Old 10th March 2008, 20:38   #1
Default OHC problem with Malfunction light
I need some advice regarding my Honda 1.5 Exi AT
Modification done :-
Free flow through Automech
iridum spark plug
splitfire Plug wires
K&N stock air filter
Problem :-
Since last two day Engine malfunction light turns on, when i turn off my engine and start it again it goes off.
what could be the problem?
second thing i need stock suspention's i have heard we get it cheaper somewhere in opera house (Mumbai).
can any one tell me if it's available in the suburbs (Mumbai).
I stay in Malad (Mumbai).
thanks
Dhananjay
dhananjay is offline   Reply With Quote
Old 10th March 2008, 23:54   #2
chetanhanda's Avatar
Thanked: 44 Times
iridum spark plug
Problem :-
thanks
Dhananjay
Problem could be anything ..not easy to guess.
Take it to someone who has a scan tool and get the exact cause of the error.
No use guessing like this..
chetanhanda is offline   Reply With Quote
Old 11th March 2008, 00:00   #3
Dippy's Avatar
Thanked: 192 Times
Dhananjay go to City Motors at Opera House. They have everything for the OHC. You'll get all parts for a good price
Dippy is offline   Reply With Quote
Old 11th March 2008, 00:08   #4
iraghava's Avatar
Thanked: 156 Times
The Automech freeflow header for the OHC has a problem with the positioning of the O2 sensor which triggers the Engine Malfunction light. That is in all likelihood the problem with your car too.
Old 11th March 2008, 00:31   #5
Thanked: 44 Times
These guys have been exhaust for quite some years now .. they still have such basic issues ?
Old 11th March 2008, 00:50   #6
iraghava's Avatar
Thanked: 156 Times
Apparently yes. Compared to the stock manifold the positioning of the sensor in their manifold is totally off & usually leads to a fauly reading from the O2 sensor leading to a Check engine light.
Apparently their dealers have also found a jugaad around it!
P.S. Will try & arrange pictures of the same if possible.
Old 11th March 2008, 00:56   #7
ramie2400's Avatar
Thanked: 58 Times
Ishan i second on your point,my cousins OHC is also te same,he has changed something called Air Sensor chip.The car is with me now days,its with Automech FFE,Stock K&N and some new Tappet covers and all.
Old 11th March 2008, 01:44   #8
Thanked: 44 Times
yes, plz post some pics ..
Old 11th March 2008, 07:19   #9
Thanks a lot Dippy. i really appriciate your timely response.
Old 11th March 2008, 07:25   #10
After I've changed my manifold my engine seems very hot. is there any solution for it
Old 11th March 2008, 07:58   #11
One thing i forgot to mention the car is running on tri-phase. when i turn on the tri-phase the malfuntion light does flash at all.
Old 11th March 2008, 08:55   #12
Akshay1234's Avatar
Thanked: 7,242 Times
its just that the new headers dont have the cover that the stock ones had so your engine bay is hotter but the actual temp is the same.
Malfunction-Indicator light stays on after push-starting car. How serious is this ? supremeBaleno Technical Stuff 18 17th August 2017 16:49
Baleno - Emission Malfunction Light Glowing vensum Technical Stuff 24 25th March 2011 20:32
Engine Malfunction Light ON in OHC. pls advise! raftaar Technical Stuff 110 31st August 2009 17:30
Malfunction light glowing in my Innova…. Mr.Bangalore Technical Stuff 5 22nd September 2006 01:59
