Old 28th January 2008, 12:25   #1
Default OHC VTEC Silencer
Hi guys,
On the way back from Pune to Bangalore I hit a pretty big pothole on the NH4 near Chitradurga (Awful awful 2-3km strech here... But anyway). My silencer has started rattling and makes an awful sound now. Honda are saying it will cost me 22k to replace it. I was wondering if anyone has tried a non-OEM silencer? Would love to go for a free flow but I dont know how feasible that is right now.
Thanks in advance
Sameer
thatsam is offline   Reply With Quote
Old 28th January 2008, 13:16   #2
S@~+#0$#'s Avatar
Thanked: 37 Times
Go to Shabir near TV Tower (Opposite Fun-world) to fix your exhaust problem.
Based on the damage, Shabir will fix your existing exhaust itself or fabricate the damaged part himself. Or, if you want to go in for a FFE, you can talk to Raj Hingorani(ask Shabir for Raj's contact details).The header design, dimensions, lengths etc are provided by Raj and the FFE will be made by Shabir.
Either ways, your exhaust should get fixed will within 50% of the Honda quote.
S@~+#0$# is offline   Reply With Quote
Old 28th January 2008, 13:38   #3
sushrutha's Avatar
Thanked: 325 Times
The silencer can be reapired easily.
Else just go in for FFE.
My OHC silencer had gone for toss. It was full of Rust, Thanks to Lohithrao who offered me his old silencer( He has FFE by viper)
Old 28th January 2008, 13:40   #4
smith's Avatar
Smile
Originally Posted by thatsam View Post
Hi guys,
Thanks in advance
Sameer
Hi Sameer,
i have an ohc1.3 & since the old silencer was damaged ,i got a non oe silencer assembly from delhi for just 3500 - yet to use it as it will be fitted in a day or two - the 1.3 & the vtec silencer should be almost identical except for tailend which is a steel one in vtec( i have got the same tailend) . so the best option for you is to get the existing one repaired & if that does not work out buy an aftermarket one. the best ones in galvanized sheet should come under 4000.
the oe is not too great either becoz i have seen a good number of people having to replace them . as far as ffe is concerned i am also interested but am sceptical about the increase in sound . it would cost you anywhere between 12 to 15 k along with modified headers & is expected to give a boost of 5-10% in power so u can go for it if you are comfotable with the sound.
smith is offline   Reply With Quote
Old 29th January 2008, 02:14   #5
iraghava's Avatar
Thanked: 156 Times
Are you sure that the silence is damaged & not one of the mounting bushes?? Sometimes just having them damages can lead to a lot of noise & they are a very cheap & easy fix too!
Old 29th January 2008, 02:55   #6
Thanked: 804 Times
Whoops thats pricey. 22k for a silencer is daylight robbery. Looks like cars and printers work on the same principle. Charge less for the product and rip customers on the consumables. Get a FFE dude. Wont regret it. The OEM is pathetic anyways...
Lalvaz is online now   Reply With Quote
Old 4th February 2008, 11:23   #7
Hi guys!
Thanks for the response.
Iraghava - The silencer is damaged. I had to get it welded from a local mechanic to reduce the sound that it was making.
S@~+#0$# - Thanks for the detailed reply. Will go there next weekend.
If the cost is comparable I might just go in for a FFE
Sameer
Old 10th February 2010, 10:10   #8
the VTEC guy's Avatar
Thanked: 138 Times
Hello, I have a similar query and since my thread was deleted putting my query here.
Can anyone advice a store/garage in Pune who can help me with the OHC VTEC silencer. I would prefer stadard over FFE for the comfort level. Silencer is in bad shape. Totally rusted. pieces of the silencer have rusted and fallen of and totally missing. repair is not a option. Needs replacement.
What I am specifically looking for is whther someone in Pune would be able to provide a cheap reliable alternative.
the VTEC guy is offline   Reply With Quote
Old 10th February 2010, 10:36   #9
There are a few places in Pune which you can evaluate
1. Khemchand near Hite bar in Mg road, I have been to him a few times to change my end can, he is good only in the welding department
2. Poona motors has got a garage in Marketyard, I recently got my OHC exhaust changed from there for Rs 6000 which included the end can, catalytic converter and a few pipes (I had some old pipes lying with me since I had a free flow earlier)
3. Sohail (International exhaust systems) on salunke vihar road
Angad_kalra is offline   Reply With Quote
Old 10th February 2010, 16:57   #10
Thanked: 138 Times
Thanks budy. I will check at these places.
Old 5th January 2011, 12:12   #11
Max
Thanked: 85 Times
Default Re: OHC VTEC Silencer
guys my honda city 2004 gxi (2nd generation) front silencer is making little loud sound (taxi like sound). Micanic told me it has 2 sensors and is on front side. I got quote from shop for replacement which will cost me about 3.5k but guy is not able to arrange it and is giving me run around since 1 month. Do anyone know where i can get it in thane (mumbai).
I also need to get suspension work done. They are kind of become hard, any suggestion on that. Also my car clutch feel little hard any way to make it soft, shall i do clutch overhaul or something else. Please suggest.
Max is offline   Reply With Quote
Old 5th January 2011, 21:26   #12
Max
Thanked: 85 Times
Just spoke to hall mark honda guys in thane about suspension overhaul and they recommend following prices for new suspensions
1) Front suspensions (each side 5k) 10k + 1k labor = 11k
2) rear suspensions (each side 3.5k) 7k + 1k labor = 8k
3) front lower arm suspension (4.25k each) = 9.5k + 1k labor = 11.5k
4) clutch overhaul 10k without flywheel and with flywheel about 18k to 20k.
he also said, if i show them car they can give me exact estimate. what you guys think please suggest.
Old 6th January 2011, 14:50   #13
Honda_Power's Avatar
Thanked: 16 Times
Hi Sameer,
I faced a similar issue with my 1.5 OHC. Honda gave me a quote of 27 k for the
B and C Pipe. Tried to fix it, but sadly it could not be welded as the rust had eaten
the core pipe and there was hardly any strength.
Went for an FFE from Raj. Costed me 11k for the end can too as i did not opt
for a half pipe. If you are bothered about the sound, you can get a muted one too.
You need to contact Shabbir/Raj for that.
Cheers.
Honda_Power is offline   Reply With Quote
Old 12th August 2011, 21:32   #14
Fortuner71's Avatar
Thanked: 274 Times
Exclamation OHC Silencer - Pondicherry help
Dear Team-bhpians ,
please assist , my OHC 1.5 Exi has a silencer leakage , need to get it repaired. any help on local contacts , garage will help . My brother in law has taken the car and is in Pondy right now . Request local team-bhpains to help .
The last option will be to take it to the showroom , which will be a rip off i know .
Fortuner71 is offline   Reply With Quote
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 137 24th January 2015 12:15
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 5 22nd June 2012 17:00
HELP -OHC under body(silencer) scraping speed breakers sushrutha Tyre & Alloy wheel Section 18 9th March 2010 10:29
Hole in silencer (OHC VTEC). Need help. hondadude Technical Stuff 18 15th February 2008 14:19
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 21:25
