Old 14th January 2008, 13:53   #1
arunmshenoy's Avatar
Default Swift Problems
Hi TEAM-BHP
I have a swift Zxi 2006. It has done 27000 Kms. I have a backlash problem from the day one. I tried with maruti they done lot of repairs but still the problem persists. Can anybody from bangalore help me solve this problem. . Thank You.
arunmshenoy is offline   Reply With Quote
Old 14th January 2008, 17:42   #2
Thanked: 32 Times
Nothing much you can do about it in India unless you file a case against them in consumer court but it would take year time to find solution and its not easy affair :(
Which Service Center and where you have baught this Lemon ?
Explain in this thread the number of problems you are facing so we will know If they are known issues of Swift.
Please remember Swift has lot of known issues and every thing is discussed in this forum, If Maruti had read this Forum or listened to customer feedback they would have rectified many issues in Swift from 2006 onwards.
But unfortunately MUL left out many issues in Swift as it is and since few people don't notice nor care of few issues life goes on
Ravi.
ravibhat is offline   Reply With Quote
Old 14th January 2008, 18:47   #3
vikram_d's Avatar
Thanked: 940 Times
Can you explain your problem in a little bit more detail. Maybe some one here maybe be able to help.
Old 17th January 2008, 14:29   #4
kryptik83's Avatar
One thing that has bugged me from day 1 is that if the Swift goes at speeds exceeding 45kph, I can hear some chik-chik sound coming from somewhere near the Driver seat belt/front right door
kryptik83 is offline   Reply With Quote
Old 16th August 2015, 13:29   #5
tharian's Avatar
Thanked: 3,163 Times
Default Re: Swift Problems
Bumping up an old thread.
My dad's 2005 Swift has been dripping green fluid on the front drivers floor for few days now. It is at a very slow rate and after a week is noticeable since it forms a small puddle right below the clutch pedal.
This morning I checked the source and it seems from a pipe under the dash right behind the center console. The pipe is a metal one with a rubber pipe on one half and it seems it's leaking from this joint.
I took the car for a spin with the AC running and checked again and although I couldn't find fresh fluid since I had wiped it clean earlier, the pipe was warm to touch.
Recently the coolant reservoir was almost empty and I had topped it up and has reduced just a bit since.
Is this the coolant or something else?
AC works fine except for the compressor cutting on/off more than often. It was overhauled around 4 years ago.
I wanted some inputs and info before heading to the service center.
I can post a snap of the pipe if required.
tharian is online now   Reply With Quote
Old 18th August 2015, 05:28   #6
vikram_d's Avatar
Thanked: 940 Times
Green fluid will definitely be the coolant. Try running the heater. I'm pretty sure you will see coolant leaking when the heater is on.
vikram_d is offline   (1) Thanks Reply With Quote
Old 18th August 2015, 10:45   #7
tharian's Avatar
That is right. The temp control knob is at the center most of the times since anything towards cold becomes too cold.
I guess I have to ask my dad to modulate the temp by turning on/off the AC button till the pipe is checked for leaks.
Old 18th August 2015, 11:02   #8
dhanushs's Avatar
Thanked: 4,504 Times
It should be the engine coolant pipe running into the cabin for heating, which has started a leak. Fix it ASAP
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
Engine problems with swift diesel GeekSrik The Indian Car Scene 11 17th March 2007 17:42
Speed 93 causing problems on my swift!? praveen_n77 The Indian Car Scene 20 23rd July 2005 13:11
