Old 15th February 2008, 19:11   #16
sumeethaldankar's Avatar
Thanked: 1,153 Times
hey man congrats. Had a PP once. Had it scarp it off at last. We used it for 18 years. Could have gone long but then we had a new car and keeping both was getting expensive.
sumeethaldankar is offline   Reply With Quote
Old 21st February 2008, 09:41   #17
Awaiting Email Confirmation
Thanked: 20 Times
interesting work, but would you please type a few lines below each pic in the web album(picasa) so that mechanically challenged people like me can understand what we are looking at?
this is the last real affordable RWD in india is'nt it?never did get the chance to drive one inspite of having many in the family, my legs were too short to reach the pedals back then.
Old 21st February 2008, 10:38   #18
Thanked: 18 Times
I will certainly look forward for after plugging in the entire setup of the engine and other stuff. That would be one major makeover and as ripper pointed out do add a few lines for nerds like us.
VJ_MAVRICK is offline   Reply With Quote
Old 21st February 2008, 11:23   #19
chiragh_bir's Avatar
Thanked: 70 Times
change front head lamps to clear lens lamp... borrow it from new ambassador..
change the steering either go in for after market wheels or borrow it from fiat palio and ty to get the front grill chromed.
chiragh_bir is offline   Reply With Quote
Old 21st February 2008, 11:42   #20
planet_rocker's Avatar
Thanked: 368 Times
yep chirag! it sounds great - just to add to your inputs:
HL - from the Amby Grand - get bosch relay and bosch halogens - the stock relay in the fiat IMO is PMP.
Steering Wheel - my car has a Momo Steering Wheel - Aditya (mod) has Momo in his 1100 as well.
Front Grill - get a mesh type grill - you can even DIY the mesh grill.
planet_rocker is online now   Reply With Quote
Old 21st February 2008, 15:26   #21
prabhuav's Avatar
Thanked: 112 Times
Thanks for the ideas guys. I had to travel to the US in a hurry and am freezing my @$$ up here.
Steering wheel is definitely after market. Might do one in wood, if I decide to go ahead with a wooden dashboard and center console. Else will be a palio steeing covered in leather
I have had clear lenses for over 5 years with Bosch relays. I will use the ones from the new Amby, as the reflectors are . Unless I manage to lay my hands on a good set of HIDs here
The pics already have the engine in. Last update was that after we started it , found leaks in the crank case and pulled out the engine again. Got a crankcase gasket and should be putting her in again.
Currently the FFE mod is being rethought coz encyclopedia Fiatica Mr Dhabhar pointed me to a spring loaded valve in the exhaust manifold that is there on this engine, which lowers power if removed. Something to do with the Hitachi carb on it..Go figure
I was browsing and found this..
Datsun 1200 Club
T3 suck thru turbo with 100+BHP on a 900 kg rwd car.. wicked ..
prabhuav is offline   Reply With Quote
Old 21st February 2008, 15:36   #22
prabhuav's Avatar
Thanked: 112 Times
Picasa Web Albums - Vijayananda - My Premier Pa...
Comments added to the pictures in the album
Old 21st February 2008, 15:42   #23
Thanked: 368 Times
wow! never knew that - care to explain more - has it gotto do something with the Hitachi Carb or in general the Solex carb or directly related to the manifold?
Old 21st February 2008, 15:53   #24
prabhuav's Avatar
Thanked: 112 Times
i have no idea what the valve is doing there.. Am yet to research that. Most probably the carb will go..
Old 21st February 2008, 16:06   #25
Thanked: 368 Times
my mech once told me about a "pumping" carb - the hitachi carb similar to that "pumping" carb? may be the presence of the spring loaded valve has got something to do with the "pumping" thingy.
do you have a pic of the valve you are talking about?
which carb are you planning to fit?
Old 21st February 2008, 16:09   #26
prabhuav's Avatar
Thanked: 112 Times
If I go the whole hog and doa suck thru turbo, then a side draft carb. not yet completely thought out.
Was thing FI but will cost money.. unless I can get entire kit from some car , maybe an esteem??
Dunno..
Old 22nd February 2008, 08:27   #27
Thanked: 20 Times
thanks for that vijay! like your homemade AC. we used to have one in our old padmini.
Old 3rd March 2008, 19:11   #28
prabhuav's Avatar
Thanked: 112 Times
Update:
No new pictures as not much progress made.
Currently struggling with fixing pedals that hang to replace the plunger type ones that are there. Two reasons I am doing this. The plunger type leaves a hole on the floor that is indeed never seals properly. Second it is a pain in the @$$ for wifey in heels to drive.
Got an idea and drew it out for the mech. Lets see how he implements it.
If anyone comes across a cheap T3/T4 turbo, do let me know.
Vijay
Old 8th May 2008, 13:17   #29
prabhuav's Avatar
Thanked: 112 Times
Since I already posted on the other thread, thought I would bump this thread up.
Very little progress on the car over the last 2 months. We got into running condition as i wanted to drive it around for a couple of days to figure out the current state of performance. Unfortunately the Hitachi carb was a mess and could not hold revs at call. was stalling constantly. We had to start it so many times that the starter conked off. Ended up towing the car back to the garage.
First thoughts, it defintely has more power than the fiats 3 bearing 1100. But my Scorpio's torque has me hooked and I am leaning strongly towards the turbo.
Currently talking to RDKarthik to see if he can do the EFI for me.. that will make it much easier to TC than the carby setup.
Vijay
Old 25th November 2008, 13:36   #30
prabhuav's Avatar
Thanked: 112 Times
Default Finally - Progress
I know this is an old thread that has not seen any update in 6 months. Lots of water has flown under the bridge since then.
Losing Dad in June put a huge dent in the enthu to work on the car, both for me and the mech.
Work done so far - engine and drive train mounted and tested. Pedals converted to hanging type and the steering mechanism being changed to a rack and pinion from an 800.
It was a little after Dussera that we woke up and said it is time to do justice to the car and start again. So the mech hired a tinkerer cousin of his to exclusively work on this car. Last weekend was heartening to see all 5 people in the workshop working on this car
Current state :
Running boards and platform - done
Doors and roof being worked on.
Fenders and boot+bonnet - next.
A few snaps that I took
A few pics that I took:
Resto-mordernizing my first love - my Dad's Premier Padmini 1989-gopalrt-rear-door.jpg
Resto-mordernizing my first love - my Dad's Premier Padmini 1989-img00022.jpg
Resto-mordernizing my first love - my Dad's Premier Padmini 1989-img00025.jpg
Premier Padmini - My love, My pride, my passion freakmuzik Long-Term Ownership Reviews 34 6th April 2017 15:51
First love is first love, The Punto Saga. furioussphinx Test-Drives & Initial Ownership Reports 281 20th October 2010 14:19
Ambassador, Premier Padmini Specs ?? Technocrat The Indian Car Scene 69 22nd February 2010 16:38
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
