Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 7th February 2008, 00:00   #1 (permalink)
hellspawn's Avatar
Default Ractive growl!!
Hi guys,
I have a ractive sf100 conical filter installed in my siena 1.6.When you floor the accelerator,the intake sound is a lot.I had a k&n filter before and compared to the ractive the intake sound wasnt too much.
Does the sound that the filter makes,signify anything?
for eg:is the filter sucking in more air or less air,if the intake roar is more or less.
Why is it that different intake filters sound different when they are sucking in air.Is this in relation to the quality of mesh used?
why does the ractive make so much more sound?Is there anything wrong with it?
P.S:Mods please move this thread if required.Didn't know whether i should have posted this query in the K&N vs RACTIVE thread.
__________________
Kenwood KDC-MP6539|Image Dynamics Q450.4|Image Dynamics CTX65cs|Image Dynamics IDQ15 D2V2|Connection Audison
hellspawn is online now   Reply With Quote
Old 7th February 2008, 00:05   #2 (permalink)
moralfibre's Avatar
I'm not a mod though someone will soon point you to this thread. (Oh Shut Up! - Intake Growl)
moralfibre is online now   Reply With Quote
Old 7th February 2008, 02:11   #3 (permalink)
hellspawn's Avatar
But nobody has mentioned why the sound is more due to an intake...is it pulling in more air or less air due to which it makes so much of noise?
__________________
Old 7th February 2008, 07:49   #4 (permalink)
akshay1234's Avatar
its pulling in more air. did u have a k&n stock replacement before this?
akshay1234 is online now   Reply With Quote
Old 7th February 2008, 11:15   #5 (permalink)
manveet's Avatar
Was the K&N installed in the Sienna or the Zen?
If you want an apple-to-apple comparison, just borrow someones K&N and set it up on the Sienna using the same plumbing.
IMO - the sound is because the filter is getting less air than it should be . .. for e.g. when one is running and can't get enough air, one "tries" to suck in more air and hence the panting ..
Also, if you remember when I got that crappy CAI system fitted on my OHC by the Noida tuner - and the intake volume was practically 5 times more and ROARING past 4k rpm .. the car REALLY slowed down post 4-5K rpm and the revs refused to climb .. Now that i've thrown it away, the growl is much less ..
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is offline   Reply With Quote
Old 7th February 2008, 11:30   #6 (permalink)
aZa
aZa's Avatar
Could be coz its a "Dry" filter ?
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 7th February 2008, 11:51   #7 (permalink)
manveet's Avatar
That could be a reason.
Once oiled and properly wet, it is likely to become smoother and hence less noisy
__________________
Old 7th February 2008, 13:05   #8 (permalink)
crazydiablo's Avatar
Binz is running a Ractive filter oiled...you should check uip with him
crazydiablo is online now   Reply With Quote
Old 7th February 2008, 16:00   #9 (permalink)
razor4077's Avatar
I have a Ractive SF100 fitted in my Lancer. Doesn't sound too loud... similar decibel levels to the K&N in my Santro. Am assuming this is a new filter, so it should be oiled. Check the plumbing to ensure there are no leaks. If that's a non-issue, take your car to the guy you bought the Ractive from and have him check it out. Ask for a replacement if the filter's faulty.
razor4077 is offline   Reply With Quote
Old 7th February 2008, 22:08   #10 (permalink)
chetanhanda's Avatar
I may have a different theory from scientific "Dr Watson" over here...
Even a stock intake makes noise very loud sucking noises its only that u cant hear it becoz of the resonator.
Have u looked under the hood of your OHC ? there is something called a resonator used in Stock intake systems, its a black colored box behind the bumper, the stock filter box is connected to this.. it provides some amount of muffling for the intake noise.. remove it and see how loud ur stock intake becomes ..
Think of it in this way.. sucking through a pipe directly or sucking air thru the same pipe with the tip placed in a large box with a large opening for air. The second setup will be less noisy.
More noise doesnt mean its dying for air etc etc or start "panting".
In a "so called" CAI setup the airfilter directly sucks air so u can hear the intake suction..
chetanhanda is offline   Reply With Quote
Old 7th February 2008, 22:14   #11 (permalink)
hey hellspawn.. noise doesn't tell u anything, stock intakes are also noisy if u dont have/remove the resonator box.
Just see how does it feel ?Do u feel the car is being held back ? if not then u are ok..
Stock systems pull air via the big resonator box which reduces the suction noise, your aftermarket sucks directly so u can hear it sucking in the air, plz dont go by the sound of the suction.
Plz dont use Manveet's theory of "running,panting hence the noise" as posted above..
Old 7th February 2008, 22:20   #12 (permalink)
nitrous's Avatar
Ractive = dry type(non-oiled)
K&N = wet type(oiled)
Hence the difference.
__________________
Where were hamilton's.... when he had to overtake Rosberg?
nitrous is online now   Reply With Quote
Old 7th February 2008, 22:34   #13 (permalink)
vikram_d's Avatar
In my expereince running panting = less air in the system. I used to have a K&N and then a green cotton. The intake growl was more on the green cotton. I have found after umpteen attempts at tuning my aftermarket ECU is that the louder the growl the more restricted the air flow. My stock swift filter breathes better than my green cotton. Have to go back to my K&N and try this again. Will post results here.
In conclusion what I am trying to say is that lesser the sound the better the breathing of an intake.
More sound = more restrictive breathing.
Note: My stock filter has a resonance box but it still breathes better than the green cotton.
Disclaimer: I am not trying to prove that one filter is better than another. Just sharing my experiences with green. Also I dont have a K&N dealership.
__________________
To be it is.
vikram_d is online now   Reply With Quote
Old 7th February 2008, 23:09   #14 (permalink)
Im not comfortable with judging air intakes based on noise theory.
It could depend on the design and type of installation etc etc
I'd go more on the feel of the car than the noise of the intake to decide..
The car could be panting becoz of the cam/headers/exhaust or any other custom tuning done.. not solely becoz of the air filter(loud) at those rpms which could be slowing it down...
Old 7th February 2008, 23:17   #15 (permalink)
vikram_d's Avatar
Chetan - I agree with you on most points but if the intake is breathing properly then there should be no sound (resonator box present or not). Air or wind for that matter causes a sound only if there is an obstruction in the way.
Trust me I have spent my whole day driving around bangalore with a modified air intake but no filter attached to it and the difference was amazing. My car is a completely stock car except for a RD ECU. It even has stock headers.
I never knew not having a filter could make so much difference to the performance of my car. I ran my car all of today with no air filter and the difference was mind blowing even on the stock ECU.
__________________
To be it is.
Thread Tools
K&n Vs Ractive HAFI Accessory/Parts Reviews 89 13th November 2007 23:53
RACTIVE SF400 Foam Air Filter eagle_f1 Shifting gears 5 29th October 2007 20:39
Oh Shut Up! - Intake Growl elf Modifications & Accessories 81 10th May 2007 00:07
ractive or k&n? NIKHILallug Modifications & Accessories 5 9th May 2007 19:10
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
