Old 2nd September 2008, 18:00   #31
iceman91's Avatar
Thanked: 22 Times
Viper bhai how will it bwe less than 1.6 twin cam. Turbo kits are going cheap these days.
Also A TC swift is way faster than a 1.3 twincam.
iceman91 is offline   Reply With Quote
Old 2nd September 2008, 18:07   #32
viper's Avatar
Thanked: 9 Times
Amit,
Was referring to 1.6l twin cam. From what I understand a new branded turbo kit with stand alone costs 1.4lacs. And am sure a 1.6l twin cam will beat a tc'd swift using stock internals at 5-6 psi. I may be wrong as have never raced both together.
Also a 1.6l twin cam will be more reliable and a daily driver than a TC'd swift.
Viper
viper is offline   Reply With Quote
Old 3rd September 2008, 00:22   #33
rider60's Avatar
Thanked: 47 Times
Originally Posted by viper View Post
Amit,
Viper
okay if its the whole unit that costs less to import then its awesome, do you mean even after paying import duties and bribes etc and getting this engine cost less?
and more over they wont be brand new engines right so would they still be as reliable after a rebuild?
and after all this what about the handling and braking of the car, wont it go for a toss? like i asked in my previous posts?
rider60 is offline   Reply With Quote
Old 3rd September 2008, 00:38   #34
iceman91's Avatar
Thanked: 22 Times
well he still is better off with a baleno engine for half the price.
Old 3rd September 2008, 08:50   #35
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
instead of all this guys.
just change the bottom half in the swift to a larger one. Say the baleno. the head and all else remains the same. Total VFM increase in power. then save money and go TC. It will wipe out competition and yes please do upgrade brakes.
There is one such build happening soon
But, amit isn't the baleno's rod stroke ratio so haywire that TCing it could pose problems? I think the 1.3L is still a better engine to turbo than the 1.6L. I think you are referring to Vikram's car, aren't you?
Old 3rd September 2008, 10:26   #36
iceman91's Avatar
Thanked: 22 Times
My friend who says you got to use the stock combo????
Vikram's car he would be the best person to ask not me.
Old 3rd September 2008, 21:57   #37
v1p3r's Avatar
Thanked: 27 Times
Vikram is getting a 1.6?
Amit, you're going turbo?
Old 4th September 2008, 08:50   #38
Thanked: 35 Times
Ahem, I was thinking its the same block you had for sale. Didn't know it came with different internals. Always thought it was stock internals beefed up to take more strength, but the same dimensions as stock.
You pretend quite well .
Old 4th September 2008, 09:53   #39
Ricky_63's Avatar
Thanked: 394 Times
So what are we saying here ? As I understand, we are talking of 3 variations / options :-
01. Standard Swift engine with the Swift GTi twin cam head
02. Standard Swift engine TC'd
03. Baleno bottom with stock Swift upper (head)
Would someone be so kind as to elaborate & explain the pros & cons as also cost implications of the 3 options ?
Old 4th September 2008, 10:18   #40
Thanked: 35 Times
Ricky, the swift is already running a baleno head (from the factory itself). With a slightly wilder cam profile.
Old 4th September 2008, 10:26   #41
viper's Avatar
Thanked: 9 Times
Rahul,
Am a bit confused. Are you saying that all swifts come with baleno heads from Maruti and they have wilder cams than regular baleno's or Vikram's car has a Baleno head with a wilder cam.
Viper
Old 4th September 2008, 10:32   #42
Thanked: 35 Times
Rahul,
Viper
Jiggy Bhai,
IIRC, all swifts (from Maruti) have the old esteem block mated to a baleno head with slightly wilder cam profiles. I had this confirmed by one of the technical heads at RNS Motors, Bangalore when I was looking for some technical help on swifts and balenos.
Old 4th September 2008, 10:43   #43
viper's Avatar
Thanked: 9 Times
Jiggy Bhai,
Rahul,
I did not know that. Correct me if wrong but all that extra torque a baleno has is there only because of the 1.6 block and if the same is swapped to a swift then the swift should be faster than a baleno going by what you just said.
Viper
Old 4th September 2008, 10:48   #44
Thanked: 35 Times
Rahul,
Viper
Yup. But then we need to count in other factors like weight, aerodynamics etc of the two cars too. Unfortunately, no one has done this comparo till date. I have seen baleno blocks mated with twin cam heads, baleno engines put into a zen but never into a swift.
Old 4th September 2008, 11:32   #45
Ford Rocam's Avatar
Thanked: 16 Times
how much wild? specs if any? one can even carry out a simple test by using a swift cam on to a baleno engine. & see how the engine responds.
Ford Rocam is offline   Reply With Quote
Beginning of a GTI era: My VW Golf GTI Mk4 voyageur Test-Drives & Initial Ownership Reports 45 3rd August 2016 13:27
Spotted! VW Polo GTI with 1.8L TSI engine hemanth.anand The Indian Car Scene 303 4th February 2016 23:30
2003 Maruti Zen Engine Swap : Twin Cam 1300cc GTi Power IndrojitSircar Technical Stuff 47 25th February 2015 09:51
Mini Cooper vs Suzuki Swift GTi bruce The International Automotive Scene 6 30th October 2007 20:10
NEW SWIFT GTI....... Can it come to India? redcandle The Indian Car Scene 14 8th December 2005 10:10
