Old 13th January 2008, 20:43   #1
Default Sunroof in Innova with 3 row A/C
Has anyone got a sunroof fitted in his/her Innova which has 3 row Airconditioning (Models G4 or V)? If yes, pl. send the contact details of the vendor. Vendors in BLR wud be preferred.
Thanks!
ateet.jayaswal is offline   Reply With Quote
Old 19th January 2008, 08:30   #2
Akshay1234's Avatar
Thanked: 7,244 Times
its not possible. youll have to reroute the ac vents and pipes etc.
Old 30th January 2008, 17:54   #3
btirthankar's Avatar
Thanked: 115 Times
Default Is sunroof then possible for single blower Innovas?
btirthankar is offline   Reply With Quote
Old 30th January 2008, 18:27   #4
Akshay1234's Avatar
yes it should be possible.
Old 31st January 2008, 10:24   #5
Thanked: 115 Times
Default Cost?
Any cost indications? Is the G1 worth it cooling wise...? I believe its the same compressor but with only in-dash outlet.
Old 31st January 2008, 10:43   #6
Akshay1234's Avatar
sunroofs can cost anything between 15k to more than a lac. i wouldnt take the g1 over a g4 with the dual ac since you need the dual ac in the innova.
Old 1st February 2008, 14:09   #7
Thanked: 115 Times
Default Cooling G1 Vs G4
But Please elaborate the cooling performance G1 Vs G4?
Isnt the Compressor and Compressor Capacity CC same in G1 Vs G4?
Finally will the 15K Sunroof be good enf?
Old 7th February 2008, 00:51   #8
BUSA's Avatar
G4 will cool much much better then G1. Get a test drive and switch of rear AC and then switch on rear AC and see the difference for yourself.
No IMO, the minimum Sun roof which is worth is 40k fully automatic one. The manual slide is dodgy to say the least.
Old 9th May 2008, 12:58   #9
LLL
Default Innova aftermarket AC
Hi
Has anyone fitted an aftermarket AC in Innova or knows about them?
If yes, is this a three row AC or a single row?
What happens to the car warranty?
LLL is offline   Reply With Quote
Old 9th May 2008, 14:36   #10
abhinav.gupta88's Avatar
Thanked: 310 Times
Get it fitted from the toyota showroom itself. It will give you a/c for the middle and the last row.
In case you get it done from outside. The warranty will go away.
Old 9th May 2008, 16:52   #11
LLL
They are offering some imported dual AC or a single row toyota genuine AC. You know about some 3 row ac as well that can be fitted?
Also for imported dual ac, it would be covered under dealer warranty and not toyota warranty.
Old 10th May 2008, 15:32   #12
Thanked: 103,782 Times
Originally Posted by LLL View Post
Hi
Get the air-con fitted only from an authorised Toyota workshop. We recently got the double air-con fitted on a family Innova for 29,000 from Shinrai Toyota. Excellent job....looks and works like a factory fit.
Old 10th May 2008, 15:34   #13
LLL
@GTO - can you tell me what company it was? Dealers in delhi are asking 46k for the AC.
Old 10th May 2008, 19:02   #14
I dunno but have been made to believe that the parts are OEM Toyota parts. I hope there isn't a confusion.....I only got the rear air-con fitted to an Innova which already had the regular air-con system. Have you been quoted 46K for the entire (front and back) air-cons or only the rear add-on to your Innova?
Old 10th May 2008, 20:49   #15
Akshay1234's Avatar
was your rear aircon the one like on the higher innova models or the one like you get on a safari i.e just above the front seats.
Innova 7/8 Seater SWAP| Are Seat Mounting bolts Layout common (for Middle Row only)? btirthankar Modifications & Accessories 26 31st August 2016 10:23
Rear seats for Safari + Middle Row & ACon herculesksp Modifications & Accessories 33 6th May 2011 18:18
3rd row of seat for Altura sans33 Modifications & Accessories 19 18th July 2010 23:44
Middle row mod for scorpio.... nbmotorsport Modifications & Accessories 6 16th May 2007 13:21
Autocar goofs-up acceleration figures...twice in a row? Shan2nu The Indian Car Scene 19 6th December 2005 13:26
