Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 6th February 2008, 14:56   #1 (permalink)
Default need help with zen
hello friends i have zen carbon
i have just installed new mag wheels n tyres size 13inch 5.5 broad
and tyres 165/60 r 13
but th problem is the tyres are touching the body all 4 tyres
i have tried to upgrade the suspension springs but the ride is to rough with the springs i have installed
pls need help.............................
thanks soban
soban is offline   Reply With Quote
Old 8th February 2008, 06:24   #2 (permalink)
wischvuanaudh's Avatar
As 13 inchers shouldnt poss much of a problem to the zen,try upgrading your suspension to koni. That should take care of your problem. Bythe way, your wheel hitting the arches when you travel alone?
wischvuanaudh is offline   Reply With Quote
Old 8th February 2008, 09:03   #3 (permalink)
A S H V I N's Avatar
This problem occurs because your alloys are a bit wide .. since it is 5.5J and the tyre is wide as well .. if you want to continue using the same set of rims and tyres on your car then you would have 2 options .. one is to alter the wheel arches so as to minimalize touching or to raise the suspension by adding bushes on all four sides ..
__________________
bass-line exhaust notes --- true music to one's ear...
A S H V I N is offline   Reply With Quote
Old 8th February 2008, 09:10   #4 (permalink)
snaronikar's Avatar
I think we can also add spacers and raise the suspension. But too much raising (of suspension) may hurt the suspension itself. Just take care while adding bushes/spacers on to it.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is online now   Reply With Quote
Old 8th February 2008, 18:43   #5 (permalink)
Infractions: 0/2 (10)
thanks soban
hello
what is the distance between the tyre and the body if its around 3inch all you need is to put 1 inch spaccers that will solve your suspension and your tyre problem
Last edited by Rehaan : 8th February 2008 at 19:21. Reason: Please take some time to type in full words as per TBHP rules. wht = what, u = you, ur = your. Thanks.
armotosport is offline   Reply With Quote
Old 8th February 2008, 20:23   #6 (permalink)
Cyrus43's Avatar
thanks soban
there is a very simple solution to this..change your wheels and tires to a more correct spec.
__________________
I HAVE NOT HAD A NOSE JOB DONE!!!!!!!!!
Cyrus43 is online now   Reply With Quote
Old 8th February 2008, 20:28   #7 (permalink)
zenopio's Avatar
dude ...change the rims to 5j man....
zenopio is offline   Reply With Quote
Old 8th February 2008, 21:58   #8 (permalink)
kpzen's Avatar
Its all because of the alloys u need to get 5j alloys. No need of tyre change.
__________________
Prajesh - << will be mostly offline till August >>
A true friend is someone who says nice things behind your back...
kpzen is online now   Reply With Quote
Thread Tools
Wanted: Maruti Zen vxi or Zen Carbon ollie Shifting gears 0 20th January 2007 10:32
S-Zen?(Swift engine in a Zen) raghuram.cg Modifications & Accessories 4 26th November 2006 17:24
Help with Zen Praneet71 Modifications & Accessories 6 26th May 2006 15:53
No more ZEN for Zen Lovers abhibh The Indian Car Scene!! 65 8th May 2006 17:17
E-Zen & B-Zen.... MustangMan The Indian Car Scene!! 3 2nd July 2005 21:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
