Old 8th March 2011, 18:12   #316
binz's Avatar
Thanked: 411 Times
Default Re: Suzuki Swift turbo
Originally Posted by Sportsmind View Post
The carbon emission has incresed off late and it is clearly visibile since last week on my rear bumper. It was not this high earlier.
Is it normal? or it needs attention.
Its mostly tuned to run richer at higher rpms, you could get it checked with rr to see if its too rich. No problem otherwise, what mileage are you getting?
Old 1st April 2011, 17:38   #317
Sportsmind's Avatar
Thanked: 28 Times
Thanks it was running rich, and a few connecting rubber tubes had given away. Lucky I got it fixed quick if not I could have damaged my ECU.
I am getting a mileage of approx 8 at the moment, mix of city and airport road drives.
Sportsmind is offline   Reply With Quote
Old 1st April 2011, 17:46   #318
Sportsmind's Avatar
Thanked: 28 Times
Default Engine oil and coolant
Hai,
I have been on OWS-5W-50 synthetic oils for the last two years. Just wondering if I should go in for a different engine oil for the turbo system.
I have these options in mind:
Engine Oil:OWS-Uber power Turbo racing- INR 5630- 4 ltrs:http://www.speedworks.in/Products.aspx?catid=14
Cooling:Tectaloy XTRA cool- INR 500- 500ml :http://www.speedworks.in/Products.aspx?catid=80
What are the best recommendations and their rates.
Also on the cooling system any recommendations.
Old 29th June 2011, 20:45   #319
Sportsmind's Avatar
Thanked: 28 Times
My turbo charged swifty is to feature in Auto Car magazine. Feels great when all the efforts of the last four years gets it due recognition.
Thanks to all fellow Bhpians and Team bhp for getting me this far.
Cheers...
Old 20th July 2011, 12:48   #320
Sportsmind's Avatar
Thanked: 28 Times
Hai I am planning to upgrade my CAI system from the existing K&N setup.
Also reworking on the filter position to avoid the so called heat sink issues. The plan is to use the area closer to the battery and also adding a air intake duct from the front bumper to guide the air flow to the filter.
Turbo heads kindly advice on the recommended filters for my setup and is this the right position for the filter.
Red rooster has been advicing me to go for the BMC filters.
Old 18th October 2016, 11:25   #321
sushrutha's Avatar
Thanked: 324 Times
I'm planning to install Turbo Boost gauge in my Diesel swift.
Can anyone point me to the exact pipe (with a picture) in the engine bay from which the boost/vaccum can be tapped ?
Suzuki Swift G13B Exhaust Turbo Manifold - Zage Turbosystems eapen Modifications & Accessories 16 15th May 2012 13:52
Suzuki Swift on Assembly line in Pak Suzuki (Spy shots) panicslayer The International Automotive Scene 10 8th February 2010 23:38
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
Indica Turbo vs Non Turbo lbhavani Technical Stuff 0 5th September 2006 22:22
New Indica Turbo - is the turbo on? gakudva Technical Stuff 5 15th July 2006 23:00
