Old 27th February 2008, 22:18   #16
alias's Avatar
hi tarul
the place is near ulsoor the guy is an works with hyundai but has his own shop as well in ulsoor
had the same issue with my santroxing blew up 2 technos and then this guy hooked me up charged 600inr
i am sure he can do wonders for you!
alias is offline   Reply With Quote
Old 27th February 2008, 23:15   #17
binz's Avatar
Thanked: 412 Times
Nice ecu you have there!
Like the others,i too would like to caution you about having an inexperienced persn fiddling with the cars ecu.
Check with asif's contact ..
Old 28th February 2008, 12:16   #18
TARUL's Avatar
You and me know that the person who fixed it isn't so inexperienced,anyway should I go back to him or try asif's contact.
TARUL is offline   Reply With Quote
Old 3rd March 2008, 16:51   #19
Possible to merge the wires of the new autogauge with the existing rpm wires? Perhaps it wouldn't make a difference to the ecu if two tachos are being used via the same signal.
cya
A
Absar is offline   Reply With Quote
Old 10th March 2009, 11:24   #20
Spark's Avatar
Hey,
Any one with experience on installing Tacho on M.Gypsy carb??
Have read the manuals but installing it on carb through distributor isin't explained properly.
Tried connecting the signal wire to the -ive connector of coi l- that connects to distributor, but only to find that tacho needle picks up a bit but comes back slowly like if a capacitor is being discharged.
Any inputs to install tacho on carb gypsy with contact type distributor are welcomed.
Spark is offline   Reply With Quote
Old 27th July 2009, 16:15   #21
nikhil1300's Avatar
Default Gypsy dashboard improvement in aesthetics
I Want To Modify The Dash Board Of My Gypsy .Want To Install Speedometer,tachometer Oilguage,teperature Fule Guage Rpm Meter Other Indicater .suggestion Are Welcome.want To Convert From Analog To Digital If Possible.What are the other option.
nikhil1300 is offline   Reply With Quote
Honda Civic angel eyes with autogauge xenons koshyjohnuk Modifications & Accessories 18 2nd January 2015 13:07
Autogauge Tachometer 5 inch for sale z klasse Shifting gears 4 19th May 2007 15:50
For Sale: Autogauge 3'3/4"TACH 0-10,000 R.P.M. (W/SHIFT-LIGHT) s0uljah Shifting gears 12 19th September 2006 22:05
Fixing dents. Pankaj9 Modifications & Accessories 5 29th August 2004 21:58
