Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 7th February 2008, 10:24   #16 (permalink)
spadival's Avatar
Does e-bay US send stuff to india ? I had tried few things from e-bay and amazon.com but could not complete the transaction because India was not in their courier destinations.
OT: Same question here.. How did you get it shipped to India? Via the usual uncle/friend returning from US route or direct via courier?
spadival is online now   Reply With Quote
Old 7th February 2008, 10:30   #17 (permalink)
akshay1234's Avatar
ebay us ships to india. it just depends on the seller. you have to register with a us address and make he shipping address an indian one.
akshay1234 is offline   Reply With Quote
Old 7th February 2008, 10:40   #18 (permalink)
Team-BHP Moderator
Samurai's Avatar
Clearly you can't get it shipped to India. I had somebody in US order it from here: eBay Motors: Digital Inclinometer--Clinometer/Tilt Gauge/Clino Gauge (item 170188635416 end time Feb-23-08 13:24:57 PST)
Later my boss carried it over from US to me last week, along with the E3.
Regarding the accuracy I have one problem. Although the inclinometer is very accurate by itself, the platform/dash isn't. I attached the meter using vaccum suction cups while parked on a very level ground. As you see it shows 0-0 reading.
But when I am going down a slope, it shows 18-20 degrees, but while coming up the same slope it shows 4-5 degrees. Does this have something to do with how the suspension works? Does the suspension get compressed to different extent while going down versus going up?
I am really confused about this one.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 7th February 2008, 10:41   #19 (permalink)
manziee_crusier's Avatar
One of feather in samuari's crown eh?.
@ shajufx :You can't get goods from eBay US to India.If that was the case I would be having a great collection of goodies.
eBay india has lot of fakers.
__________________
Everyone seems to have a clear idea of how other people should lead their lives, but none about his or her own
manziee_crusier is offline   Reply With Quote
Old 7th February 2008, 10:52   #20 (permalink)
akshay1234's Avatar
it does ship to india. this item costs $27 to ship to india.
Old 7th February 2008, 11:10   #21 (permalink)
Cyrus43's Avatar
just one question samurai...what is the motive behind this installation??
__________________
I HAVE NOT HAD A NOSE JOB DONE!!!!!!!!!
Cyrus43 is online now   Reply With Quote
Old 7th February 2008, 11:17   #22 (permalink)
Team-BHP Moderator
Samurai's Avatar
I often try climbs and descent off the roads, I just wanted to know the degree of inclination.
__________________
Samurai
Old 7th February 2008, 13:26   #23 (permalink)
madan80's Avatar
so this is a REALLY high end Sextant! with realtime information!
... nice find!
__________________
Taken the plunge!
www. virtu. in
__________________
2002 Lancer | 2006 Palio | 2008 Trek 4300D
madan80 is online now   Reply With Quote
Old 7th February 2008, 13:52   #24 (permalink)
Location: Chennai (formerly Madras, even more formerly Chenna Patnam)
Post
Regarding the accuracy I have one problem..... Does this have something to do with how the suspension works? Does the suspension get compressed to different extent while going down versus going up?
yes, the suspension does get compressed to diff. extent going up vs. down, but that is a very marginal difference. The difference may be a couple of degrees, NOT 15-20 degrees.
But an inclinometer should give more or less the same reading going up or down the same slope.
Maybe you should try placing it in some other place, or change the direction ??? .
Blue Thunder is offline   Reply With Quote
Old 7th February 2008, 14:08   #25 (permalink)
Cyrus43's Avatar
ohh ok..have fun offroading buddy..basically you want to see how extreme you can go..have fun offroading buddy..
__________________
Old 8th February 2008, 04:30   #26 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Samu,
I wouldnt say the suspension has a large part to do with this (however, i have always wondered how the Gtech changes its behavior depending on soft/hard suspension and its acceleration readings...anyways thats a whole different story).
Let me give this a shot...hopefully i will be on the right track, but beware that i might be totally wrong
I think the reason for your difference in readings (if it isnt a problem with the device) is due to how it works.
My guess is that if it is a low end device, it is nothing more than a 2-axis accelerometer. However, if it is better designed than that it will ALSO have a gyro (probably 1-axis to detect pitch only...or for more $$ 2-axis gyro for pitch and roll.)
(vikram_d i stand corrected - after thinking about it for a while, in an application where you can set the device's neutral position a 2axis gyro would probably be the way it works, unless there is a huge price advantage to putting an accelerometer in? )
Basically the accelerometer can detect gravity(9.8m/s^2), and hence can figure out its orientation based on the pull of gravity.
Think of it somewhat like a marble in a bowl placed on your car's dashboard. If you are parked facing downhill on a slope, the marble will be further forwards in the bowl than its dead center/neutral position...and so on.
However, this now illustrates the flaw of using (only) an accelorometer to measure inclination.... why?... Think about what would happen (if you were on flat land) and slammed the gas pedal.
The marble would move to the rear of the bowl, because it is responding to acceleration (being a faux accelerometer n all). Hence the "inclinometer" would be telling you that you are going uphill at this point of time!
Now, my guess is that if you have an inclinometer that does use only accelerometers, the acceleration/deceleration while going up/down the slope is affecting the readings.
How to test this > park on the slope facing upwards (stay parked long enough to ensure the readings are refreshed and no smoothing / averaging messes up the reading) and then do the same facing downwards.
So... where do gyros come in?
Basically, they come in to work in tandem w/ the accelorometer to provide more accurate readings.
Gyros can detect rotation on their axis very very well, butttt.. everything is relative. ie. they know they have rotated 15*/sec for 0.1 second, so doing the math they can tell they have rotated 1.5* more than they were at 0.1second ago, but they have no sure sign of what their absolute reading is (they can only figure it out by calculating a.k.a heading gyros).
The problem with calculating is that cumulative error builds up, and the readings keep getting more and more offset.
When gyros and accelerometers work together, they keep each other in check. A gyro can help the accelerometer know that it is experiencing acceleration and not rotation, and an accelerometer at rest can help the gyro re-adjust its readings to eliminate that cumulative error, and so on...
You could figure out what your device has by the instructions given to set it up. For example, the Gtech (cheapest model) requires you to stick it on your windscreen, with the car at rest on flat ground, and then move it up and down till the display tells you it is level. This is a clear indication of an accelerometer at work.
If your device has a "set" button which you have to press to tell it that it is on level ground or something like that, i would guess that it is a gyro. This would tell the gyro that "this is 0*". However culumative error would build up the longer the device hasnt been re-calibrated for (if it doesnt have an accelerometer).
Anyway...im rambling on.... so i will stop.
Let me know : how are you instructed to set up the device and how your stopping on the slope test went.
cya
R
__________________
The memory of you will ride by our side forever.
Old 8th February 2008, 07:49   #27 (permalink)
dilipkumar7278's Avatar
Default Avg-vdp1
Pioneer AVG-VDP1 processor has this and more. I have connected it to my DVD player AVH-P5750.
dilipkumar7278 is offline   Reply With Quote
Old 8th February 2008, 15:17   #28 (permalink)
gd1418's Avatar
Pictures would be appreciated..
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 8th February 2008, 15:22   #29 (permalink)
Team-BHP Moderator
Samurai's Avatar
Rehaan, that's a good analysis. Since this is a cheapo inclinometer, it doesn't compensate for motion. I guess I have to stop and settle it to get good reading.
__________________
Samurai
Old 8th February 2008, 15:27   #30 (permalink)
gd1418's Avatar
I too have an analog type sitting on the dash of my Scorpio for the last 2 years..!!
Originally Posted by greenhorn View Post
an uncle's old omni had an analog version of this. It was much less complex, obviously !
__________________
Thread Tools
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
