Old 18th January 2008, 13:04   #1
absynthguzzler's Avatar
Thanked: 224 Times
Default Fibre Glass Or Dynamat ?
simple query really, do u think lining bodywork with fibreglass works in a similar manner to layering dynamat ?
2 reasons for the thought , firstly kinda got a few sources for gettin hold of fibreglass on the cheap. and more importantly ...... i want DIY mods , not a buy and apply with no satisfaction at all !!! dont wanna work around just slappin cash to solve my problem , i want a proper DIY way of sound deadening .
so any other suggestions for sound deadening would be appreciated apart from "go to this shop and buy blah di blah and blah di blah will fix blah di blah for you "
oh just got myself a w124 shell , so working from groundup..the engine bay is empty so thought id use the chance to make this one as silent as a lexus
absynthguzzler is offline   Reply With Quote
Old 18th January 2008, 16:10   #2
spadival's Avatar
Thanked: 16 Times
I have no answers to ur queries.. But can u start a thread and post some pics of your W124 restoration ?
spadival is offline   Reply With Quote
Old 18th January 2008, 17:50   #3
Thanked: 13 Times
Blueraven has worked with fiberglass in panels, boots etc so maybe you should ask him.
Old 18th January 2008, 18:11   #4
Thanked: 294 Times
Fiber glass and dynamat both are different things.
Dynamat add weight but fiber glassing does not. I would suspect fiberglassing the door panel only will make it stiff but it might rattle also.
Old 18th January 2008, 21:31   #5
Thanked: 224 Times
can i add any material in between the fibreglass layers while applying the resin to assist in sound deadening ?? and also is dynamats primary reason for doing its job due to the weight n solidity it adds ? if so , then can i add a few layers of " something" to get fibreglass to work in same manner
Old 19th January 2008, 11:33   #6
Thanked: 294 Times
you can add lead sheets to make it heavy, but I think it will be costly affair also.
XYG Glass or Saint Gobain glass HappyRoadie Technical Stuff 10 2nd June 2011 19:50
Dynamat alternative? Sankar In-Car Entertainment 9 13th July 2009 19:45
Fibre Glass Motorcycle Fuel Tank fireblade747 Motorbikes 7 30th March 2009 13:54
Happy Birthday Moral Fibre,Oral Fibre,MF Drive,Moral Forboid etc. payam Shifting gears 44 20th November 2007 10:58
infinty subw for sale with dynamat extreme rsjaurr Shifting gears 16 20th March 2006 13:33
