Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 19th February 2008, 22:04   #1 (permalink)
Ignazio's Avatar
Default Tata TL mods
Hi all!
I'd like to share with you the little modification of my pick-up and receive suggestion and comments. In my profile is a foto of my beast...
what I have done up to now:
1_ reshaping of leaf springs.
2_ torsion bars adjust (+4 cm)
3_ new rear drums
4_ new front ventilated discs (original are solid)
5_ high pressure avionics flexible brake hoses
6_ mud tires BFGoodrich 215/75 15"
7_ manual locking front hub (AVM)
8_ reusable air filter (FINER FILTERS)
9_ roll-bar lights and antennas (VHF & CB)
10_ front swaybar removed
To be installed soon (as they are in the garage) just time that is never enough....
1_ xenon lights
2_ 12000LB electric winch
3_ new set of steel rims with ET0 (+4 cm per side circa)
4_ second 100Ah battery with battery splitter
On the to do list:
1_ longer leaf springs shackle (+3/4 cm)
2_ new 4 gas shock absorber +5 cm extension
3_ stainless steel exhaust line
4_ turbo and injection pump tuning
5_ protection side bars, gearbox and differential
6_ snorkel
7_ diff. lock (ECTED)
8_ rear swaybar disconnect system
9_ 31" or 32" tires
10_ bed containers for tools, luggage etc.
11_ extra gauges
...and something else that I forget...!
Any comments and suggestion warmely welcome!!!
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 20th February 2008, 09:54   #2 (permalink)
rippergeo's Avatar
that is a huge list.
wonder why tata owners here in india dont go for serious performance mods.
I had my eye on the tata TL but it didnt seem value for money for the equipment provided. they give you better deals in italy dont they!
I like off roading, but am useless at technical/mechanical stuff.
some questions
1. why do you adjust the torsion bar? how does it change the on road and off road behaviour?
2.why longer leaf spring shackles?
3. you have removed the front sway bar and are planning for a rear sway bar disconnect system. why?
4.did you have trouble with the OEM brake hoses?
sorry for the newbie questions , just trying to learn.
are there any links that will give me more info about offroad suspensions?
I'm interested in basic leaf spring setups.
thanks.
__________________
Hairpin bends in a RWD Common rail Diesel= Ecstasy
Old 20th February 2008, 10:12   #3 (permalink)
Steeroid's Avatar
Thats a loooong list of things to do! I wish you all the very best and do keep us updated.
Out of interest is there any way we can get those ventilated discs, brake lines and air filter sent to India?
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 20th February 2008, 10:41   #4 (permalink)
condor's Avatar
Ignazio, pls post pics of your truck, and of the modifications you are doing. Would love to see them. Thanks !
__________________
Life is Analog. Digital is an approximation.
All kinds of animals come here ... and the occasional demon too !
Old 20th February 2008, 11:35   #5 (permalink)
tsk1979's Avatar
Post some big pics please!
Also could you post the "stock specs" of your vehicle? I presume its a 4WD with LSD?
__________________
Reclaiming.....!
Old 20th February 2008, 20:53   #6 (permalink)
Ignazio's Avatar
Hi all,
as you have discovered I like to talk a lot
So, sit down, have a cup of good Indian tea and read...
Answer in bold
Me too!!!
Here is good value for money... but think that in Italy is sold without anything! A pure working horse, even bull bar and roll bar are all aftermarket accessory...
some questions.
Never too late to learn!
The main reason is to increase GC for off road use, suspension is becoming a bit more stiff, then with higher ET rims, the car footprint is wider so is the lever acting on suspension. On the road with new rims will be still a bit stiff, but generally fine.
As above, higher body GC.
Because it increase the suspension excursion, especially on twist. On the road makes a bit more swing, but is something thet you can live with.
No, I haven't, but to increase breaking performance this is a must. Note that every kind of car will have better performance with this mod. Simply because, you do not have hoses expansion due to pressure. All the pressure you generate is going to the brakes.
Happy to answer!!!
here it is...Car Bibles : The Car Suspension Bible
thanks.
Thanks mate, will do for shure!
I think so, is only a matter of find a good price courier... It is a long trip!
Will post pictures, simply I'm not home now, actually I'm 1000km away, for a businness trip... Yes it is 4wd but not LSD.
Have a look to the spec. here in Italian, sorry...Tata Club Italia
Ciao Ciao, will post picture soon, promise!
Ignazio
Old 2nd March 2008, 16:24   #7 (permalink)
Ignazio's Avatar
Hi all!
Week end has been proactive, I've installed the xenon lights kit!!!
Picture coming later...
ciao!
Old 2nd March 2008, 23:20   #8 (permalink)
Hey you got xenons in the same old seal beam or did you get projectors??? hows the beam spread??
did you get the diff locks on the beast? is the suspension job done, the shackles increase is will lift the rear but what about front, do get lift kit for TL front end?
If your lifting the truck, get spacers for the wheels, or the vehicle will become unstable on the road [at high speeds] the track has to increase with the height.
dinar is offline   Reply With Quote
Old 3rd March 2008, 03:40   #9 (permalink)
Ignazio's Avatar
Hi!
just replaced bulbs, a bit of extra work because i had to remove the internal bulb reflector. Then I had to fix the 2 ballast and the little interface to switch the high beam. The original bulb is H4 then to have High beam there is a little reflector that moves to lit the full projectors when on. Nice efficiency, beam spread a bit wider, I have more light and at 6000K light temperature, is very bright! Very happy!
Diff lock is not done yet... soon it will be...
Charging the torsion bar to the maximum gives you an extra +5cm, reshaping leaf springs does not get that high, that is why I want to put extra long shackle. Will do that once I've got the money for the 4 new shock absorber they are 99 euros each!!! I will not use spacers, they are not very reliable. In place I'm going with 4 rims with ET0, they will be fitted tomorrow at my tire shop, I bought them already for the purpose last November. The footprint should become 8 cm wider!
Ciao Ciao
Old 3rd March 2008, 10:59   #10 (permalink)
99 euros for one........man thats expensive......if the track is widening than there is no problem, cause if your using it only for off roading it was fine , you'll be using it for daily driving too right [I think so], and thats when the stability is required more [at high speed]....keep us posted of the mods and post some pic with the new mod.
Thread Tools
mods and performance mods for unicorn please give your views rider60 Motorbikes 127 14th September 2008 09:51
Tata 1 L car to be unveiled on 10th Jan 2008. EDIT : Named Tata NANO safari_lover The Indian Car Scene!! 594 11th April 2008 14:20
Mods for Civic Vs Mods for Laura redsfx Modifications & Accessories 15 19th November 2007 20:01
Geneva Auto Show: Tata Motors unveils the Tata Elegante navdeep The International Automotive Scene 44 27th March 2007 13:44
Vote for Mods for Tata Indigo Marina vivek.singh.73 Modifications & Accessories 2 13th March 2006 11:55
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
