? If not then you can install on the Boot Door as well (Provided Getz has such option unlike Swift). If it allows then put MDF plank on boot door & place your 6X9s there else
Btw if you dont listen to louder levels then first get front comps as this has worked for most of my friends & they dont miss rear speakers at all
__________________
180, 225, 150, ??? -> 159?
Old 18th December 2007, 12:37   #8 (permalink)
hydrashok's Avatar
Originally Posted by Technocrat View Post
... first get front comps as this has worked for most of my friends & they dont miss rear speakers at all
Righto! If you get comps in front first, you'll get decent bass in front, and you can avoid the whole parcel-tray-thing altogether.
And I'd also vote for installing the rear speakers in the rear doors (in the stock provision) when/if you get them. You'll need only 5.25" coaxials in the back, if you get 6.5" components in front.
@PatienceWins, I did see your experience in the other thread. Bad installers and bad post-purchase attitude from the installer will make the experience quite irritating. A good installer can setup a parcel-tray install without issues. Some functionality may be compromised, depending on the car (and the owner will have to take a call on that), but it can be done.
__________________
Old 18th December 2007, 14:20   #9 (permalink)
If you drive alone most of the time, get good quality components and that will do the job. I prefer the sound to be more in the front.
@hydrashok: Yes yaar. The installation guys should be blamed for pulling the wire in the wrong way. If not for the build quality of Getz, the entire thing would have come off.I hate rattling and the only solution now is to remove the MDF tray. If the installation was proper, this issue would not have occured.
Old 18th December 2007, 14:27   #10 (permalink)
mobike008's Avatar
Stock parcel shelfs of most cars are not that great. It is susceptible to rattle easily. Best is to have the mdf tray installed or better as already suggested get a good pair of comps in the front
__________________
[b][i]The nail that sticks out gets hammered !!!
Thread Tools
Wagon R rear speakers tray system udit78 Ask the Gurus 36 11th July 2008 18:09
Getz parcel tray rattling? arunkumar_rec Technical Stuff 5 7th December 2007 07:53
Parcel/Speaker Tray saintsinner DIY - Do it yourself 11 5th December 2007 09:23
Tray Sliding.... Time for fun in FWD cars too!!! karthik247 Shifting gears 21 16th April 2007 01:23
woofer in tray of swift 200mph Ask the Gurus 16 2nd July 2006 00:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
