Old 24th January 2009, 23:45   #136
@TADUKUTTAN
Thanks for the shorrt n sweet review mate,thats just unbelievable to hear.Diesel clatter gone plus more power at low rpms Is the power drop in high rpms significant or manageable?
maverick030581 is offline   Reply With Quote
Old 24th January 2009, 23:46   #137
Akshay1234's Avatar
Thanked: 7,243 Times
Originally Posted by drpullockaran View Post
If you are thinking in terms of a twin turbo would it not be better to put the VGT turbo of the Captiva since they share the same engine and you already have a bigger intercooler. All this if you have access to a Dyno and a fresh ECU plot of the Captiva.
elantra and captiva share the same engine? are you serious? we arent talking about the optra magnum.
Old 24th January 2009, 23:56   #138
kpzen's Avatar
Thanked: 1,655 Times
I think he's right. As per the specifications, the Captiva's engine is similar to Elantra..
Even i wasn't aware of this until now.
Old 24th January 2009, 23:57   #139
Awaiting Email Confirmation
Thanked: 319 Times
Default Same enigne
Yes all the three share the same engine. The Magnum, Captiva and the Elantra and also the defunct suv from Hyundai the name of which I forgot; but its got the 2 liter engine of the 3 vehicles..
drpullockaran is offline   Reply With Quote
Old 24th January 2009, 23:59   #140
Akshay1234's Avatar
Yes all the three share the same engine. The Magnum, Captiva and the Elantra and also the defunct suv from Hyundai the name of which I forgot; but its got a 2 liter engine of the 3 cars..
ok. im still not totally convinced though.
Old 25th January 2009, 00:03   #141
kpzen's Avatar
Hyundai TUCSON or Tu - sawn ?
One of the finest SUV's ever sold in India but sadly never made an impression...
Old 25th January 2009, 00:08   #142
Thanked: 319 Times
Default Thats the one
Thats the SUV I am talking about.
I knew it had something to do with Tuxedo but was not sure of the exact name. Thanks KPZen.
The elantra with a VGT and a p-tronic kit with a panel filter from Pipercross would be the mile muncher among Indian cars with good fuel efficiency too.
Old 25th January 2009, 00:10   #143
Akshay1234's Avatar
actually an elantra with a petes box, a greddy boost controller, a green cotton airfilter, and a larger intercooler is the mile muncher among indian cars with good fuel efficiency.
Old 25th January 2009, 00:22   #144
Thanked: 319 Times
Default I agree.
I agree with you but the PSI box erroneously called Petesbox in India is the poor cousin of P-tronic.
The green cotton is poor cousin of Pipercross poly urethane filter. I agree that the ones mentioned by me are far more expensive but its got its benefits. Though I do vouch that Green filter is miles ahead of K&N filter as far as engine longevity is concerned. If you go to the K&N website its mentioned that filteration efficiency improves only after the filter clogs up with muck. Ironic that the filter from K&N is good only after it gets dirty.
The other two you mentioned about I agree whole heartedly.
Old 25th January 2009, 00:25   #145
[quote=drpullockaran;1144270]I agree with you but the PSI box erroneously called Petesbox in India is the poor cousin of P-tronic.
quote]
Any links/locations where we can get info about the same? And why would you call them poor cousins of the PSI box / Green cotton filter?
Old 25th January 2009, 00:29   #146
Thanked: 319 Times
Default Forgot one more
How can I forget the same engine being used in the new Hyundai Sonata Transform.
Welcome to Hyundai Motor :: Hyundai Sonata Embera
Which means that the 1.3jtd from FIAT and the 2litercrdi engine from GM is doing duty in very many vehicles in India. That leads me to believe that spares should not be problem many years down the line for these 2 engines.
Old 25th January 2009, 00:34   #147
Thanked: 319 Times
[quote=maverick030581;1144273]
quote]
P-Tronic additional box-units :: power kit ::engine chips :: diesel chips :: power box-units :: diesel tuning :: power box-unit :: chiptuning :: increase engine power :: diesel booster :: TDI tuning :: additional box-unit (NEW)
Panel Filters | Pipercross Air Filters
N1 Engineering is the dealer in India for the filters.
Old 25th January 2009, 00:46   #148
Thanked: 319 Times
Default This should be an eye opener.
Diesel performance tuning, diesel engine, diesel chiptuning, engine tuning, tuning box, power unit, engine and part, more diesel power, diesel performance chip, diesel fuel injection
As for green filters read up about polyurethane and cotton filter as a filteration medium. google search should see you through. Read the fine print and read between the lines when reading about comparisons.
Old 25th January 2009, 01:01   #149
Thanks for the linky mate.Found two more such products :
Hyundai Elantra 2.0 CRDi tuning diesel performance chip
Chiptuning - Hyundai Accent, Fahrzeug Datenbank Modelle
How many more are there,I wonder
I'm guessing the technique used must be the same across the board.Why the claimed numbers are different is anybody's guess.
Regarding Pipercross and Green,I reserve my comments till I have read up enough or experienced the difference.
Old 29th January 2009, 13:29   #150
Thanked: 20 Times
Default Some silly questions from a diesel addict.
1.Does the pressure drop after the new intercooler cause a drop in performance? Theoretically should right?
2.when the boost is upped using the electronic wastegate, shouldnt that compensate for the pressure drop?
3. even at stock boost levels, with the new intercooler and boost controller, the engine is going to be fed a larger mass of air than stock right? what happens to the pressure inside the cylinders then? where do we draw the line?
4. Fuelling- when the boost is upped, the stock ECU tries to compensate by feeding more fuel to bring the AFR closer to normal, isnt that how the fuelling is maintained? or are you guys using the pete's box to dump more fuel?or a combination of the two? anyone planning to use the RD diesel ECU?
5.Are you guys monitoring exhaust gas temperatures? how are you doing it?
6.The Apexi AVCR boost controller that I think u guys are using, has rpm dependent boost control and gear dependent boost control right? best results would be if that capability is utilised to match fuelling at particular rpm and gear to the boost, is that how you are doing it? if so, how are you getting the info about fuel injected? does the obd scanner give that kind of info?
I know turbodiesels give a lot more freedom with regards to the AFR compared to a petrol, therefore trial and error will work as long as we're cautious, but, would really like to know how the boost controller settings are being fine tuned.
Sorry for all the silly/nosy questions, just trying to plan out mods and I'm pretty ignorant/bookish when it comes to this stuff.
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
