| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #77 (permalink) |
| BHPian | @busa the turbo lag had lessened considerably after the tuning box, and i was expecting a further improvement after the green wind. that has not happened. i read somewhere that at lower RPMs a large amount of air rushing in will lead to a loss of power. is that what's happening? now, the drop in performance is not noticeable easily, and I'm sure my 0-100 timings would have still improved by a good margin. the problem with turbo lag occurs mainly in 2nd gear. this probably due to the large gap in the gear ratios between 1st and 2nd. @busa- stop egging me on about the FFE,its not going to happen ![]() next project- alloys and upsize- but that will be many months down the line. then better discs from tarox then- maybe a bigger intercooler and a heat shield that peter was talking about. and then -suspension mods from gabriel and then-maybe, just maybe-FFE. this is going to take a few years. ![]() and a lot of cash.
__________________ Chrome! Last edited by rippergeo : 29th January 2008 at 19:33. |
| | #78 (permalink) |
| Senior - BHPian | hey ripper no use of FFE if you are looking for sound but maybe it can bridge some gap due to the turbo lag.try it with peter and then decide. ram
__________________ Become MAD SOON and join the MON SOON Drive. one more from me- hey MAN come SOON for the MONSOON drive |
| | #80 (permalink) |
| BHPian | out with the old, in comes the new! my filter(the filthy one) has been given for cleaning and a shiny new one has been temporarily popped in place by peter and his guys. 5000kms of hard running can do that to a filter! [img=http://img227.imageshack.us/img227/4390/10032008533ha2.jpg] By rippergeo
__________________ Chrome! Last edited by rippergeo : 10th March 2008 at 22:20. |
| | #81 (permalink) | |
| BHPian Join Date: Apr 2007 Location: Delhi
| Quote:
![]() Can't see the image ![]()
__________________ Car is no longer a luxury; parking space is. | |
| | #84 (permalink) |
| BHPian | just got back from a night drive through the city, on my way back, it started raining cats and dogs. in front of indus motors at thevara, the road was flooded(maybe 2-3ft of water) This meant i had to splash straight through the flood at the highest possible speed ![]() normally, this kind of idiocy does not cause trouble. but, midway through my late night swim, i realised, my car is not stock, it uses a CAI!!!!! as if on cue, i lost revs, and engine responsiveness. images of a cracked engine block/blown turbo flashed through my head! panic!! downshifted to 1st, the tacho had been hovering at 800-1000rpm in 2nd and was refusing to climb. the downshift seemed to work, the revs climbed and so did my car, i crawled out of the flooded road. the car still refused to rev in 2nd or 3rd for the next 30 secs or so. it was revving in 1st without sputtering. then it just seemed to fix itself. now runs fine. moral of the story- Dont be an idiot! the swift is not an off roader(though i treat it like one)questions for the techies 1.the car's fine now- but have I damaged anything? 2.should I change the position of the CAI from behind the gearbox and turn it upwards and draw air from a bonnet scoop? what are the pros and cons of that? 3.general question-what happens when water enters the air intake during running?
__________________ Chrome! |
| | #85 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| 1: Please get it checked ASAP, though i feel that so much of water hasnt entered, maybe soaked the filter. Still inspect the filter first and then check if water has entered further. 2: This is a problem with CAI, ie once you move away from stock filters. Best is to install a snorkel induction from a place where water doesnt enter. Bonnet point is good, but then again ensure you have a collector and drain point also for rain water, though this will eventually kill the air flow. 3: D I S A S T E R, blown innards!! I think you know the consequence from the way you posted. Bent con rods, cracked pistons etc can happen.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 12th March 2008 at 23:46. |
| | #86 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| Hi Rippergeo, in on of the posts you have mentioned that you have cleaned the Air filter by yourself...it would be useful for me if could you put some instructions (if possible with few pics) on how to clean the air filter. i asked the servicing guys to instruct me during my last service but they scared me saying that its not advisable to do by ourself and i dont believe that... thanks |
| | #87 (permalink) | |
| Quote:
If yes, then follow this: 1) Switch off the car, remove keys (to avoid error codes) 2) Unplug the air flow sensor wire on top of the filter cover, there is a clip which you need to lift before you unplug 3) Remove screws off the air filter cover, 4 if i remember correct 4) Loosen the C clip screw for the hose that connects on top of the air filer cover 5) Lift the cover carefully 6) Remove the air filter 7) Blow pressurized air from inside>out of air filter, vacuum cleaner exhaust will also work. And under light pressure all around it, wipe off the edges 8) Take a moist cloth (NOT wet and dripping) and wipe the inards of the air box and the cover Retrace your way back the steps from 6 to 1, opposite of what you did Enjoy ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #88 (permalink) | |
| BHPian | Quote:
![]() I was planning to put in the CAI the next day, so I felt I could afford to be rough with the stock filter. I had just opened the filter to see what the condition was, and was shocked to find it caked with dirt.I couldnt just leave all that dirt there, so I did what I could under the circumstances and used locally available materials(coconut tree). jaggu's instructions are better than any I could give you. @jaggu- removing and cleaning the stock filter does not need unplugging of the sensor. all you have to do is unscrew the lid(4 screws) take out the filter. the sensor can remain attached, just make sure you don't tug on the wires. have not had the chance to get the car looked at after yesterday's misadventure. just returned from a 450km trip. will show it to peter tomorrow. In case anyone is wondering, No, I didnt drive the swift, I used my brother's endeavour. I may be stupid, but not that stupid.
__________________ Chrome! | |
| | #89 (permalink) |
| Yup you dont need to remove the wire, but its for precaution. If it snaps with accidental lug n pull, then it becomes a pain, why take a chance for 5 sec job.
| | #90 (permalink) |
| BHPian | have recently started commuting on the NH47 4 lane highway, from cochin towards cherthala. I usually travel between 80-100 on this road,but my speed hardly ever drops even in traffic, I manage to slip through the gaps. as far as possible i overtake on the right, but if people persist in hogging the overtaking lane while crawling at 50kmph, inspite of flashing lights and honking, I take them from the left. 80-100 is not a rash speed for this road, and is easily attainable by the most inept drivers even when they are driving rust buckets ready for the junkyard. which means, all these idiots, who are doing 60, even the ones driving swank new sedans, speed up when they see me in the RVM, try to block me, or start racing the moment I pass them. I dont mind if they kill or maim themselves while trying to keep up with me, but I definitely dont want them scratching my car. what I usually do is a put on a nice burst of speed to accelerate from 80kmph in the 5th to 140kmph(which is great fun-i admit) this usually destroys the wannabe racer's morale and they leave me alone, so that I can settle down to my usual speed of a 80-100. wondering if there is a better way to avoid getting drawn into these kind of pissing contests. dont tell me not to overtake a car travelling at 60-80, because, that defeats the purpose of having a highway. PS-people driving stock swifts, can you tell me if your car smokes above 120kmph(on regular diesel)
| Thread Tools | |
Similar Threads | ||||
| Swift Mods : Post all queries / pics of Swift Modifications here. | blindrage | Modifications & Accessories | 1288 | 4th September 2008 01:08 |
| Peted Swift VDi ABS 10000kms Review. EDIT : Updated to 20,000 kms | BUSA | Long-Term Ownership Reviews | 39 | 21st February 2008 17:47 |
| Swift Vxi & Swift Vdi - Ownership/Service/Running costs | dcetech | Hatchbacks | 1 | 16th August 2007 14:21 |
| First timers Confusion : Swift VXI , Swift ZXI and Palio Stile 1.6 | proverma | Hatchbacks | 17 | 18th July 2007 17:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
