Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 5th January 2005, 11:56   #1 (permalink)
tabrez02's Avatar
Question AutoGuage Vs AutoMeter
I am planning to buy a tacho for my baleno, please help me the good one as per the performance and price.
__________________
Tabrez
tabrez02 is offline   Reply With Quote
Old 5th January 2005, 12:03   #2 (permalink)
anoops's Avatar
be care as to which model you buy...the baleno has a distributorless ignition systems..so all the autometer models will not function properly. find out from the seller if he has installed it on a baleno before...the DIS model is about 14k.
anoop
__________________
AAKGC- Activist Against Killing a Good Car
anoops is offline   Reply With Quote
Old 5th January 2005, 12:07   #3 (permalink)
speedsatya's Avatar
the baleno already has a tacho .so why do u need another tachometer???????
speedsatya is offline   Reply With Quote
Old 5th January 2005, 12:12   #4 (permalink)
tabrez02's Avatar
I need a tacho with shift light And to enhance my dashboard.
__________________
Tabrez
Old 5th January 2005, 12:24   #5 (permalink)
anoop
can it be fitted on the carb zen??
heavy_foot is online now   Reply With Quote
Old 5th January 2005, 12:27   #6 (permalink)
anoops's Avatar
yep carb cars are no problem..most tachs will work with them.
__________________
Old 5th January 2005, 15:07   #7 (permalink)
bhp
bhp's Avatar
i have a 3" auto gauge rpm meter with shift light on the ikon and it just works fine .
__________________
05 suzi baleno
07 city vtec
08 swift DDIS
Live Life in the Fast Lane "vvvrrrooooommmmmmmm"
bhp is offline   Reply With Quote
Old 11th January 2005, 11:39   #8 (permalink)
yeee_ha's Avatar
what has the carb got to do anyways with the tach? please explain....
yeee_ha is offline   Reply With Quote
Old 11th January 2005, 12:46   #9 (permalink)
anoops's Avatar
its just easier to fix a tach on a carb car rather then the newer mpfi engines which DIS or coil over plug systems...fixing an aftermarket tach on these systems can be tricky unless you know where the OE tach terminal is...visit the tec info section in the autometer web site for more on these systems.
anoop
__________________
Old 11th January 2005, 17:12   #10 (permalink)
Domnic's Avatar
All latest autometers are compliant with our indian DIS systems. Only for the Ford Mustang V8 it has a problem. You will need a tach adapter.
You can even wire it to one coil and set the appropriate pulse.
Dom
Domnic is offline   Reply With Quote
Old 11th January 2005, 22:46   #11 (permalink)
XtremeG's Avatar
i have installed only a shift light in my baleno,it already has a tach in the dash. you can wire it to your orignal rpm meter in the dash. open the instrument cluster and connect the wires in parallel to the stock RPM.
XtremeG is offline   Reply With Quote
Old 12th January 2005, 09:32   #12 (permalink)
Super-Admin
Nice and neat. Wasnt aware of this possibility.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 12th January 2005, 17:17   #13 (permalink)
nitrous's Avatar
how do i fit am autometer tachometer in a ford ikon 1.3 CLXI?? does anyone have any idea??
__________________
The Road less travelled, is less travelled for a reason
Old 13th January 2005, 22:35   #14 (permalink)
hey get the autometer phantom with swift light for starters its a good looking meter which performs pretty well and is not too heavy on your pocket
vengeance is offline   Reply With Quote
Old 13th January 2005, 22:50   #15 (permalink)
how much does it cost..?? and wat are the cheapest available with shift light.??
Thread Tools
Autometer COBALT Air/fuel ratio Meter RAYZ Shifting gears 5 14th August 2007 15:23
Autometer Nexus tachos + gauges chetanhanda Modifications & Accessories 5 11th November 2005 05:41
Autoguage smoke face dial pics viper Shifting gears 1 15th May 2005 17:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
