Old 29th February 2008, 11:24   #91
Smile
What's the mechanic name and his contact number?
Cheers,
Pradeep
pradeepya is offline   Reply With Quote
Old 29th February 2008, 17:18   #92
Thanked: 2,470 Times
Pradeep.
Having trouble with your a/c or what?
I presumed you wanted to get some nice set of wheels for your Car.
Old 11th March 2008, 15:46   #93
Coming back to my car after all the mods and running it for over 25000 kms,
The car seems to be running fine and neat.
Using kbx power brakes on the car, although it brakes better than any 800's around but still its tad bit slacky for a complete halt.
Need to look into the braking aspect as on now .
Some electrical issues cropping up. My Stereo has cultivated a habit of playing ON and Off games.
Need some advice on them?
Old 11th March 2008, 18:05   #94
i have the same issue of stereo on/off it is due to weak alternator.
another thing i want to ask friends i have removed all the things present in my car silencer to improve sound. sound is good and pick up has also increase . are there any harms of doing so,
harry2223 is offline   Reply With Quote
Old 22nd March 2008, 23:50   #95
Yes a weak alternator might be the issue, Thanks harry.
Silencer mod not sure what you've done.
New find:
Use 250 ml engine oil into your fuel tank every full tank fill, this improves engine life and runs so smooth.
Old 24th March 2008, 14:24   #96
Thanked: 37 Times
Hi Kadam
Please check whether this would suit your requirement...Pics of my 800 5S MPFI
Mridul
Still waiting.
Atleast if somebody has done it pls let me know.
Guys want to know 2 things.
1) If any body got pics with neat fog lamps in the front for M-800
2) Arial and square fog lamp at the rear hatch.
keep shooting guys
__________________
KADAM
mridul is offline   Reply With Quote
Old 24th March 2008, 14:27   #97
Thanked: 37 Times
Hi Kadam
Please check whether this suits your requirement...my 800 5S MPFI ..
Mridul
keep shooting guys
Old 24th March 2008, 15:49   #98
thanks Mridul for digging up this thread requirement.
Your 800 looks cool with those wheels and fogs, But confused with those 2 different combination of fog lamp fittings.
I am getting what i intended to do.
Any pics on the rear Square Fog and arial.
Old 24th March 2008, 16:22   #99
Thanked: 37 Times
Hi
The one which is shown first is the current one which I relocated recently since I changed my headlamps to 2007 spec with motorized levellers..the other was prior to the relocation..Incidently I have HID's on the H/L & 100 W H3 as fogs..Just a simple question why would you want an ariel in the back when u have the facility on the RHS roof...rear fogs..U can go for the Hella rectangles...
You can let me know your requirement I can suggest you the brand...
Infact the front fogs would be changed to large size spots to give the RALLYE look...In the process of finding the shells for fitting the beams....
Old 24th March 2008, 16:39   #100
Mridul,
If you look at the pics of my M-800 on the thread, the ariel on the RHS has been removed and flattened with metal.
The rear arial looks real sporty fitted along with the Square Fog(Hella) as you've mentioned.
Thanks, will update new pics once done.
Old 28th March 2008, 23:06   #101
Finally guys my engine is running smooth now completing 25000 kms after overhaul.
I am able to go upto 4200 rpms and the top speed tried as on now is 135 kmph.
Need to time my acceleration sometime later.
Any other 800's close or better pls post.
Old 8th May 2008, 16:46   #102
Default FFE Set-up
Hi all,
I have been experimenting about the Free-Flow-Exhaust set up on my M-800 since 2 yrs. What i see with different setups are not a major difference.
1) Initially started with the end can or the muffler, took out the MGP muffler or the tail pipe used an after market set up
Result- Minor increase in pickup and a bit throaty on top end speeds. But never gave me any great boost.
2) Used a header with the after market tail pipe
Result-The setup never worked properly and never made any difference.
3) Fitted a Free-Flow-End can with the header.
Result- Great race car feel, throaty exhaust, great pick up, great rpms and good top end speeds.Great increase in HorsePower, lot of in-cabin noise
Although the 3rd set up lasted in my car for over 2 yrs and had been performing well,with lot of cabin noise, i started feeling my cars become too noisy and felt the need to silence it..
Performed a new set up
4) Retained the headers, removed the Free-Flow-End can and refitted a new MGP tail pipe.
Result-Car is running very silent, good initial pick up and also good at top ends.
But what i feel is someting strange. Is the complete Free Flow Exhaust just added for Mental Horsepower or does it do some justice with the set-up.
Somehow after my Dads pestering i've gone and taken this step to keep the car silent, but my mind seems to work the other way round.
Is there any different kind of FFE Setup for the M-800 where i can get the 3rd set-up to work with lesser cabin noise.
Old 8th May 2008, 17:02   #103
planet_rocker's Avatar
Thanked: 368 Times
stuff the free flow end can / muffler with lots of glass wool to get the silent effect. although i love the lots-of-in-cabin-noise part. i usually keep all windows opened to enjoy that effect in my padmini - something which i miss in my gtx.
planet_rocker is offline   Reply With Quote
Old 9th May 2008, 20:39   #104
Will that lower my in cabin noise and will i be able to rev as earlier?
With the present set up my mileage has actually increased to approx 18-19 kmpl.
I cant be more happy than this,
But i miss the race car feel.
Old 11th May 2008, 17:54   #105
can u post a short video of exhaust sound .
samybravo is offline   Reply With Quote
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Service for Maruti 800 at Maruti Service Masters f1head Indian Car Dealerships 20 16th May 2010 18:48
K&N for 800 mpfi 5 speed (EDIT: Bigger alloys, FFE and spark plugs) addyrulz01 Modifications & Accessories 7 27th August 2007 17:25
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene 32 13th February 2007 12:57
FFE for sierra ??? samybravo Modifications & Accessories 0 20th January 2007 21:45
