Old 30th March 2008, 13:11   #106
gopinathann's Avatar
Thanked: 20 Times
Originally Posted by iTNerd View Post
thanks mate.. I think I am gonna stick with the stock grill for now.. also, lost interest in modifying the car post the body kit... if anything that I will get done next is getting a nice pairs of 17" alloys and rubbers..
Are you going for 17'' for looks ?
If you put low profile tyres it will give superior handling, however you will suffer in ride quality and they may have some maintenance issues because of the suspension are not tuned for it.
Clarify all these points and then go for the upgrade.
gopinathann is offline   Reply With Quote
Old 26th July 2008, 15:04   #107
madmaxdave's Avatar
Default Posting my SX4 before and after body kit
As you can all see ,the MGA kit max the car look more agressive but the ground clearance from the front skirt is reduced thus resulting in it scraping the paint off the underside.
madmaxdave is offline   Reply With Quote
Old 27th July 2008, 12:29   #108
AbhiJ's Avatar
Thanked: 537 Times
Itnerd, great looking car!!
If the clearance is bothering you, you can solve a good portion of that problem when you upgrade rims/tyres.
You can increase the ride height by choosing tyres with slightly higher aspect ratio.
AbhiJ is offline   Reply With Quote
Old 27th July 2008, 20:26   #109
theEnd's Avatar
I dont think its a very good idea to change your ride height by messing with the size of your tyres/wheels. Ideally, the outer diameter of your tyres should remain constant, or within 2% of stock. If you want to raise/lower your car its best to do that by modifying the suspension, and make sure whoever does that knows what they're doing.
theEnd is offline   Reply With Quote
Old 27th July 2008, 20:30   #110
theEnd's Avatar
Delhi, and Noida in particular has pretty nice roads. How about trying 18" wheels? Might make your teeth chatter over bad roads, but they would look awesome.
Old 28th July 2008, 02:45   #111
hellspawn's Avatar
Infractions: 0/1 (10)
Originally Posted by prince85 View Post
Could you get one for me dude if its not a problem?? Also it would be great if you could get a pair of projector headlamps like those on the JDM-spec Sx4, i feel they look super-cool and just rock!cheers:
Hey ,could not find the grill for an sx4..Apparently the thai aren't too suzuki friendly..
hellspawn is offline   Reply With Quote
Old 28th July 2008, 03:13   #112
iTNerd's Avatar
Thanked: 505 Times
Thumbs up
@madmaxdave, nice work! your car looks wicked now
@AbhiJ and theEnd, Thanks mate. I dont have any issues with the GC with the body kits. In fact, the clearance still is high enough for all the notorious speedbreakers I had driven over so far! I only wanted to get new tyres and rims (possibly 17" or 225/55), just for the looks and handling.
btw, a friend of mine recently got his new SX4, along with the body kit. here are some shots of both the cars.
(some flirting sessions between "mens").
iTNerd is online now   Reply With Quote
Old 28th July 2008, 15:53   #113
Thanked: 20 Times
It always looks good when we have 2 SX4s side by side. My friends recently took the same color of mine. Here are some pics.
Old 28th July 2008, 15:59   #114
Rahulkool's Avatar
Thanked: 591 Times
^^ hey saw ur car 2-3 days back in Tnagar
IMO your car will look lot better without those stickers on the side/front glass and rims .....
Rahulkool is offline   Reply With Quote
Old 5th September 2008, 14:38   #115
anantnehru's Avatar
Originally Posted by hellspawn View Post
will be going to thailand in june...will pick up a honeycomb grill if i find it..let me know if you need one too.
Hi
Does anyone know the size of the Sx4 grill?
Like would 18in x 48in sheet fit the current grill (both top and bumper)? I know I would have to cut it but just wondering if that would be big enough?
I have options of 18in x 48in and 12in x 48in. Just incase someone knows please help, since im really bad with sizes!
Also since we're putting up Sx4 and Sx4 pictures, here's my addition.
Mine is on the right with newly installed 4300K Bixenons and a friends stock bulbs.
anantnehru is offline   Reply With Quote
Old 5th September 2008, 15:01   #116
Thanked: 31 Times
Originally Posted by anantnehru View Post
Hi
Was wondering why do you want to sheet fit the current grill. Are you planning to do some modifications?
Also 4300K Bixenon how is the performance. Did you put relay, holder etc or they fitted in the existing assembly
aka_iitd is offline   Reply With Quote
Old 6th September 2008, 20:03   #117
anantnehru's Avatar
Yup planning on changing the front a bit. The bixenons fit in the existing assembly with ballast and everything as the normal HID set up goes. Performance Im quite happy, the white is much whiter than the Philips VisionPlus I had before. Throw is quite far too. These are 50w bulbs as compared to normal 35w ones; hence I get flashed quite a few times by oncoming traffic.
Lousy installation of MGA roof spoiler by Popular Killipalam (Maruti dealer) Sankar Modifications & Accessories 11 18th September 2014 19:19
Which Body Cover for my Swift? EDIT : Bought MGA Tyvex lambuhere1 Technical Stuff 15 27th July 2009 11:31
SX4 Spoiler Kit loving_alaap Modifications & Accessories 1 28th September 2007 19:46
Aluminium Spoiler or Body Colored Spoiler v.tec Shifting gears 3 9th March 2006 13:24
Skirts and under body neon lights needed normally_crazy Shifting gears 22 24th March 2005 07:14
