Old 5th March 2008, 18:43   #1
Exclamation Difference Between MPFI/Carburetor LPG Kit ?
what is the difference between an LPG kit that goes into an MPFI engine car and and Carburator Car
Also If I buy an Used LPG kit which was earlier used in MPFI engine would I be able to use the same kit in Carburetor engine or vise versa . What parts of the kit would have to be added or deleted
gameonrwind is offline   Reply With Quote
Old 5th March 2008, 19:47   #2
teknophobia's Avatar
Thanked: 22 Times
AFAIK the two LPG kits are different and you can't interchange them.
teknophobia is offline   Reply With Quote
Old 5th March 2008, 22:10   #3
esteem_lover's Avatar
Thanked: 451 Times
You would end up using only the tank, if there is one.
Old 6th March 2008, 13:57   #4
I am a little confused as to why that is not possible , this link below should be able to better explain why ?
it starts with a basic kit for Carburetor Engines and goes all the way up to MPFI , with just some addition of parts to the basic kit
Tinley Tech LPG Conversions - LPG conversion kit prices.
can the same logic be used ?
Old 6th March 2008, 14:52   #5
Please ignore the earlier post , I went throught the Link in detail and it says that the MPFI and Carubrator Kits a not the same
MULTIJET & MPFI - Whats the difference ? nandans2005 Technical Stuff 20 22nd October 2009 08:48
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
MPFI lpg kit mabhi10 Modifications & Accessories 1 11th May 2008 18:30
Is Star Gas LPG kit good for Maruti MPFI-ed vehicles ? nicejits Technical Stuff 8 28th September 2007 23:08
Lpg Or Cng Better For Esteem Mpfi santo Modifications & Accessories 28 20th July 2006 20:50
