Old 16th January 2008, 13:44   #1
nishantgandhi's Avatar
Thanked: 151 Times
Default Gear Lock and Headlights for Getz
Hi guys,
I want to know:
1. Which is the best gear lock for Getz? Xenos website doesnt have Getz in its list of either U type or Pin type. Please mention brand and cost.
2. I find the stock headlamps very weak, even on high beam (I hate driving on high beam normally but have no choice due to poor light of stock HL). Can you suggest upgrade (Xenon lamps? HID? I dont know anything about these!!). What will be the cost?
Also, would I need to replace all bulbs, or just the headlight bulbs?
Nish
nishantgandhi is offline   Reply With Quote
Old 16th January 2008, 13:53   #2
ramie2400's Avatar
Thanked: 58 Times
i agree with nishant,Getz stock headlamps are real dull,even i feel the same and drive on Hi-beam,though the new ones have crystal clear Headlamps,what can anyone suggest to make it much more brighter.. please if anyone using better headlamps on Getz throw some light on our dull lights problems.. cheers
Old 16th January 2008, 14:26   #3
Akshay1234's Avatar
Thanked: 7,242 Times
im using 90/100w narvas. they are white and are pretty bright though not as bright as the HIDs in my innova. bulbs cost some 500 bucks or so. had changed the parking lights to white also but the hyundai dealer thought they were spoilt and changed them back to original ones.
Old 16th January 2008, 15:02   #4
Thanked: 151 Times
WHich Hyundai dealer was so creative?
On another note, I noticed that you are from Mumbai. Where did you get these bulbs fitted? Also, can you recommend some nice shop(s) in suburbs for Xenos security system fitment, Gear Lock fitment and lights change? I want a clean job without cutting of wires for Xenos, so please advise accordingly.
Old 16th January 2008, 23:22   #5
ramie2400's Avatar
Thanked: 58 Times
you might have got heated up on seeing that
Old 17th January 2008, 12:17   #6
Akshay1234's Avatar
in really dont know about the suburbs. this was jayabharat hyundai. actually they werent working and nor were the fogs. the changed all of them. i thought it mightve been a fuse. but now ill never know. that service adviser left them.
tell me about it. good thing is they were only rs150.
Old 17th January 2008, 12:32   #7
pingping's Avatar
Go for 90/100 upgrade, it is definitely worth it.. note the following..
- fix a quality branded RELAY... it is a must
- Use Ceramic Holders or else ur stock holders would melt with the excess of heat produced by those bulbs
- use quality wires and an experienced car electrician..
Other details can be found in the following thread... and U'll love driving at night.
http://www.team-bhp.com/forum/modifi...ting-here.html
HID kits are very expencive, needs technical knowledge to find the original one.... not advisable for normal use, unless you intend to do too much of highway and high speed driving then HID's come handy.... Good luck
pingping is offline   Reply With Quote
Old 28th January 2008, 14:03   #8
Thanked: 151 Times
GEAR LOCK
I enquired for a pin type gear lock for Getz and was quoted INR 1800 for Autocop and INR 1850 for Xenos.
Installation for both would be done at home/customer premises, by company engineers.
Which one would you guys recommend?
HEADLIGHTS
Also, I checked out the headlamp bulbs. Is it advisable to retain 60/55W power and go for Philips H4 white light? Or should I go for 100/90W power and get Narva/Philps with additional relay?
Any suggestions?
Old 7th March 2008, 13:43   #9
Thanked: 151 Times
Default Xenos - finalized
I am planning to go for Xenos Pin Type gear lock for Getz. I have been quoted INR 1850 (INR 1600+INR 250 for installation).
Any user reviews or feedback for this? The dealer told me that Xenos, Autocop and Silicon are more or less the same, the only difference being branding and warranty. since Xenos offers 5 year warranty, I decided to go for it.
If there are any first hand reviews or problems encountered with Xenos, I would appreciate if one could please let me know.
Old 7th March 2008, 14:15   #10
binoyb22's Avatar
@Nishat
IS this problem there for the GETZ PRIME also??
binoyb22 is offline   Reply With Quote
Old 7th March 2008, 14:20   #11
Thanked: 151 Times
^ what problem are you referring to?
Old 7th March 2008, 15:04   #12
Thanked: 25 Times
Infractions: 0/2 (9)
I've used Minda gearlock on my Wagonr which i U-type. I bought it directly from the company(UP) and installed by company servicemen at Bangalore.See the below thread for full details.
http://www.team-bhp.com/forum/689908-post49.html
http://www.team-bhp.com/forum/706440-post58.html
Ramki
ramki067 is offline   Reply With Quote
Old 7th March 2008, 15:14   #13
binoyb22's Avatar
@Nishat
Old 7th March 2008, 15:15   #14
binoyb22's Avatar
Stock headlight problem
Old 7th March 2008, 15:16   #15
Thanked: 151 Times
Originally Posted by binoyb22 View Post
@Nishat
I am not sure. But I guess it would be as the headlight bulbs have not been changed in Prime series. Anyways, you would be a better judge since you are driving the car. I found the stock headlights way too dim for my usage and infact I found the Philips Vision+ also a bit dim, although other users are happy with it.
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Can a gear-lock cause the gear cable to loosen up? libranof1987 Technical Stuff 0 22nd December 2011 21:29
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
