Old 14th March 2008, 14:53   #151
Invinsible's Avatar
Thanked: 60 Times
This is what I think one should be doing looking for boosting..
Well ya ideally if one is looking for around 200-220hp can go for a mild boost about 15-20 psi via remap with intake and exhaust so one can safely have about 190 even after rise in temp ..may be the power would be consistent.
Anything more then that can go new turbo K04-1 with new ported manifold prefreably, remap of 18-21 psi, FMIC, new downpipe, injectors, fuel regulator, intake and exhaust.. can expect about 240-260bhp consistent power.. anything beyond that custom turbokit are must.. inluding all other modififcation to clutch, suspension, brakes, upsize tires, may be source a 6 speed gearbox with LSD too.. retaining the internals can upto 320-340hp.. beyond that get new pistons, valce, conrods and bring down compression level.
What most people do is strain the OE turbo with boost which goes beyond 20psi+ and in return the OE turbo K03/ K03s is not able to sustain that boost through out the rev band once the temperature rises.. in return one start facing lack of power after a certain time of drive or in the long run.
K04-1 turbos ideally can be installed with stock manifold but may need a new down pipe and you can get one for around 1000-1500$ or about 800 pounds or so over the net plus the freight and duties.
Invinsible is offline   Reply With Quote
Old 19th March 2008, 23:30   #152
iraghava's Avatar
Thanked: 156 Times
So Shuv, any updates??
Old 20th March 2008, 10:35   #153
shuvc's Avatar
Thanked: 287 Times
Heard you made his day !
I'm looking forward to his fitting the new brakes.
Drove the beast during the last meet. It's @&$^@#& scary! Specially so in city traffic and due to the inadequate brakes.
Old 20th March 2008, 10:52   #154
planet_rocker's Avatar
Thanked: 368 Times
Shuvd must be very happy with you Ishan - you did a great job man! cheers:
as for the brake upgrade - its just a matter of time. since the vRS alloys are with him - he just needs to source new shoes and thats it. i guess after that the brake upgrade will be done.
planet_rocker is offline   Reply With Quote
Old 20th March 2008, 11:47   #155
shuvd's Avatar
Thanks to Dhanno's driver, I got the RS alloys at a SWEEET price!!cheers:
Also, many thanks to Autokustomz!
@ Ishan - I decided to get the wheels couriered. They should be delivered in a while. The Spice people weren't too helpful about packing shaking.
But, the good news ends here. My turbo gasket is blown. Car now sounds like those old diesel generators. Should be getting a new gasket and OE bolts from Pete's soon. But, getting the same properly installed is going to be TOUGH!
shuvd is offline   Reply With Quote
Old 20th March 2008, 11:52   #156
maxbhp's Avatar
Thanked: 65 Times
Originally Posted by diven_b View Post
if i am not mistaken,the RS has discs all over,where as the Tpi has Discs at the front and drums at the back.
Thats true with respect to Rider diesel. For 1.8Tpi , its all round disc.
maxbhp is offline   Reply With Quote
Old 20th March 2008, 12:07   #157
Thanked: 368 Times
arey dont worry yaar! just keep your fingers crossed. I am sure it will be taken care of. you changed the turbo gasket last time as well?? ask Peter to send another set as well - just in case. i am sure Suman(Shazid) is good at it...one of your friends (Sunny) has switched to him as well for getting his / his customers' works done. Shazid's father was one of the best during their time.
Old 20th March 2008, 14:21   #158
shuvd's Avatar
Thumbs up
The alloys were delivered an hour back! Giving them a good wash.
Old 20th March 2008, 14:57   #159
Thanked: 368 Times
what about the rubber? are you going to use the Falkens for the time being? get the problem sorted out. all the best.
Old 22nd March 2008, 02:10   #160
iraghava's Avatar
Thanked: 156 Times
Good to see you guys happy! And a special thanks to Gaurav aka Autokustomz for the outstanding deal!
So, any progress on the tyres or need some help on that too??
P.S. And as Shuv might clarify, I do not deal in wheels or tyres!
Old 22nd March 2008, 02:47   #161
khanak's Avatar
Thanked: 130 Times
Those rims are really beautiful. Are you planning on getting the RS front bumper too?
Yea, Ishan only does wheel and tire packages
khanak is offline   Reply With Quote
Old 22nd March 2008, 07:42   #162
NOS Power's Avatar
Thanked: 55 Times
I don't think he'll do that. That's the first warning his car dealer told him before buying the TPi else he would have gone for the RS.
NOS Power is offline   Reply With Quote
Old 1st April 2008, 01:01   #163
Autokustomz's Avatar
its all good man...had to keep ishan's friend happy...
Autokustomz is offline   Reply With Quote
Old 5th April 2008, 09:49   #164
NOS Power's Avatar
Thanked: 55 Times
Smile
@shuvd, how u doing? hows your leg?
by the way did you get in touch with pete's regarding the intercooler? what about the suspension.
Old 8th April 2008, 14:46   #165
Thanked: 368 Times
Update:
the work was delayed because shuvd injured himself (sprained his ankle). got a call from him.
the turbo gasket and worn out bolts (sent by Peter two weeks back) have been replaced and SB is back on the road. the work was carried out at a Garage who used to / still tune rally cars.
all the best SB - good to have you back with us. i am sure shuvd will take very good care of you and he will not go over 2.5K RPM & maintain 60KPH - i am out of this thread now
From Skoda Octavia 1.8 TPi to a Grand Vitara. Or something else? nanu28 SUVs, MUVs & 4x4s 83 26th May 2012 23:46
Skoda Octavia RS 1.8 TPi Gearbox gone kaput @ 60,000 Kms!! nanu28 Technical Stuff 34 22nd March 2011 12:08
Skoda TPI & vRS whats the TCS button? nanu28 Technical Stuff 29 17th October 2008 15:29
